Solving the Twin Paradox with Lorentz Transformation
  • Context: Graduate
  • Thread starter Thread starter AdVen
    Paradox Twin paradox
186 replies · 27K views
MikeLizzi said:
The point of the paradox is that a superficial calculation made with the astronaut as the observer gives a contradictory answer. The only way you resolve that problem is by providing the correct calculation, or at least explaining the correct calculation, with the ASTRONAUT as the OBSERVER.
I've mentioned before that Einstein's 1918 resolution addresses it from the non-inertial frame of the ship. I know most consider the standard resolutions adequate because they provide the correct answer, but Einstein realized full well that a 100% correct resolution isn't necessarily a satisfactory one.
Basically, you can break the period of acceleration into as many segments as you want, and calculate Earth time for each one in the ship's (co-moving inertial) frame. Or just use the equivalent of an infinite series of co-moving inertial frames: gravitational time dilation.
Einstein's resolution just uses the simple gravitational time dilation equation for linear acceleration to calculate elapsed time on Earth's clock in the ship's frame during acceleration. And, unsurprisingly, gets the same answer as the standard resolutions.
MikeLizzi said:
The only way you resolve that problem is by providing the correct calcultion, or at least explaining the correct calculation, with the ASTRONAUT as the OBSERVER.
You have not done that. You have not resolved the paradox.
Pointing out the frame-invariant geometry of the problem (longest interval is a straight line) is a perfect resolution. It gives the student a new way to think about relativistic physics that both clearly demonstrates the mistake in the paradox and helps the student learn more advanced physics.
=Al68;2794254]I've mentioned before that Einstein's 1918 resolution addresses it from the non-inertial frame of the ship. I know most consider the standard resolutions adequate because they provide the correct answer, but Einstein realized full well that a 100% correct resolution isn't necessarily a satisfactory one.
Hi Al68
I don't even remember if I ever read that paper let alone the contents but I have some questions on principle:
1) As I understand it G time dilation in an accelerating frame only has an effect within
the frame itself . A relative dilation between different locations in the frame.
It does not have any effect relative to inertial frames {clock hypothesis]
The relationship with other frames is simply derived from the instantaneous relative velocity. As per your statement below ((2))
2) Even in a round trip with only a relatively short acceleration phase compared to total trip length;- m the overall trip time the cumulative diilation is based on both accel. ICMF velocity and inertial velocity
but the inertial phase dilation (from velocity), which would normally be reciprocal [relative] has now become real , actual.
{Catalytic effect}
3) There is no corralation between the relative percentage of the trip that is accelerated and the end result . Quite unusual for a physical phenomenon wouldn't you say?
For a relevant parameter to vary with no consequence to the end result??
IMO The reason many people are unsatisfied with the resolution is:
It seems like you should be able to analyse the picture from either frame in an identical manner. Assume the accelerating frame as at rest and the Earth is accelerating etc.
Draw an Earth worldline that is curved in areas and straight while inertial and apply all the relevant math on that basis. This of course can be easily calculated and in actuality wouldn't the calculations also be identical,?
Then there would be symmetrical Minkowski diagrams [reciprocal mirrow images] and all the analysis that is commonly used in resolutions would be identical.
But this is not allowed. It is denied on the basis of somewhat ad hoc pricipals
a) Acceleration is real as opposed to inertial motion which is purely relative [unreal]
b) Because of a) only inertial frames are considered valid.
c) Because a world line which changes direction makes it longer and accelerated . ANother version of
a) and b)
Regarding :
a) It is true that there are measurable differences between accelerated and inertial motion.
Unquestionable.
But does there simply being a difference mean there must be a specific effect attributable to that difference?
There is no physics principle or concept suggesting that acceleration would result in real dilation or how it might catalytically turn relative dilation into real or explaining how it possibly could effectuate this result.
So it is not because there aren't valid resoluions to the "paradox" that there remains the dissatisfaction [if anything there are too many]
it is because some seemingly valid ways of looking at it are negated on grounds that are themselves not completely satisfactory or consistent.
