Solving for Air Resistance: Free Fall Homework Help
  • Thread starter Thread starter MCSPT117
    Fall Free fall
The problem involves determining the air resistance acting on a 100-N bag of nails that falls at its terminal speed, focusing on the forces involved in free fall and terminal velocity.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the concept of terminal velocity and the resultant force being zero. Questions are raised about the use of F=ma and how to express the resultant force.
Some participants have provided guidance on equating the resultant force to zero at terminal velocity and have encouraged attempts to derive the expression for the resultant force. There is an ongoing exploration of the forces acting on the object.
Participants are navigating the definitions and properties of forces involved, particularly the distinction between gravitational force and air resistance, while some express uncertainty about the necessary calculations.
MCSPT117
Homework Statement [/b]
Problem: How much Air Resistance acts on a 100-N bag of nails that falls at its teminal speed?
What process do you use to solve this?
At terminal velocity the resultant force on it is zero, so find the expression for the resultant force and equate to zero.
What have you tried so far? Do you understand the properties behind terminal speed?
Nothing.
I'm asking if I need to use F=ma to solve this. And if I do, where are each of the numbers plugged in?
This should be more than enough for you to solve the problem.
Make some attempts and if you're still stuck we'll go from there.
Still don't know what to do? How do you find the expression for the resultant force?
To obtain an expression for the resultant force you have to understand what the resultant force is! ;)
The resultant force is what you get when you sum up all the forces acting on a given object.
What forces are acting on the object?
Air resistance, and gravity are the forces acting on the object, right?
Fg (Force of Gravity) - Ff (Force of Friction) = Fr (Resultant Force)
  • · Replies 39 ·
  • · Replies 18 ·
