Solving Heat Energy Dissipation for a Falling Magnet
5 replies · 4K views · last reply
carpelumen
A magnet of mass 0.10 kg is dropped from rest and falls vertically through a 35.0 cm copper tube. Eddy currents are induced, causing the copper to warm up. The speed of the magnet as it emerges from the tube is 1.50 m/s. How much heat energy is dissipated to the environment?
E = mgh
h = 35 cm --> .35 m
E = (.10 kg) * (9.81) * (.35 m) = .3433 J
Is the equation incorrect?
E = mgh
h = 35 cm --> .35 m
It is the initial energy if you take the potential energy zero at the bottom of the tube. But what is the loss of energy?
ehild
E = mgh
h = 35 cm --> .35 m
What happens to the P.E. that you have just calculated the magnet loses?
Jakob Weg said:
An illustrative experiment on this issue
Good! We note that a larger-diameter tube slows the magnet down more than a smaller-diameter one, following emf = -dΦ/dt. Also that Cu slowed the magnet down more than did Al or brass, following i = emf/R. Vielen Dank!
E = mgh
h = 35 cm --> .35 m
That's the kinetic energy (k.e.) that would have developed in the absence of the copper tube. What was the k.e. with the tube?
