Solving for K and M in Quick Question ( y = mx + c )
  • Thread starter Thread starter _Mayday_
9 replies · 5K views
_Mayday_
[SOLVED] Quick Question ( y = mx + c )
Okay, this shouldn't take long. Would it be okay if I did not show any working as I want to know how one equation related to another, which will then aid me in trying to solve the actual question. [tex]T^2[/tex] is the y-axis and [tex]d^2[/tex] is along the x-axis.
The equation of the straight line I have drawn is...
[tex]T^2=(0.10K)d^2+0.042Km[/tex]
I am asked to find a value for for K, and then to calculate a value for m.
m = the effecitve mass
K = the constant for the systemNow I would have thought I would need to consturct a similtaneous equation, but I have a feeling that this equation can be linked to...
[tex]y=mx+c[/tex]
Would x and y in this equation relate to my axis? What would K be? If I put the intial equation in the form [tex]y=mx+c[/tex] will it work? If so here is how I would have thought it should look.
[tex]T^2=m\times d^2 + c[/tex]
Now I can put in the values I have for [tex]T^2[/tex] and [tex]d^2[/tex] so...
[tex]3.13=m\times 0.026 + c[/tex]
I am still not sure what c is...is it K?Any help would be great. If this does not make sense please ask for anything that isn't there and I will go and find it :-p
If you know T2 and d2, you can rewrite the first equation you wrote as:
K = T2 / (0.10d2 + 0.042m)
This equation has the form y = a / (b + x), not y = mx + b.
This assumes that K depends on m.
The problem is that I do not know the values for m or k, so I cannot calculate either of them from that.
You can calculate K from the gradient. Your equation is [itex]T^2=(0.1K)d^2+0.042Km[/itex] which is, on letting y=T^2 and x=d^2 in the form [itex]y=nx+c[/itex] where n=0.1K and c=0.042Km. Now, what does n represent? Can you obtain this from the graph? If so, then you have K and can use your y intercept to find m.
What is n? n isn't in any of my calculations? I know what y and x represent but I do not know what y stands for. m is the gradient...
I changed n to be the gradient when I wrote the equation y=nx+c. You've got two m's and so that's bound to be confusing. Anyway, the important point is that you have the equation in the form y=(gradient)x + (intercept). Compare this to [itex]T^2=(0.1K)d^2+0.042Km,[/itex] with y=T^2 and x=d^2. What is the gradient of your graph? What is the y-intercept?
[tex]Gradient = \frac{T^2}{d^2}[/tex]
I calculated this at 3.3, I did this by drawing a triangle onto the graph to determine this value.
Thanks for your time Cristo, much appreciated. :smile:
