Solving Ratio Test Limit with x and -3
7 replies · 2K views
Dannbr
[tex]\begin{array}{l}<br /> \\<br /> \mathop {\lim }\limits_{n \to \infty } \left| {\frac{{{x^{n + 1}}\left( {\frac{1}{{{{\left( { - 3} \right)}^{n + 1}}}} - 1} \right)}}{{{x^n}\left( {\frac{1}{{{{\left( { - 3} \right)}^n}}} - 1} \right)}}} \right| = \mathop {\lim }\limits_{n \to \infty } \left| {\left( {\frac{{{{\left( x \right)}^n}\left( x \right)}}{{{{\left( { - 3} \right)}^n}\left( { - 3} \right)}} - \frac{{{{\left( x \right)}^n}\left( x \right)}}{1}} \right) \bullet \left( {\frac{{{{\left( { - 3} \right)}^n}}}{{{x^n}}} - \frac{1}{{{x^n}}}} \right)} \right| = \mathop {\lim }\limits_{n \to \infty } \left| {\frac{x}{{\left( { - 3} \right)}} - x} \right|<br /> \end{array}[/tex]
[tex]\begin{array}{l}<br /> \\<br /> <br /> \mathop {\lim }\limits_{n \to \infty } \left| {\frac{{{x^{n + 1}}\left( {\frac{1}{{{{\left( { - 3} \right)}^{n + 1}}}} - 1} \right)}}{{{x^n}\left( {\frac{1}{{{{\left( { - 3} \right)}^n}}} - 1} \right)}}} \right| = \mathop {\lim }\limits_{n \to \infty } \left| {\left( {\frac{{{{\left( x \right)}^n}\left( x \right)}}{{{{\left( { - 3} \right)}^n}\left( { - 3} \right)}} - \frac{{{{\left( x \right)}^n}\left( x \right)}}{1}} \right) \bullet \left( {\frac{{{{\left( { - 3} \right)}^n}}}{{{x^n}}} - \frac{1}{{{x^n}}}} \right)} \right| = \mathop {\lim }\limits_{n \to \infty } \left| {\frac{x}{{\left( { - 3} \right)}} - x} \right|<br /> \end{array}[/tex]
This is as far as i can get I have an answer key which says it simplifies down to..
[tex]= \left| {\frac{x}{3}} \right|[/tex]
could someone help me out with what I am not seeing
Thanks
Removed some extraneous stuff.
Thanks
You're apparently working with a series. Can you provide the series itself? I want to make sure that you're working with the right expressions in the ratio test.
here it is:
[tex]\sum\limits_{n = 0}^\infty {\left[ {\frac{1}{{{{\left( { - 3} \right)}^n}}} - 1} \right]} {x^n}[/tex]
Find a power series for the function, centered at c, and determine the interval of convergence.
[tex]g(x) = \frac{{3x - 8}}{{3{x^2} + 5x - 2}}[/tex]
Using PFD I came up with...
[tex]\frac{3}{{x + 3}} + \frac{1}{{x - 1}}[/tex]
then set it to the form...
=[tex]\frac{1}{{1 - \left( { - \frac{x}{3}} \right)}} - \frac{1}{{1 - x}}[/tex]
[tex]\begin{array}{l}<br /> \\<br /> = \sum\limits_{n = 0}^\infty {\left[ {\frac{1}{{{{\left( { - 3} \right)}^n}}} - 1} \right]} {x^n}<br /> \end{array}[/tex]
the book says Interval of convergence:
[tex]\left| {\frac{x}{3}} \right| < 1and\left| x \right| < 1 \Rightarrow ( - 1,1)[/tex]
I understand now it diverges at (-1,1) because it is (-3,3) is larger
Your decomposition is incorrect. 3x2 + 5x - 2 = (3x - 1)(x + 2). So the denominators in your partial fractions won't be x + 3 and x - 1.
yea, you are right. I posted the wrong problem g(x)
g(x) should be ...
[tex]g(x) = \frac{{4x}}{{{x^2} + 2x - 3}}[/tex]
Sorry.. this whole thing is screwed up
I put in the correct g(x).
[tex]g(x) = \frac{4x}{x^2 + 2x - 3}[/tex]
[tex]g(x) = \frac{3}{{x + 3}} + \frac{1}{{x - 1}}[/tex]
So we should be good at least to here, and the next one or maybe two look correct.
In this line,
[tex]\begin{array}{l}\\\mathop {\lim }\limits_{n \to \infty } \left| {\frac{{{x^{n + 1}}\left( {\frac{1}{{{{\left( { - 3} \right)}^{n + 1}}}} - 1} \right)}}{{{x^n}\left( {\frac{1}{{{{\left( { - 3} \right)}^n}}} - 1} \right)}}} \right| = \mathop {\lim }\limits_{n \to \infty } \left| {\left( {\frac{{{{\left( x \right)}^n}\left( x \right)}}{{{{\left( { - 3} \right)}^n}\left( { - 3} \right)}} - \frac{{{{\left( x \right)}^n}\left( x \right)}}{1}} \right) \bullet \left( {\frac{{{{\left( { - 3} \right)}^n}}}{{{x^n}}} - \frac{1}{{{x^n}}}} \right)} \right| = \mathop {\lim }\limits_{n \to \infty } \left| {\frac{x}{{\left( { - 3} \right)}} - x} \right|\end{array}[/tex]
in the very first limit I would cancel the x factors. This leaves you with
[tex]|x|\lim_{n \to \infty}\left| \frac{\frac{1}{(-3)^{n+1}} - 1}{\frac{1}{(-3)^n} - 1}\right|[/tex]
Instead of multiplying stuff out as you did, I would combine the two terms in the numerator and the two in the denominator, and see if I could simplify that. Another approach is to multiply by (-3)^n over itself. This limit should come out to 1/3.
