Solving the inequality 2x² - x + 1 < 9
  • Thread starter Thread starter Anne_Boleyn
    Test
5 replies · 3K views
Anne_Boleyn
Can anyone please help? :cry:
2x² - x + 1 < 9Edit: This is what I've done so far
2x² - x - 8 < 0
2 [ x² - 1/2x - 4] < 0
2(x - 1/2)² - 17/4 < 0
This line is incorrect:
2 [ x² - 1/2x - 4] = 2(x - 1/2)² - 17/4
Start by getting the right one, then we'll go foward.
Then should it be: 2 [ x² - 1/2x - 4] = 2(x - 1/2)² + 15/4
:confused: I'm really lost :frown:
The formula you should memorize if you have difficulty with this is
[tex]ax^2+bx+c= a\left[ \left( x+\frac{b}{2a} \right) ^2 - \left( \frac{b}{2a} \right) ^2 + \frac{c}{a} \right][/tex]
Apply this formula to your equation. (i.e. plug a=2, b=-1 and c=-8)
2x² - x + 1 < 9
2x² - x - 8 < 0
another method is to solve [itex]2x^{2} - x - 8 = 0[/itex] by dividing both sides by 2 and solve the quadratic equation using
[tex]x = \frac {-b ^{+}_{-} {\sqrt {b^{2} - 4ac}}} {2a}[/tex]
and then investigate for what x this inequality is valid.
2x² - x - 8 < 0
Uhmm, let f(x) = ax2 + bx + c, and let the equation f(x) = 0 has 2 real roots x1, and x2, such that x1 < x2. We choose a arbitrary x0 value. We have:
[tex]af(x_0) < 0 \Leftrightarrow x_0 \in ]x_1 , \ x_2[[/tex]
[tex]af(x_0) > 0 \Leftrightarrow x_0 \notin ]x_1 , \ x_2[[/tex]
Or in other words:
x0 is in the interval ]x1, x2[ if and only if the leading coefficient a, and f(x0) takes different signs, i.e if a is positive, then f(x0) is negative, and vice versa.
x0 is not in the interval ]x1, x2[ if and only if the leading coefficient a, and f(x0) takes the same sign, i.e if a is positive, then f(x0) is also positive, and vice versa.
I'll give you an example:
Example:
Solve the inequality:
x2 + 5x + 4 < 0
<=> (x + 4) (x + 1) < 0
-4, and -1 are the 2 roots for this equation.
Let f(x) = x2 + 5x + 4
The leading coefficient of f(x) is 1 > 0
And you have to solve for f(x) < 0, i.e, you will have to find all the value x such that f(x) and the coefficient take different signs, so the solution is
<=> -4 < x < -1
Can you get this? :)
