Solving Power Output for 3400 KG Truck on 8° Incline
  • Thread starter Thread starter AZhang
    Power
The problem involves a 3400 KG truck driving up an 8° incline, with resistive forces totaling 1200 N, and seeks to determine the power output required to maintain a constant velocity of 20 m/s.
  • Participants discuss the setup of equations and the appropriate formulas for calculating power, with some expressing uncertainty about how to apply their knowledge to the specific scenario.
The discussion is ongoing, with participants exploring different approaches to calculate power, including suggestions to consider time or distance for calculations. Guidance has been offered regarding the relationship between energy, distance, and time.
There is mention of resistive forces and the need to account for both friction and gravitational potential energy in the calculations. Participants are navigating the constraints of the problem setup and the information provided.
AZhang
A 3400 KG truck is driving up a road inclined at 8 degrees above the horizontal. If the resistive forces such as air drag and friction that act on the car add up to 1200 N, determine the power output necessary to keep the velocity constant at 20 m/s.
I don't really get how to set up my equations. Can someone help me?
Have you got a formula for finding power? If not, try wikipedia.
I do, it's both Work/Time and Total Energy/Time, but I don't know how to use them in this scenario.
You need pick a convenient time OR distance to work with. Say you choose 1 second for the time. Then you must work out the distance along the incline that it goes in that time. And the height straight up that it goes. These numbers should allow you to calculate the energy used to overcome friction and the energy used to increase the height. Finally, P = energy/time should do the trick.
  • · Replies 20 ·
