Solving "Strange" Syntax Errors with Cookie Fun
  • Topic: Comp Sci
  • Thread starter Thread starter Lancelot59
    Errors Fun Strange
6 replies · 2K views
Lancelot59
We had to basically modify a few variables in the given code and then shoot it out with a valid output. I decided to have some fun with it.
However I get a strange syntax error, here is the code:
Code:
	  //Conditionals controlling the cookie response output
	  if(cookies == "Yes")
		  cookieresponse = "Hooray! Cookies are awesome! :D";
	  else
		  cookieresponse = "YOU MONSTER! HOW CAN YOU NOT LIKE COOKIES!? D:";
	  cout << cookieresponse;
	  << endl;
	  return 0;
VS says I'm missing a ";" before the "<<" of the endl command. What's happening here. According to my book I've done it correctly.
This piece of code:
Code:
	  << endl;
is incorrect. The first line is a complete statement, with a stream on the left and an object on the right. The second line is incomplete; it does not specify a stream.
Consider removing the semicolon at the end of the first line.
- Warren
Thanks, it worked. Could please you explain in a little more detail? I'm still new to C++. All were were supposed to do is copy some code from the handout and change a few variables. I added the cookies part in.
So from what I understand count is a stream, and the cookieresponse variable is an object. Correct?
So if I want to end a line I have to have a stream or something coming before it?
Also do you happen to know any good online resources for C++ programming?
Yes, cout is a stream, and cookieresponse is a variable.
You can do either of the following:
Code:
cout << endl;
or
Code:
cout << cookieresponse << endl;
You can also split up the statement onto multiple lines, but notice that there is still only one semicolon for the whole statement. The compiler ignores whitespace.
Code:
<< endl;
- Warren
I see now. Just to clarify: streams are paths that information can take to enter or leave the program, and objects are elements contained in the program?
A stream is an abstract thing which can source or a sink data. You can read data from streams, or send data to streams. The keyboard is a source of data, so it is a stream. The console is a sink of data, so it is also a stream. Files on disk can be read from or written to, so they are streams. Finally, a network connection between a client and server program is also a stream.
An object is essentially a data structure wrapped up together with the methods used to modify that data. At this point in your programming career, you don't need a well-defined definition of "object," though. That'll come later.
- Warren
