Solving the O.D.E using Frobenius Method about x=1
  • Thread starter Thread starter T-chef
    Frobenius Method
The task involves finding an analytic solution to the ordinary differential equation (O.D.E) given by 4(1-x^2)y''-y=0 with the condition y'(1)=1, using a series solution centered around x=1. The original poster notes that the singularity at x=1 is regular, suggesting the use of the Frobenius method for the series expansion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the form of the series solution and the implications of expanding about x=1 instead of the more common x=0. There is a suggestion to substitute t = x - 1 to simplify the differential equation. The conversation includes attempts to derive the indicial equation and concerns about the indices of summation in the series.
Participants are actively engaging with the problem, sharing their attempts at rewriting the differential equation and expressing their thoughts on the indicial equation. Some express uncertainty about the implications of their findings, particularly regarding the values of r and the conditions for a_0.
There is a noted concern about the validity of certain assumptions, such as whether a_0 can be zero, which may affect the nature of the solution. The discussion reflects a variety of interpretations and approaches to the problem, indicating a rich exploration of the topic.
T-chef
The task is to find an analytic solution to the O.D.E
[tex]4(1-x^2)y''-y=0 \hspace{20mm} y'(1)=1[/tex]
by using an appropriate series solution about x=1.
The singularity at x=1 is regular, which makes me think the Frobenius method is what's meant by appropriate series solution. But I've always done these about x=0, so I suppose the form would be
[tex]y=\sum_{n=0}^{\infty} a_n (x-1)^{n+r}[/tex]
with
[tex]y''=\sum_{n=0}^{\infty} a_n(n+r)(n+r-1)(x-1)^{n+r-2}[/tex]
At this point I'd substitute into the O.D.E and find an indicial equation, but I'm not really sure how this works when we're expanding about x=1, or indeed if this is the right track. Any help or advice would be greatly appreciated!
with
That all looks good to me in terms of the concept, but there's a slightly easier way to do this. Whenever you have a regular point ##x_0 ≠ 0##, substitute this :
$$t = x - x_0$$
This will make your life so much easier when dealing with this.
Hey Zondrina! Cool, so making the substituion [itex]t=x-1[/itex] the D.E then becomes
[tex]-4(t^2+2t)y''(t)-y(t)=0[/tex]
and the assumed solution is
[tex]y=\sum_{n=0}^{\infty} a_n t^{n+r}[/tex]
so we end up with
[tex]4\sum_{n=0}^\infty a_n (n+r)(n+r-1)t^{n+r}+8\sum_{n=0}^\infty a_n (n+r)(n+r-1)t^{n+r-1}+\sum_{n=0}^\infty a_n t^{n+r}=0[/tex]
Or perhaps more neatly,
[tex]\sum_{n=0}^\infty [4a_n (n+r)(n+r-1)+a_n]t^{n+r}+8\sum_{n=0}^\infty a_n (n+r)(n+r-1)t^{n+r-1} =0[/tex]
Now, if I'm not mistaken (I might be :) ), this second sum will give me my indicial equation so I can find r?
so we end up with
You need to satisfy this equation for all ##t##:
$$\sum_{n=0}^\infty [4a_n (n+r)(n+r-1)+a_n]t^{n+r}+8\sum_{n=0}^\infty a_n (n+r)(n+r-1)t^{n+r-1} =0$$
That is, the coefficient of each power of ##t## must be zero. This will yield your indicial equation and then your exponents of singularity.
Alright, well, messing with that last sum:
[tex]\sum_{n=0}^{\infty}(4a_n(n+r)(n+r-1)+a_n)t^{n+r}+8\sum_{n=1}^{\infty}a_n(n+r)(n+r-1)t^{n+r-1}+8a_0(r)(r-1)t^{r-1}=0[/tex]
So the lowest power is this [itex]t^{r-1}[/itex] fella, in which case [itex]r(r-1)=0[/itex]. But from the wording of later parts in this question it seems there's only one solution to be found here. Would I be right in assuming this is from r=1, since r=0 would give a [itex]t^{-1}[/itex] term in the above equation, which is not the form of a power series?
You need to be a bit more careful about the indices of your summations. They really do matter.
