Solving Two-Block Friction Problem - Force Calculation
The discussion revolves around calculating the forces between two blocks with a shared coefficient of friction under an applied force. The net acceleration of the system is determined to be 1.410 m/s². The force exerted by the 80 kg block on the 210 kg block is calculated to be 409 N, with the opposing force being equal due to Newton's third law. A common misconception about differing friction forces due to mass differences is clarified, emphasizing that the forces exerted by the blocks on each other remain equal. The conclusion reinforces the principle of action and reaction in physics.
TexasCow
http://img219.imageshack.us/img219/4953/physicsyo5.png
That's the best that I can do. As you can see, the two blocks are touching and both share the same coefficient of friction. There's an applied force on the first, lighter block. I've done all of my homework but just can't figure out:
-Force exerted by the 80kg block on the 210kg block
-Force exerted by the 210kg block on the 80kg block
-I have already determined the net acceleration, which I believe is 1.410m/s^2
F=ma
Ff=(Fn)(mu)
F=ma
Fnet=(m)(anet)
Fnet=(210kg)(1.410)=296.1N
F=Fa-Fnet
F=750-296.1=453.9N I believe this is the answer for the "Force of the 80kg block on the 210kg block".
However, I don't know how to calculate the other. Any help is appreciated!
Okay well F - Ff = m*a.
F = 750 N
Ff = 341
750 - 341 = 290 * a
a = 1.41 m/s
Then the force of each blocking pushing on each other is equal because of Newton's 3rd law. So the Force on the first block minus the force of friction is equal to the force of one block on another.
F - Ff = 409 N
Or you could do Fnet = m * a and plug in 290 kg times 1.41 in which you will get 409 N.
Therefore,
A) 409 N
B) -409 N
Thanks!
Quick question though. Since the masses are different and thus having different friciton forces, wouldn't the forces exerted by one block on the other be different?
Nope. If you push against the wall with a force of 50 Newtons, the wall pushes back on you with a force of 50 Newtons. This is how a scale works.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
