Solving Gauss' Law for Electric Field Around Spherical Shell
The problem involves applying Gauss' Law to determine the electric field strength around a spherical shell with a specific charge distribution. The shell has an outer radius R and an inner radius R/2, carrying a total charge of -q, while a point charge +q is located at the center.
  • Participants discuss the calculation of charge density and the enclosed charge within a Gaussian sphere. There are questions about the accuracy of the charge density formula and the application of Gauss' Law. Some participants express confusion regarding the use of LaTeX for mathematical expressions.
The discussion is ongoing, with participants providing feedback on attempts and clarifying concepts related to charge density. There is no explicit consensus on the correct charge density, and multiple interpretations are being explored. Guidance has been offered regarding LaTeX formatting.
Some participants mention a lack of understanding of charge density and its definitions, indicating that this is a new topic for them. There are also references to homework constraints and the need for step-by-step assistance.
radiator0505
a spherical shell has an outer radius R and a inner radius R/2 and carries a total charge -q, distributed with uniform charge density. A point charge +q is at the centre of the sphere. Calculate the electric field strength for R/2<r<R
Gauss' Law
I figured out the charge density in the shell ρ = [itex]\frac{-6q}{7πR^3}[/itex], so the charge enclosed by a gaussian sphere is q(1-[itex]\frac{8r^3}{7R^3}[/itex])
Then using gauss' law I get E = [itex]\frac{q}{4πε_0r^2}[/itex](1-[itex]\frac{8r^3}{7R^3}[/itex])
But my book says E = [itex]\frac{q}{4πε_0r^2}[/itex][itex]\frac{8}{7}[/itex](1-[itex]\frac{r^3}{R^3}[/itex])Also does anyone know why the latex things aren't working? I'm new to all this stuff.
Edit: cheers guys
Don't use the BB code tags like inside the LaTeX code. If you want to do superscripts in the LaTex math code, use ^ .
Could be that you're combining Latex with non-Latex stuff. Stick to pure Latex and it should work.
Good.
Redo that one.
(FYI: I agree with the book's answer.)
how do you get
radiator0505 said:
ρ = −6q7πR3
jilia said:
how do you get
What's the definition of charge density?
i don't really understand charge density. all i know is that it have 3 charge densities, volume, area, and linear.
i just learned this today and i get ρ = −6q/πR3 not ρ = −6q/7πR3.
can you help me solve this step by step?
Here we are talking about ρ, which is a volume density.
Why don't you show how you arrived at your answer?
  • · Replies 26 ·