##-4(t^2+2t)y'' - y = 0##
##-4t^2y''- 8ty'' - y = 0##
##y = \sum_{n=0}^{\infty} a_n t^{n+r}##
##y' = \sum_{n=1}^{\infty} (n+r)a_n t^{n+r-1}##
##y'' = \sum_{n=2}^{\infty} (n+r)(n+r-1)a_n t^{n+r-2}##
Therefore the DE becomes:
##-4t^2 \sum_{n=2}^{\infty} (n+r)(n+r-1)a_n t^{n+r-2} - 8t\sum_{n=2}^{\infty} (n+r)(n+r-1)a_n t^{n+r-2} - \sum_{n=0}^{\infty} a_n t^{n+r} = 0##
##- 4 \sum_{n=2}^{\infty} (n+r)(n+r-1)a_n t^{n+r} - 8 \sum_{n=2}^{\infty} (n+r)(n+r-1)a_n t^{n+r-1} - \sum_{n=0}^{\infty} a_n t^{n+r} = 0##
##- 4 \sum_{n=2}^{\infty} (n+r)(n+r-1)a_n t^{n+r} - 8 \sum_{n=1}^{\infty} (n+r+1)(n+r)a_n t^{n+r} - \sum_{n=0}^{\infty} a_n t^{n+r} = 0##
Okay, this should be nothing too far from what you've already done, but there's still a problem to be tackled. Notice that all the powers of ##t## are the same, which is what we want. The indices of the three summations are completely different though, which needs to be rectified to be able to find the indicial equation.
Notice you can re-write the second sum as:
##8 [\sum_{n=1}^{\infty} (n+r+1)(n+r)a_n t^{n+r}] = 8[(r+2)(r+1)a_1t^{r+1} + \sum_{n=2}^{\infty} (n+r+1)(n+r)a_n t^{n+r} ]##
Do the same for the third sum. What does your equation look like now? Can you combine the sums effectively now?
[tex]\sum_{n=0}^{\infty} a_n t^{n+r} = \sum_{n=2}^{\infty} a_n t^{n+r}+a_0t^r+a_1t^{r+1}[/tex]
Putting this, and your expansion into the D.E we can group all the sums, since they start at n=2,
[tex]\sum_{n=2}^{\infty} [4(n+r)(n+r-1)+8(n+r)(n+r+1)+1]a_nt^{n+r}+8(r+2)(r+1)a_1t^{r+1}+a_0t^r+a_1t^{r+1}=0[/tex]
[tex]\sum_{n=2}^{\infty} [4(n+r)(n+r-1)+8(n+r)(n+r+1)+1]a_nt^{n+r}+[8(r+2)(r+1)+1]a_1t^{r+1}+a_0t^r=0[/tex]
How's this look :) ? This suggests a_0=0, and then equating the coefficient of [itex]t^{1+r}[/itex] to zero gives non-integer r, is that okay?
Lookin good.
Now you have to solve for the roots and satisfy the equation for all t. That means even if ##t≠0##, the equation still has to be zero.
So ##a_0 = 0## is good.
Now ##8(r+2)(r+1) + 1 = 0## yields ##r_1 = \frac{1}{4} (\sqrt{2} - 6)## and ##r_2 = \frac{1}{4} (-\sqrt{2} - 6)##.
These are the exponents of singularity.
Now, solve the equation for the coefficient of ##t^{n+r}## and simplify it. This yields your recurrence relation for ##n≥1##.
Now you have to break this down into cases to find the general ##a_n## term. One for the first root and one for the second root and for each case you have to test values of ##n≥1##.
I haven't read through this thread carefully, but generally, this condition isn't correct. By assumption, ##a_0 \ne 0##, otherwise you'd just replace r by r+1. In other words, r is defined as the value for which ##a_0 \ne 0##.
Yes, the assumption is usually ##a_0 ≠ 0##.
I found it odd that ##a_0t^r## was grouped. The problem is if ##t≠0##, then ##a_0t^r ≠ 0##, which prevents the solving of the equation. It has to be valid for all ##t## I believe.
That's the right indicial equation. The two roots differ by an integer, so the larger value will yield a solution. The smaller value may or may not give you a second independent solution. It depends on how the coefficients work out.
It's okay to have a term like t-1 in your solution, so that's not a reason to discard the root r=0. After all, you're expanding about a singular point. It wouldn't be surprising if the solution diverged around there too.
You're thinking of what happens when you differentiate a Taylor series. With the method of Frobenius, you can't assume the lowest order terms vanish because of ##r##.
For example, suppose r=2, the series would be of the form
$$\sum_{n=0}^\infty a_n x^{r+n} = a_0 r^2 + a_1 r^3 + \cdots.$$ If you differentiate twice, you'd get
$$\sum_{n=0}^\infty a_n (r+n)(r+n-1) x^{r+n-2} = 2 a_0 + 6 a_1 r + \cdots.$$ If you started with n=2, the sum would be missing the constant and linear terms.
