Solving Two Charged Plates Homework: Magnetism, Frequency & Charge Density
  • Thread starter Thread starter scoutdjp2012
    Charged Plates
The discussion revolves around a physics problem involving a proton moving between two charged plates, where the electric field is specified, and the magnetic field is to be determined. The subject area includes magnetism, electric fields, and charge density, with a focus on the interactions between these forces as they affect the proton's motion.
  • Participants discuss the calculation of the magnetic field and the implications of the Right Hand Rule for determining the direction of the proton's motion. Questions arise regarding the definitions of variables in the equations used, particularly the meaning of 'r' in the context of the formulas provided. There is also a focus on understanding the relationship between the forces acting on the proton and how they relate to its trajectory.
The discussion is ongoing, with some participants providing hints and prompting others to clarify their understanding of the relevant equations. There is recognition of the need to correctly interpret the variables involved and the conditions for the proton's motion. Multiple interpretations of the problem are being explored, particularly concerning the application of formulas and the physical meanings of the variables.
Participants note potential misunderstandings regarding the relevance of certain equations and the definitions of variables. There is an emphasis on ensuring that the correct relationships between forces are established for the proton to remain undeflected.
scoutdjp2012
A proton is shot at 5x10^6 m/s between two charged plates. When E between the plates is 15,000 N/C, the proton is undeflected by the field by a magnetic Field B into the paper
1) What is the magnitude of the magnetic field?
2) if the proton now enters a region with only the magnetic field, what direction and with what radius will it move?
3) How long will it take to make a half circle?
4) What would the period and frequency of the proton be?
5) find the charge density for the parallel plate
B = mv/qr
E=KQ/r^2
I figured out the magnitude of the magnetic field as 20.84 using B = mv/qr
for number 2, using the Right Hand Rule, the force is pointing upwards, and using E = KQ/r^2 i found the radius of the proton.
Can someone help with the last three?
Thread moved from Calculus section. For problems 3, 4, and 5, please show some effort. For problem 3, do you know how fast the proton is moving? In problem 2, you didn't find the radius of the proton -- you found the radius of the arc along which it is moving. Do these give you a hint?
See if you reason out at least a start for the three you're asking about.
B = mv/qr
E=KQ/r^2
What are the meanings of the letters m, v, q, r Q, k in the formulas?
Is E=KQ/r^ relevant here? The electric field is given between two charged plates.
How did you figure out the strength of the magnetic field with B = mv/qr? What is r in that formula? Was it given? What is the unit of B?
Again, what is r in the formula E = KQ/r^2? Is that formula relevant here?
As others here have noted, you don't seem to fully understand the meaning of ##r## in Coulomb's formula ##E = KQ / r^2##. The ##r## in this problem is something else. (Hint: Think centripetal acceleration.)
You've got another incorrect formula in part (1). Think simpler--the electric field exerts a force on the proton; so does the magnetic field. These forces are given by the definition of the electric field and the Lorentz force law, respectively. For the proton to be "undeflected," they must cancel out--so set them equal to each other and see what happens.
Once you find the proton trajectory's radius, parts 3 and 4 become trivial, as long as you remember the relationship between the period and frequency. Part (5) is just an application of a formula you don't seem to have remembered--the formula for the electric field in the interior of a parallel-plate capacitor. You can either look it up or derive it using Gauss's Law.
  • · Replies 26 ·
  • · Replies 58 ·