Basically, ((2)) you can break the period of acceleration into as many segments as you want, and calculate Earth time for each one in the ship's (co-moving inertial) frame. Or just use the equivalent of an infinite series of co-moving inertial frames: gravitational time dilation.
((1))
I am going to have to read the 1918 paper (again?)
Judging by this it seems to indicate that G-dilation is exactly equivalent to velocity dilation [ICMF's etc.]
COnsistent with clock hypothesis
But this seems strange if G-dilation is constant but instantaneous velocities are varied.
ANy ideas ?
Thanks
IMO, the basic problem, and the reason for the astonishing clamour in this thread is that no-one seems to agree on what a 'resolution' is.
Certainly I personally can't agree that simply calculating the ages of the twins correctly is enough. Simply calculating the values correctly gives one an impression of having 'solved it' without striking to the heart of the paradox.
The paradox is deeper than that and for me it hinges on the question of what happens during a velocity change. Not in the sense of how acceleration affect time (General Theory), but what happens to the geometry of space time at that point.
As Dalespam pointed out earlier, differing path lengths is the simplest answer. The path length (proper time) is frame independent, that is, everyone agrees upon it. The main problem is that because of the strangeness of the result the problem is introduced to whet the readers appetite for relativity before the reader is equipped with the tools to resolve it. Once the concept of proper time is understood the problem goes away. The twins scenario is no "deeper" than anything else in SR.
Matheinste.
I agree the paradox is deeper and has nothing to do with the twins final ages really.
There are deeper questions intrinsic to the problem.
It involves the meaning of simultaneity. And the relationship between simultaneity and time dilation.
The meaning and reality of acceleration.
Certain inconsistencies between different valid methods of resolution which derive the same results.
On the GR and how acceleration effects the geometry of space ; from what I have gathered SR says there is no change in the geometry but GR and Rindler coordinates seem to imply there would be. My study of bGR and Rindler is just beginning so I would like to know the answer my self.
My point exactly.
I 'solved' this problem decades ago. Then suddenly realized much later that what I had wasn't a resolution at all - just a maths question with a textbook solution.
No. The differeing ages of the twins is put forward as the paradox.
Matheinste
Matheinste
:rolleyes:
Hmm... not a very good rolleyes smilie is it?
As far as a "deeper" meaning goes; Differential ageing is a direct logical consequence of the axioms of SR. That is where any deeper meaning lies and when we find that deeper meaning we can start looking for a still deeper one.
Matheinste.
Matheinste.
Has it never occurred to you to wonder how it is possible for JC to be still alive (or not even yet born) in some F.O.R.?
Or that in others, the Earth no longer exists?
And that all that separates these frames is the velocity of the inhabitants?
I disagree. The age difference is a paradox in the sense "a counterintuitive result", but a lot of people have used this scenario to argue that SR is logically inconsistent, not just that it's counterintuitive. All of them are using the word "paradox" in the sense "logical contradiction". You can't prove them wrong by showing that the astronaut twin will be younger than his brother at the reunion.
I would be interested to know which particular argument you use to come to the conclusion that there are frames of reference for whom the inhabitants at rest in them the Earth no longer exists, even allowing your implicit assumption that the Earth will eventually cease to exist in the reference frame in which it is at rest.
Idon't wish to get into discussions about determinism as the subject carries too much baggage with it.
Matheinste.
I hate the use of the word paradox to describe it because as you say, as others have said and as I have said ad nauseam, it follows logically from the axioms of SR. I cannot see how the result can be used to prove SR inconsistent.
I have seen more than one author express the opinion that all the time spent arguing about the resolution would be better spent actually learning some basic SR.
Matheinste
What is an "Ansible?" Is it from the same world as the old chemical "phlogisten?"
If one accepts the principle of SR or GR, two events can be simultaneous only if they are within the lightcone. Now, if you don't accept that premise (i,e,, don't "believe" in relativity) well that's your "bag." But, so far, all experimental evidence and natural phenomenon such as the mu-mesons, etc. support relativity.
