Solving Gauss-Legendre Algorithm in C++
  • Topic: C/C++
  • Thread starter Thread starter ggeo1
    C++
4 replies · 6K views · last reply
ggeo1
Hello , i have the algorithm attached and i am trying to execute it in c++.
My code until now is : ( i have created the function f with limits (-1,1) )
Code:
#include <iostream>
#include <cstdio>
#include <cstdlib>
#include <iomanip>
#include <cmath>
using namespace std;
const double pi=3.14;
double f(double x){
double y;
y=(pi/4.0)*(log((pi*(x+1.0))/4.0 +1.0));
return y;
double legendre (int n){
    double *L,*w,*t;
    double x,sum1,sum2,result;
    L=new double [n];
    w=new double [n];
    t=new double [x];
        while(n<10){
         L[0]=1;
         L[1]=x;
        for (int i=1;i<=10;i++){
        L[i+1]=((2.0*i+1.0)*x*L[i] - i*L[i-1])/(i+1.0);
        w=0;
        w[i]+=(2.0*(1.0-x*x))/(i*i*(L[i-1]*L[i-1]));
            sum1=0.0;
            for (int k=1;k<=2*n-1;k+=2){
                sum1+=w[i]*(pow(t[i],k));
                sum1=0;
                sum2=0.0;
                for(int k=0;k<=2*n-2;k+=2){
                    sum2+=w[i]*(pow(t[i],k));
                sum2=2.0/n;
    result=w*f(t);
    return result;
int main()
    double eps=1e-8;//accuracy
    double exact=0.8565899396;//exact solution for the integral
    double error=1.0;
    double result;
    int n=1;//initial point
    while (fabs(error-exact)>eps) {
        result=legendre(n);
        cout <<"\nFor n = "<<n<<",error = "<<fabs(error-exact)<<",value = "<<result;
    n++;
    return 0;
I have the following problems:
(first of all i am not sure if am doing it right..)
1) I am not sure how to connect the whole thing.I am computing L[i+1],w and then sum1 and sum2 but i can't figure how to connect them.
2) In the point i am writing result=w*f(t) ,the compiler gives me an error.I can't insert a pointer (t here) in a function as argument?
Any help is appreciated...
For #2: "t" is a pointer to a double, and the function f() wants a double as an argument. So most likely you want to de-reference t: result=w*f(*t);
For #1: I don't know what you mean by "connecting the whole thing", because I'm not familiar with the function you are computing.
This will crash...
You set n = 1...
You call legendre(n)...
Then inside legendre(int) you say w=new double [n];
In other words n = 1 and w has a length of 1.
But then you iterate i from 1 to 10 and say :
sum1+=w*(pow(t,k));
This will crash or at least badly misbehave unless w has a length of at least 11.
Maybe it would help if you posted the specific algorithm you are trying to implement.
Hello ,
i have the algorithm attached.
the compiler gives me the following errors:
where i have "t=new double [x];" it gives -> error: expression in new-declarator must have integral or enumeration type|
and where " result=w*f(*t); " ->error: invalid operands of types ‘double*’ and ‘double’ to binary ‘operator*’|
(note :i changed result=w*f(t) to result = w*f(*t)
And as i said , i don't know if i implemented the algorithm right.
Thanks for helping.
ggeo1 said:
Hello ,
You can't do this, which is what the compiler error message is saying. There are several things wrong here.
1. x is a local variable of type double. When you declare an array, the number must be an integral type (int, long, char, short, etc.) or a value of an enum.
2. Even if you could declare an array with a double or float number of elements, x is an uninitialized local variable.
Thanks for helping.
