Solving Series Convergence: ln(x)^ln ln(x)
pierce15
Is this series convergent or divergent?
[tex]\sum_{n=2}^{\infty} \frac{1}{(ln(n))^{ln \, ln(n)}}[/tex]
[tex]ln(x)<x^a, \, a>0[/tex]
I don't see a way to tackle this one other than the comparison test.
[tex]\sum_{n=2}^{\infty} \frac{1}{(ln(n))^{ln \, ln(n)}} < or > ?[/tex]
What would I compare this to?
Re: LaTeX code: you need }} instead of } to close the \frac command properly. Also, you should write '\ln' instead of 'ln'; 'ln' produces ##ln(n)##, while '\ln' gives ##\ln(n)##.
Slow down and take your hint into consideration.
For ##a>0##, if ##ln(n) < n^a## then ##(ln(n))^{ln(ln(n))} < (n^a)^{ln(ln(n))}##.
Reciprocating both sides, you get ##\frac{1}{(ln(n))^{ln(ln(n))}} > \frac{1}{n^{aln(ln(n))}} >## something I will allow you to notice for yourself.
Then you will have to break down the cases for positive a... you'll need two cases in total. Pretty sure it was 'p-series' though, not 'a-series' :).
Based on visual inspection it looks as if ##\frac{1}{(\ln n)^{\ln(\ln n)}} > \frac 1 {n^{0.1}} > \frac 1 n## for n sufficiently large.
The series diverges.
I don't see how I can match that with your observation though.
The series ##\dfrac{1}{n^{a\ln(\ln n)}}## converges for any a>0, meaning it won't give conclusive evidence.
