Finding velocity and position with acceleration a = -bv
22 replies · 4K views
resurgance2001
Given that a particle has an initial velocity v0 and then undergoes an acceleration a = - bv. , where b is a constant, obtain an expression for v = v(t) and x = x (t) [/B]
Not sure
If I integrate a = - b v
I think I get v + vo = - b x + xo
But then I get stuck
The book actually gives the answer. x(t) = xo + (vo/b) (1 - e^-bt)
But I can't figure out how they got to that. The book kind of assumes that one can solve this and I should be able to but I am stuck. Thanks
Not sure
If you knew the velocity function ##v(t)##, how would you get the acceleration ##a = a(t)##? So, if you are told that ##a = -b v## with constant ##b##, what sort of equation do you get?
If you know the velocity, you can get the acceleration by differenting. dv/dt = - b v ??
So v (t) = - 1/b dv/dt ?
If my function for v(t) is correct, I try integrating this to get x.
I starting with v(t) = - 1/b dv/dt
Integrating both sides, I get
x(t) + xo = -1/b v (t) + v0.
But I know this is incorrect. I can't see where the e^-bt. In their answer comes from. Thanks
It's not incorrect, but you've expressed v in terms of x, not in terms of t. Although, you've been careless with x0 and v0.
If you try ##v(t) = e^{-bt}## you'll find it satifies your equation.
To get v(t) you need to separate v and t before you integrate.
Thanks Perok.
I think I've got it. At least I can show that the answer they gave is a solution.Starting with the answer they gave:
x(t) = x0 + (vo/b) (1 - e^-bt)
I differentiate this once to get:
v(t) = vo e^-bt
I differentiate this a second time:
a(t) = -b vo e^-bt Substuting for [vo e^-bt ] gives:
a(t) = -bv (t) as required.
So now I can see that it would (theoretically) be possible for me (next time) to solve the problem.
Thanks
Thanks Perok.
v(t) = vo e^-bt
Thanks
The DE dv/dt = -bv is among the simplest, and is one of the first you meet in a differential equations course. The solution is easy, because somebody already solved it for us in the past, and it is well documented in just about every textbook: v = const* exp(-b t). The reason is simple: (d/dt) exp(a*t) = a* exp(a*t), from Calculus 101; basically, this is just the exponential derivative (d/dx) exp(x) = exp(x), with a change of variable to x = a*t.
Yes - thanks. I should have got it sooner, but it is about 7 years since I did my course in applied maths and am pretty rusty. Cheers
From your differential equation,
$$\frac{dv}{v}=-bdt$$
Both sides of this equation are exact differentials.
Chet
Hi Chet,
Can you explain a bit more about what you mean when you say that both sides are exact differentials?
Thanks
Peter
Hi Chet,
Thanks
Peter
What is ##\int{\frac{dv}{v}}##?
What is ##\int{dt}##?
Chet
I am not sure. The integral of dV/V, is it
ln V ?
And the integral of dt is t?
So t = lnV
Which seem to make sense given that
V = Vo = e^-bt (I've got to figure out latex!) But I still don't get the term 'exact differentials. Cheers
ln V ?
So t = lnV
V = Vo = e^-bt (I've got to figure out latex!)But I still don't get the term 'exact differentials. Cheers
Given that you simply wrote down the integral of each term, is that not a strong hint of what an exact differential is?
A good example is ##mv\frac{dv}{dt}##
Can you see what that is an (exact) derivative of?
You definitely need to revise derivatives, integration and differentials if you're trying to study DE's.
ln V ?
So t = lnV
No. Including the constant of integration C, the result should read:
lnv=-bt + C
Inverting this gives:
$$v=e^{(C-bt)}$$
Hope this makes some sense.
Chet
Hi Perok
You wrote:
mvdv/dx and then ask, what is this a derivative of.
This is my attempt:
I start by separating the variables:
mvdv = dx
Then integrating both sides, I get:
ma + vo = t + to
I am not sure if this is what you meant.
Hi Chet
Thanks I get that. I am still stuck though on this new term (at least it is a term that I am unfamiliar with) "exact differential". But don't worry - it's probably not so important right now. The main thing is that I am getting back into doing this maths. Cheers and thanks again.
Hi Perok
This is my attempt:
mvdv = dx
ma + vo = t + to
First, I gave you an expression, not an equation. You've effectively set that expression = 1.
In any case:
##mv\frac{dv}{dt} = \frac{d}{dt}(\frac{1}{2}mv^2)##
So, that expression is the rate of change of Kinetic Energy. I.e. it's an exact derivative of the expression for KE. It's a good one to remember.
As I said before, you need to revise your calculus!
Thanks - I guessed that it would be something really obvious like energy but missed it.
You are right, I do need to revise my calculus. Like I said it is 7 years since I did this stuff and now I am trying to study quantum field theory.
Can you give an example of a derivative that is not exact? Sometimes to get a better understanding of what something is one needs to see an example of something which is not the thing in question. Or is it simy because there is no constant? I mean if you just integrate mv over dt , would you not get 1/2 m[v][/2] + C ? Is that why you wrote it mv dv/dt ? Thanks
That should have said 1/2 mv^2 + C (iphone doesn't seem to like latex
PeroK wrote this several posts back:
If you integrate the left side, with respect to t, you have this
$$\int mv\frac{dv}{dt} ~dt = \int mv ~ dv = \frac 1 2 mv^2 + C$$
In the expression on the left, the dt's effectively cancel to produce the expression in the middle.
