Solving the two body problem in Matlab
The discussion focuses on coding an algorithm in Matlab to compute the trajectory of a two-body problem using the Euler method. Participants confirm that the original second-order differential equation can be separated into three first-order equations for each spatial component. However, they caution that the Euler method is unstable, recommending the use of the Runge-Kutta method or Verlet integration instead. The user reports issues with velocity calculations after the first iteration, suggesting that while position data appears correct, the velocity components are not, leading to errors in subsequent iterations. It is advised to convert the system to first-order equations and utilize Matlab's ode45 for better stability and accuracy.
patric44
solve the two body problem using a Matlab script ?
a = -mu/r^3
hi guys
i am trying to code an algorithm for computing the trajectory of a basic two body problem situation according to the equation
$$\ddot{r} = \frac{-\mu}{r^3} \vec{r}$$
i am trying to use the Euler method , but the problem is in converting this problem into a 3 separate equations one for each component
of ##r## .
can i separate this equation for each component of ## \ddot{r}## as
$$\ddot{x} = \frac{-\mu}{r^3} \vec{x} \quad \ddot{y} = \frac{-\mu}{r^3} \vec{y} \quad \ddot{z} = \frac{-\mu}{r^3} \vec{z} \quad $$
and solve each part using euler method separately , or i cannot do that ?
Yes you can, and should.
The usual approach is to reduce the system to a set of coupled first order differential equations, by introducing new variables corresponding to ##\dot{x}##, etc. Note that the Euler method is unstable. You should try a Runge-Kutta method.
You can also directly integrate the second-order equations using Verlet integration.
Likes patric44
i tried to that but it only works in the first iteration from my initial vector i provide , i checked every thing but for some reason the velocity resulting from each solution individually is not correct , can some one revise my code :
Matlab:
clc
clear all
x0 = [6569.944337;-1.387381];   % inital condition  [x,v_x]
y0 = [1152.258896;6.658808];   % inital condition  [y,v_y]
z0 = [390.787865;3.658486];   % inital condition  [y,v_z]
r1 = [6569.944337;1152.258896;390.787865];
R = 6.371e6;    %%meters
M = 5.972e24;  %%kg
G = 6.67e-11;   %%% some SI unit
mu = G*M;
dt  = 60;   % time step
T =3*dt;    % amount of time to integrate
% the forward euler
xF(:,1) = x0; %  [.....] tow of them above each other
yF(:,1) = y0;
zF(:,1) = z0;
rn(:,1) =[xF(1,1);yF(1,1);zF(1,1)]; %% all the elements in the first array contain r1
tF(1) = 0;
for k = 1:T/dt
     A = [0 1;-mu/(norm(rn(:,k)))^3 0];
     tF(k+1) = k*dt;
     xF(:,k+1) = (eye(2)+A*dt)*xF(:,k);
     yF(:,k+1) = (eye(2)+A*dt)*yF(:,k);
     zF(:,k+1) = (eye(2)+A*dt)*zF(:,k);
rn(:,k+1) = [xF(1,k+1);yF(1,k+1);zF(1,k+1)];
end
rn
that is a huge time step... and the total integration time is only 3 time steps. I'd start there. Euler is very unstable wrt time step size
Likes patric44
i have no choice here i have an initial data set came from a simulation , the interval between the data is 60 sec
, i know it seems the main issue but i guess something else causes an error in the velocitiy components 🤔
The program seems that the velocity components calculated is way way off but the positions seems to be correct, so when the second loop starts it begins with the vectors containing the incorrect velocity and every thing goes wrong, can anyone help
The integration time step does not have to correspond to the output time step.
As you are using Matlab, you should really convert the system to first-order equations and use ode45 to integrate.
  • · Replies 24 ·
  • · Replies 17 ·
