Solving for sin(x) with Complex Numbers
13 replies · 3K views
zzmanzz
Given:
[tex]sin(x) = \frac{e^{ix}-e^{-ix}}{2}[/tex]
Show that [tex]sin(x)[/tex] can be written as:
[tex]sin(x) = \sum_{n=0}^n \frac{x^{(2n+1)}}{(2n+1)!}[/tex]
[tex]e^x = \sum_{n=0}^n \frac{x^{n}}{(n)!}[/tex]
I'm unsure how to treat the imaginary number in order to get a power expansion for [tex]e^{ix}[/tex]
I know that it's not the same as [tex]e^{ax}[/tex] where a is just a constant. Any help on the complex part would be greatly appreciated!
zzmanzz said:
Given:
How is it different from ##e^{ax}## with ##a = i##? More to the point: who told you it is different?
I'm just going by the fundamental law for imaginary multiplication. i.e.
[tex]i = \sqrt{-1}[/tex]
[tex]i^2 = -1[/tex]
[tex]i^3 = -i[/tex]
[tex]i^4 = 1[/tex]
Therefore, if a = i, the expansion has to follow the above pattern?
Wait, I guess I never got the formula for
[tex]e^{ax}[/tex] in the first place now that I think about it. Good catch. Sorry about that!
Is [tex]e^{ax} = [\sum_{n=0}^n \frac{(ax)^{n}}{(n)!}][/tex] correct?
I think it's
[tex]e^{ix} = \sum_{n=0}^n \frac{(ix)^{n}}{(n)!}[/tex]
therefore,
[tex]\frac{e^{ix}}{2} = \frac{1}{2}\sum_{n=0}^n \frac{(ix)^{n}}{(n)!}[/tex]
[tex]\frac{e^{-ix}}{2} = \frac{1}{2}\sum_{n=0}^n \frac{(-ix)^{n}}{(n)!}[/tex]
Then I show that:
[tex]\frac{1}{2}\sum_{n=0}^n \frac{(ix)^{n}}{(n)!} - \frac{1}{2}\sum_{n=0}^n \frac{(-ix)^{n}}{(n)!} = \sum_{n=0}^n \frac{x^{(2n+1)}}{(2n+1)!}[/tex]
Right?
zzmanzz said:
I think it's
therefore,
Then I show that:
Right?
You would do that except you've got some bad information in the problem statement. sin(x)=(e^(ix)-e^(-ix))/(2i) not over 2. And there should be an alternating sign in the series. Or are you really trying to expand the hyperbolic sine, sinh(x)?
Sorry, it's late and I'm missing the details.
He writes that
[tex]sin(x) = \frac{e^{ix} - e^{-ix}}{2}[/tex]
can be represented in power expanded form as:
[tex]sin(x) = \sum_{n=0}^n (-1)^n \frac{x^{(2n+1)}}{(2n+1)!}[/tex]
so you were sight, I was missing the alternating part in the final formula. I looked it over twice and there is no 2i, just 2? Maybe he made a mistake?
He writes that
Yes, he made a mistake. e^(ix)=cos(x)+i*sin(x) and e^(-ix)=exp(i*(-x))=cos(-x)+i*sin(-x)=cos(x)-i*sin(x). So e^(ix)-e^(-ix)=(2i)*sin(x).
According to his notes: [tex]cosh(x) = \frac{e^{x} - e ^{-x}}{2}[/tex]
He didn't give us sinh(x), or cos(x). Just assigned the sin(x) as I stated above with the alternating addition. It has to be 2i to cancel out in order to get the final formula.
I've been trying to cancel/combine the expansion terms for 45 mins now and couldn't get his formula.
I will bring it to his attention. Thank you!
The cosh formula is wrong too. cosh(x)=(e^x+e^(-x))/2. Either whoever is writing the notes or transcibing the notes has some attention problems.
Wow, I'm looking at his pdf and he has cosh(x) written once in your format, and then once again with the -. This is a 3 hour lecture and he was talking for 2 hrs and then just rushed through the last part in 45 mins.
One more thing, is his formula for cos(x) = (e^(ix) + e(-ix))/2 right? Or should this also have 2i in the denominator? I will bring all of this to his attention tomorrow.
Ah, at last a correct formula. Yes, that one works.
Thank you,
So, just to summarize:
[tex]sin(x) = \frac{e^{ix}-e^{-ix}}{2i}[/tex]
[tex]sinh(x) = \frac{e^{x}-e^{-x}}{2}[/tex]
[tex]cos(x) = \frac{e^{ix}+e^{-ix}}{2}[/tex]
[tex]cosh(x) = \frac{e^{x}+e^{-x}}{2}[/tex]
Thanks!
zzmanzz said:
Thank you,
Thanks!
Sure, and [tex]sinh(x) = \frac{e^{x}-e^{-x}}{2}[/tex] if you want to complete the list. The sin and cos formulas follow from deMoivre's expression ##e^{ix}=cos(x)+isin(x)##, you don't have memorize them all you can derive them.
