Finding a cubic through three points with f'(-3)=0 and f'(1)=0
  • Thread starter Thread starter Olle.s
    Function
13 replies · 3K views
Olle.s
The function goes through the points -3,1 -1,3 and 1,4
f''(x)>0 when x<-1 and f''(x)<0 when x>-1
What is the function?
I take it this is a third degree equation?
f(x) = ax^3 + bx^2 + cx + d
When I plug in the values I get
From derivative
0 =27a– 6b+ c
0 =3a+ 2b+ c
From f(x)
1 =-27a +9b− 3c+ d
3 =-a+ b− c+ d
4 =a+ b+ c+ d
I substitute and get rid of c and d and then get
a=-5/48
and from this i get
b=-0.3125 c= 0.9375 d ≈ 3.48
but this is wrong, as the graph doesn't go through -3,1
What did I do wrong? ?
Thanks for help
Welcome to PF!
Hi Olle.s! :smile:Welcome to PF! :smile:
0 =27a– 6b+ c
0 =3a+ 2b+ c
1 =-27a +9b− 3c+ d
3 =-a+ b− c+ d
4 =a+ b+ c+ d
erm … you had five equations and only four variables! :redface:
Try a fourth degree equation. :wink:
I don't think a fourth degree equation will work; the fact that [itex]f''(x)<0 \text{ if } x>-1[/itex] and [itex]f''(x)>0\text{ if } x<-1[/itex] says to me that the graph of f(x) has only one inflection point, and its at x=-1. A quartic won't accomplish that.
oops!
oooh … I never noticed they were both at -1. :redface:
hmmm … that gives a sixth equation, f''(-1) = 0 (or ∞?) …
so maybe a fifth degree equation will do it?
Thanks, gabbagabbahey! :smile: It's a good job other people check up on me! :wink:
Olle.s said:
...The function goes through the points -3,1 -1,3 and 1,4...
Are you sure it doesn't pass through (-1,2) instead? :wink:
tiny-tim said:
so maybe a fifth degree equation will do it?...
Actually I don't think there is a solution to the problem written as-is (if it passes through (-1,2) instead of (-1,3) then it's a different story)
Try sketching a graph of the function using the fact that it must be concave up for x<-1 and concave down for x>-1...it looks almost cubic, but a little fishy at x=-1.
-EDIT- I just realized that the problem doesn't claim that f is continuous...that changes things a little :smile:
hmm … never thought of sketching it …
yes, (-1,2) does look a lot more likely! :smile:
uhh? what's wrong with looking fishy?? o:)
The accompanying golden hue distracts one from the mathematical tasks at hand of course. :rolleyes: (-grasps at straws in search of witticisms-)
:biggrin: i'll take that as a compliment! :biggrin:
Hi,
I'm certain it's -1, 3,
yeah I've sketched it, it's a third degree function with a negative value in front of x^3, I think.
And yeah, I also had some problems when juggling with the variables..
But perhaps there's a typo somewhere in the question that makes it unsolvable?
Because I think this should be failry easy!:frown:
Olle.s said:
Hi,
Well; it's not unsolvable. The function may or may not be continuous.
Given that you are told f''(x)<0 for all x>-1 and f''(0) for all x<-1, does that tell you that f''(x) exists everywhere? If a function is twice differentiable everywhere, then can you say whether or not it is continuous?
What places, if any might f(x) be discontinuous?
Hm... I'm not sure I follow you.
Why is the graph discontinuous?
I haven't said that it is.
Is there any reason to assume otherwise though?
