Solving for y: e^(y) = y^(2) - 2
6 replies · 3K views
flyingfishcattle
Hi
I am having trouble solving for y for the following equation:
e^(y) = y^(2) - 2
ln(x)^(y) = y*ln(x)
ln(e^(y)) = y
ln(2) = 1
My attempt:
e^(y) = y^(2) -2
ln(e^(y)) = ln(y^(2)) - ln(2)
y = 2*ln(y) - 1
y - 2*ln(y) + 1 = 0 <--- stuck here
Any help would be appreciated
flyingfishcattle said:
Hi
e^(y) = y^(2) - 2
ln(x)^(y) = y*ln(x)
ln(e^(y)) = y
ln(2) = 1
My attempt:
e^(y) = y^(2) -2
y = 2*ln(y) - 1
Hello flyingfishcattle . :welcome:
You have some mistakes:
  1. ln(2) ≠ 1 . In fact, what is true: ln(e) = 1, also ln(2) ≅ 0.693 as well as log2(2) = 1 .
  2. In general, ln(A − B) ≠ ln(A) − ln(B) . Specifically, ln(y^(2) − 2) ≠ ln(y^(2)) − ln(2) .
Equations such as this cannot be solved in closed form using standard functions. This equation should be solved using something like numerical or graphical methods.
This cannot be solved analytically.
You have to use an approximation.
For example, you can take the approximation (taylor series) of e^y = 1 + y + y^2/2
Then you will have 0 = y^2 - 2y - 6, and can solve for y.
You will get -1.6458 which is approaching the correct answer. To get more correct, include more terms from the taylor series.
If you are going to do it essentially "by hand", it's much more efficient to just use a couple of iterations of Newton's method.
The first approximation using the 3 term Taylor expansion will be 1 - √7 which you can punch into the calculator. Thereafter you can very easily set up the Newton Rhapson iteration on any scientific calculator having an 'ANS' button (just about all of them!):
$$ANS - \frac{e^{ANS}-{ANS}^2+2}{e^{ANS}-2 \times ANS}$$
Just keep pressing the "=" sign for continuing iterations!
