Solving Force in a Stretched Rope: Applying Hooke's Law
The problem involves a rope with a spring constant k that is stretched by a force F, with an additional force mg applied at its midpoint, leading to a height difference h. The context suggests a model related to slack lines and the application of Hooke's law.
  • Participants discuss the relationship between the forces and lengths in the setup, with some attempting to derive equations based on geometric similarity and others questioning the validity of their approaches.
There are multiple interpretations being explored regarding the relationships between forces and lengths. Some participants have offered algebraic manipulations, while others express skepticism about the results and the assumptions made, particularly concerning the nature of the rope and material properties.
Participants note the implications of using different materials (e.g., steel vs. rubber) and the relevance of Young's modulus in the context of the problem. There is an ongoing discussion about the assumptions regarding elasticity and inelasticity in the setup.
Paul L
The problem:
See attachment for figure.
(1) A rope with a spring constant k is stretched by a force F.The length of the rope is l (including the deformation).
(2) A force mg is then applied at l/2 on the rope. This results in a height difference between the highest (and unchanged point) and the lowest point, h. The length between the endpoints where the force F is applied is still l.
Equations:
Hooke's law for springs: F=kx
Maybe something else? Cant see where and what though...
The question:
Set up an equation for the force F.
My attempts:
I've tried to solve this problem with geometric similarity between the force and the deformation, but obviously not correctly...
Applying in real life:
This is thought to be a model of a slack line set up. If you don't know what that is, do a search on flickr.com and you'll get the idea. Is it reasonable to expect that such thing will follow Hooke's law for springs? Is there any other theory that is better to use? Links?
F in the figure 1 is not equal to F in the figure 2.
F in the figure 2 can be found in terms of mg by using vector method.
New half length of the string can be found in terms of l/2 and h.
Using these values you can find F in figure 1.
The F in figure 2 should be called S. If we call the new length of the rope (the hypotenuse) L, I get the following similarity: L/h = S/F
Then, with some algebra (see attachment), I get an equation I'm not sure what to do with.
L/h = S/F This is not correct. It should be L/(l/2) = S/F and h/L = mg/2S. Solve for F.
I'm not sure if I'm following you, but I tried what you suggested (attachment once again) and ended up with this:
F=(mgl)/(4h)
I have a bit problems believing that's correct as it would mean that an inelastic rope (k -> infinity) will stretch and bend down equally much as a elastic rope when the same force is applied.
For a perfecly elestic body k -> infinity and for a perfectly inelastic body k->0. If you replace the rope by a steel rod and apply the force mg at the mid point, the depression of the mid point is very small.
For a perfectly inelastic body k -> infinity. Hooke's law gives x = F/k and F/k -> 0 when k -> infinity. For a perfectly inelastic body, x = 0 for any given force F.
If the rope is replaced with a steel rod this would be a completely different problem as a rod can absorb torque and a rope cannot. However if you replace the rope with a steel wire, the depression would indeed be very small. That's why the equation F=(mgl)/(4h) can't be correct as it doesn't take this into account.
I still haven't figured out this problem, so any help would be highly appreciated.
Young's modulus of elesticity is given by Y = Stress / strain = (F/A)/(x/L) where F is the stretching force, A is the area of cross section, x is th elongation and L is the original length. So F = [(y*A)/L]*x or F = k*x So for a given deforming force F, when K...> infinity x...> zero. When you apply froce S, x increases.( since k remains constant) And hence the depression of the mid point h increases. Steel is more elestric than rubber, because for an applied force elongation in steel wire is very small compared to that in rubber.
And therefore should the material constant k be included in the equation when the depression (and hence the elongation) is given. The equation F=(mgl)/(4h) must be wrong since it doesn't include the material constant.
Welcome to PF!
Hi Paul! Welcome to PF! :smile:
What a mess everyone is making! :rolleyes:
This is a perfectly simple force diagram question …
it's a rope, so the only force in it is the tension …
you can work out the tension from the length, or vice versa
and the tension is the same at each end …
and you know the angle …
so … ? :smile:
  • · Replies 35 ·
  • · Replies 17 ·
