Solving MATLAB Loop with X & Latitudes
The discussion revolves around solving a MATLAB coding problem involving the subtraction of a list of latitude values from a set of grid points. Participants explore different methods to achieve this, including the use of loops and vectorized operations.
  • One participant presents a list of latitudes and grid points and describes the desired operation of subtracting each latitude from the grid points, indicating a conditional output based on the results.
  • Another participant suggests a nested loop approach to compute the differences and store them in a matrix, providing a code snippet as an example.
  • A third participant proposes a more efficient method using a single loop to achieve the same result, simplifying the code structure.
  • A fourth participant introduces the use of the bsxfun function to eliminate the need for loops altogether, explaining how it can create a matrix of differences and set conditions based on those values, highlighting its efficiency for larger datasets.
Participants present multiple approaches to the problem, with no consensus on a single best method. Each proposed solution has its own merits, and the discussion remains open to further exploration of these coding techniques.
Some participants' solutions rely on specific MATLAB functions and may assume familiarity with matrix operations and conditional logic in programming. The effectiveness of each method may depend on the size of the dataset and the specific requirements of the task.
Tone L
I have a list of latitudes:
lats =
41.0100000000000
43.7800000000000
44.4200000000000
41.2500000000000
42.8000000000000
42.7500000000000
42.4900000000000
42.4900000000000
42.7800000000000
44.3200000000000
42.1500000000000
41.9300000000000
41.1700000000000
I have a list of gridpoints (latitudes):
X =
41
42
43
44
45
46
I want to subtract every latitude value from my list of grid points... (i.g, X1-lats1, X1-lats2,X3-lats3...etc)
if any X value is greater than any lats value i want d = 0 if not d = 1..Code i tried..i know why it dosent work but i don't know how to code it >.<
for i = lats
for j = X
if i - j > 3
d = 0;
else
d = 1;
end
end
end
You probably want something like this:
Matlab:
lats=[41.01  43.78  44.42 41.25 42.80 42.75 42.49 42.49 42.78 44.32 42.15 41.93 41.17];
X=[41:46];
ans=zeros(length(lats),length(X));
for ix0=1:length(lats) for ix1=1:length(X) ans(ix0,ix1)=lats(ix0)-X(ix1); end; end;
So, "ans" will contain your "lats" by "X" differences.
Or, better:
Matlab:
for ix0=1:length(lats) ans(ix0,:)=lats(ix0)-X; end;
You can do this without using a loop at all by using the bsxfun function. This let's you subtract each value in X from the lats vector, and it forms a matrix. The row C(j,:) is equal to X(j)-lats.
Then you just set all of the negative values (for which the value in X was less than the value in lats) to one, and the other values where X was greater will be 0.
This code should be very fast if you have a larger dataset to do this with.
Code:
C = bsxfun(@minus,X,lats')<0
C =
     1     1     1     1     1     1     1     1     1     1     1     1     1
     0     1     1     0     1     1     1     1     1     1     1     0     0
     0     1     1     0     0     0     0     0     0     1     0     0     0
     0     0     1     0     0     0     0     0     0     1     0     0     0
     0     0     0     0     0     0     0     0     0     0     0     0     0
11K