Now, I am not one to challenge Einstein, Hilbert, Eddington and all those giants of the past.
If they are wrong - as they say in Missouri - show me.
Steve Garramone, MD
Melbourne, FL
Steve Garramone, MD
Melbourne, FL
That should be spacelike separated. There are no restrictions on their locations in spacetime other than that.
Matheinste.
Touche.
I allowed myself to get carried away.
However, this points up another facet of SR, namely that although it is possible for one observer to 'lag behind' another in time. It is not possible for an observer to be 'in front' of the other. No?
In which case, the rules of common logic seem not to apply.
Don't get me wrong, SR wins in my book. However, having removed one rule, can we trust any of the others?
Consider a distant inhabitant who is (a) at rest and (b) at the origin of an inertial frame moving quickly towards the direction of the earth. If distant enough and quick enough, his plane of simultaneity tips up enough so that, for him, the Earth's world line ends beneath the plane - i.e, for him, the Earth no longer exists.
Is this not coherent?
Matheinste.
You're right. One Diemnsion - if event at x1, t1 and x2, t2 occur simultaneously, (t1 = t2) there is no way that light could eminate from either one and get to the other "within the speed of light" as each event would have its own light cone and each event would be outside the others light cone and therefore spacelike.
Sorry for being being "spacy" myself.
SMG
When I have time I would like to bust the original supposition apart but I cannot into it now. This is a perfect example of Einstein's train, and an "Ansible" is sort of like a Unicorn - it doesn''t even exist in a make believe world -that's two steps removed from reality.
Now I don't mean to be disrespectful here and all ideas must be entertained. Lord knows, you folks have put up with my idiocy in the past and will do so in the future and my idiocy is far more spacy than this original thread. So thank you all for past and future tolerations of my going down blind alleys and incongruities.
AJ Bentley said:
Gentlemen, Please!
Humour me, have a go at this restatement of the paradox in a different form.:-p
Observer Alice, says to Bob ,who is just passing by at nearly the speed of light 'My Granny on Proxima Centauri is just sitting down to kippers for her tea'
Alice knows that because she has an Ansible (which allows her to see what Granny is doing right now without having to wait for the light to arrive)
Bob, who also has an Ansible, takes a quick look and says 'No she isn't, your Granny had her kippers for tea three days ago'
Explain.
You might like to show how Bob's Ansible allows him to travel back in time and re-experience events that have already happened.
What would Alice need to do to 'freeze' her Granny in time so that she is always having tea?
How long can she hold Granny frozen?
No offense meant to you. I will go over your proposition in closer detail so that I may more clearly undertand it.
Yes, but in this case the non-earth inhabitants will not be aware of the Earth's demise until the light from the event reaches them. They cannot before then say that in their now Earth has vanished. This, for me, and many others is part of the problem with definitions of simultaneity. They have no natural meaning. They are all, probably of necessity, conventional.
Of course there are some serious philosophers and maybe physicists who ague that there is a natural concept of absolute simultaneity. I have yet to study their reasoning. My opinion is that the usual definitions of simultaneity are useful until they lead to contradictions. If a mere convention causes problems in a certain context then don't use it.
Matheinste.
Has it ever been shown either experimentally or through observation of natural phenomena that gravity travels at the speed of light (no faster?)
In other words, if our Sun was to suddenly "go away," it would take eight minutes or so for us to a) lose the light and b) fly off into space.
stevmg
I see and agree.
I am aware there is an issue of whether a concept of simultaneity is mere convention or something more. I think this issue is very delicate.
I would distinguish this from the question of whether there is such a thing as absolute simultaneity, which suggests that the notion is not frame-relative. This seems much more implausible, and harder to reconcile with relativity.
yossell said:
I see and agree.
I agree, but you know what philosophers are like.
Matheinste.
Matheinste.
