Solving Linear System of Equations: Elimination
The discussion focuses on solving a system of linear equations using the elimination method. The correct solution for x is derived as x=(de-bf)/(ad-bc), which incorporates the coefficients of y to ensure proper elimination. The participants clarify that the condition ad≠bc is necessary to avoid parallel lines or identical equations, which would result in no unique solution. The elimination process is demonstrated step-by-step, emphasizing the importance of aligning coefficients for accurate results.
  • Understanding of linear equations and their standard form.
  • Familiarity with the elimination method for solving equations.
  • Knowledge of algebraic manipulation and coefficient alignment.
  • Basic concepts of unique solutions in systems of equations.
  • Study the elimination method in greater depth, focusing on coefficient manipulation.
  • Learn about the conditions for unique solutions in linear systems, specifically the implications of ad=bc.
  • Explore alternative methods for solving linear equations, such as substitution and matrix approaches.
  • Practice solving more complex systems of equations involving three or more variables.
Students studying algebra, educators teaching linear equations, and anyone looking to enhance their problem-solving skills in mathematics.
ilovecake
A general system of linear equations is
ax+by=e
cx+dy=f
where a,b,c,d,e,f are constant values.
a)Use elimination to solve for x and y in terms of a,b,c,d,e,f.
b)Are there any values that a,b,c,d,e,f cannot have?
For part A, I got x=(e-f)/(a-c), assuming using subtraction for elimination, but in the answers it says x=(de-bf)/(ad-bc). Why are the coefficients of y there?
For part B, I think ad=/=bc because then both equations would cancel out, and it is either the exact same equation or has the same slope but parallel and never intersecting.
for example, 15x+9y & 5x+3y
ax+by=e
cx+dy=f
For part A I got x=(e-f)/(a-c), assuming using subtraction for elimination, but in the answers it says x=(de-bf)/(ad-bc). Why is the coefficient of y there?
For part B I believe ad=/=bc because if ad=bc, then the x and y of both equations would have the same coefficients meaning it's the exact same equation or same slope but parallel and never intersecting.
You need to show your work---how you got the answer, not just the answer itself.
RGV
using elimination by subtraction, solving for x:
ax+by=e
cx+dy=f
(ax+by)-(cx+dy)=(e-f)
ax-cx +by-dy=(e-f)
(a-c)x=(e-f)
x=(e-f)/(a-c)
Nevermind, I just realized that it's to make the coefficients of y the same.
(ad)x+[STRIKE](bd)y[/STRIKE]=(de)
(cb)x+[STRIKE](bd)y[/STRIKE]=(bf)
  • · Replies 22 ·
  • · Replies 21 ·
