Solving the Sturm-Liouville System: Finding Eigenvalues and Eigenfunctions
  • Thread starter Thread starter sassie
    System
The discussion revolves around solving a Sturm-Liouville system to find eigenvalues and eigenfunctions from a differential equation involving second derivatives and a parameter λ. The equation presented is complex and involves terms that suggest a need for careful manipulation and substitution.
  • Participants discuss expanding the original equation and attempting substitutions to simplify the problem. There are mentions of using the chain rule and concerns about differentiation errors. Some participants express confusion about obtaining the general solution and seek hints to progress.
The discussion is ongoing, with participants sharing their attempts and corrections. Some guidance has been offered regarding the manipulation of the equation and the importance of boundary conditions, but there is no consensus on a clear path forward yet.
Boundary conditions are noted as y(0)=0 and y(1)=0, which may influence the approach to finding eigenvalues and eigenfunctions. There is also mention of the complexity of the problem compared to previous ones encountered by participants.
sassie
Evaluate and find the eigenvalues and eigenfunctions for:
[tex]-\frac{d}{dx}[(1+x^{2})\frac{dy}{dx}]=\lambda\frac{1}{1+x^{2}}y}[/tex]
Okay, what I did was to expand the given equation to get:
[tex]((1+x^{2})^{2})y''+2x(1+x^{2})y' + \lambda y =0[/tex] <---- edit typo
But then I get on how to get the needed general solution. I have tried substitution by letting [tex]t=1+x^{2}[/tex] and then using the chain rule to get the first and second derivatives etc. I tried that to get a nice equation, but it ended up with a messier equation. Now I am really stuck and don't know what to do. Your help is very much appreciated.
[tex]((1+x^{2})^{2})y''+2x(1+x^{2}) + \lambda y =0[/tex]
It looks like you made an error when you differentiated. I get
[tex]-(1 + x^2)y'' -2x \frac{dy}{dx} = \lambda \frac{1}{1 + x^2} y' - \frac{2x}{(1 + x^2)^2} y'[/tex]
After multiplying both sides by (1 + x2)2 I don't get what you show.
Okay, what I did was (sorry I did skip a few steps):
LHS = [tex]-(1+x^2)y''-2xy'-(\lambda \frac{1}{1 + x^2}) y=0[/tex]
I then multiplied through by [tex](1+x^2)[/tex]
Now, I understand how you got the left hand side of the equation you gave, I am a little confused about how you got the right hand side.
But can anyone help me with this question? I've been working on it for 5 hours straight and still I can't a solution! This question is just so much harder than ones I have handled previously!
ok so the first step is to solve the general ode
then find the eigenvalues and functions from the general solution, using the boundary conditions, where are you up to?
EDIT - re-read, so you're trying to find the general solutions...
I haven't even got the general ODE and that's what I have been having problems with. I have absolutely no idea how to obtain it :'(
I know it should be easy but for the life of me, I can't do it
Re: EDIT
Yes, so I am trying to get the general solutions to the given equation but I do not know how to.
I should not have differentiated the right side. I erred by thinking incorrectly that we were differentiating both sides. Sorry for the bad advice - it was late at night and I misread your equation.
Your equation still has an error, though. It is missing a y' factor in the second term.
Mark44 said:
I should not have differentiated the right side. I erred by thinking incorrectly that we were differentiating both sides. Sorry for the bad advice - it was late at night and I misread your equation. Your equation was correct as it was.
Oh, okay! I was pondering why your RHS was the way it was. But can you help me with getting the equation into a form where I can the general solution? I REALLY need a hint to get me on the right track. I am sure I can solve for the eigenvalues and eigenfunctions myself, it's just been getting the general solution which has been causing me problems.
EDIT re: error sorry, that was a typo
yeah that's tricky, mucked around with a few things, series was pretty nasty, even if you solve for the lambda = 0 case you get an inverse tangent...
one thing i did notice however is that if you use the chain rule with some substitution t(x), then using chain rule, with dashes for x derivative & dots for t derivative
[tex]y' = \frac{d}{dx}y(t(x)) = \frac{dy(t)}{dt}\frac{dt(x)}{dx} = \dot{y} t'[/tex]
so then it would be nice to cancel the x term in the brackets, so i started with
[tex]t'(x) = \frac{dt(x)}{dx} = 1+x^2[/tex]
and things evolved nicely form there...
the nice part is that after cancelling the term, you're left with:
[tex]\frac{d}{dx}(\dot{y}) = \ddot{y} t'(x) = \ddot{y}(1+x^2)[/tex]
and unless i missed something, everything simplifies a heap... ;)
Okay, thanks. I'll try that out :)
sassie, see the end of my post #8. Your equation in the first post did have an error in it.
Thanks, I did notice that mistake :)
Hey lanedance, is it possible for you to put up more of your working? I seem to be getting some thing different
apologies - think i made a mistake writing down the ODE, so it doesn't cancel like i thought;(
sorry, that was my fault. i wrote down the wrong ode, but mark44 pointed out the mistake. look's like I'm back at square 1.
I spent a little time reviewing S-L equations this morning. In most of the examples I saw there were boundary conditions. Are there boundary conditions in your problem?
yes,
y(0)=0 and y(1)=0
so the original ODE is:
ok think I've may have made some headway on the ODE, the lambda x=0 case is easy to solve & gives an inverse tangent function, which may be a hint of what direction to go...
now assume we are going to simplify by making a substitution t(x), then
[tex]y' = \dot{y}t'[/tex]
[tex]y'' = \ddot{y} (t')^2 + \dot{y} t''[/tex]
so going back to the DE and substituting in gives
[tex]((1+x^{2})^{2})(\ddot{y}(t')^2 + \dot{y}t'') +2x(1+x^{2})\dot{y}t' + \lambda y =0[/tex]
collecting terms
[tex]((t')^2(1+x^{2})^{2})\ddot{y} + (t''(1+x^2)^2+t'2x(1+x^2))\dot{y} + \lambda y =0[/tex]
so then it looks worth trying
[tex]t' = \frac{1}{1+x^2}[/tex]
then differentiating again gives
[tex]t'' = \frac{-2x}{(1+x^2)^2}[/tex]
then see how that goes subbing in, hopefully will simplify down for a better DE for t...
if this works, you'll need to be careful with your boundary conditions, on determining the eigenvalues & eigenfunctions...
so did you get to [itex]\ddot{y}+\lambda y = 0[/itex]?