Yes. Very well. Do you?
Not philosophers personally. I do find most philosophical disussions, as regards physics, stimulating, but some of the ideas seem to clash with reality. But then what is reality. That's another question for another day.
Matheinste.
Austin0 said:
Hi Al68
That's right, in this case the rate of Earth's clock is calculated relative to the ship's clock, both wrt to the accelerated frame of the ship.
But there is a "consequence" to the end result. Because the "end result" will vary with the relative velocity of the ship at each point along the way, which is a direct function of acceleration.
This is exactly what Einstein's 1918 resolution did. But of course the frames are not identical.
It's not an ad hoc principle that non-inertial motion isn't the same as inertial motion. The math would not identical because the coordinate position of Earth relative to the ship's frame throughout the trip isn't identical to the coordinate position of the ship relative to Earth's frame throughout the trip.
And you can't ignore the consequences of using an accelerated reference frame, such as gravitational time dilation as applied to distant clocks.
Time dilation refers to the relative tick rate of the clocks, not their accumulated elapsed time between events. It's the accumulated time between events, not the tick rate of the clocks, that is not reciprocal during inertial motion. Remember that the distance accumulated during the trip is not the same in each frame, and this factors into the accumulated time on the clocks in addition to their relative tick rates. Also note that the elapsed time between the ship leaving Earth and the ship reaching the destination would be different in each frame whether the ship accelerates or not.
I'd say it's not satisfactorily explained in many resolutions. The fact is that the ship has a clock during its acceleration, and the ship's twin experiences every increment of elapsed time on that clock. Many people correctly point out that there is no need to address that in order to obtain a correct solution. But the typical question is "how does it work from the ship POV?", not "how can we get a correct solution without analyzing the ship POV?"
Gravitational time dilation isn't "equivalent" to velocity time dilation, it's the same exact phenomenon. All of the gravitational time dilation equations are derived from the lorentz transformations.
ANy ideas ?
I'm not sure what you mean, but gravitational time dilation isn't necessarily "constant". It's only constant for certain simplified scenarios. It's not constant for this scenario, since even if the acceleration is constant, the coordinate distance of Earth's clock in the ship's frame isn't constant during the acceleration.
BTW, here's a link to an English translation of Einstein's 1918 paper: http://en.wikisource.org/wiki/Dialog_about_objections_against_the_theory_of_relativity.
Where would I read on gravitational time dilation? I have the 1960s version of Spacetime Physics. Einstein himself in Relativity doesn't really get into the nuts and boltss.
It has taken me long enough just to grasp the basics of SR, much less GR other than understanding what Einstein, Hilbert and Eddington did.
Thanks,
stevmg
AJ Bentley said:
Gentlemen, Please!
Explain.
By Einstein et al there can be no such thing as an Ansible. Basically, an Ansible literally establishes simultaneity between two events (the event itself and its observation in the Ansible.) This is not possible wrt to all frames of reference. Simultaneity "changes" (or can change) when looking at two distict events from the two different FORs.
The scenario descibed above is literally the Einstein train in which the lightning flashes are perceived as simultaneous in one FOR while in the other FOR, the lead flash occurs before the back flash. [Section IX, The Relativity of Simultaneity, Relativity, Albert Einstein.]
In this case, Bob is traveling towards Granny and sees her event to occur before Alice.
Lorentz time transformation and SR:
t' = [tex]\gamma[/tex][t - xv/c2]
Set t = 0 (for Alice,) x = whatever (call it x) for the distance between Alice and Granny in a common FOR. v is Bob's speed wrt Alice and going towrds Granny. Do the math... presto! a negative number "'No she isn't, your Granny had her kippers for tea three days ago'
Granny doesn't have to be frozen. All we have to do is "thaw" our brains to allow SR to take over.
Now, if you don't accept the state-of-the-art knowledge of SR as being "real" then that is a different story.
AJ Bentley said:
Gentlemen, Please!
Explain.
Granny has kippers every day.
Matheinste.
