Solving Vector Equations w/ A+B+C = 0
  • Thread starter Thread starter nokitman
    Vector
16 replies · 3K views
nokitman
Vector A points in the negative x direction. Vector B points at an angle of 30 degrees above the positive x axis. Vector C has a magnitude of 15.0 m and points in a direction 40 degrees below the positive x axis. Given that vectors A + B + C = 0, find the magnitude of vector A and vector B
Sin = opp/hyp
For vector C, I found the x direction to be 11.49 m and the y direction to be -9.64 m.
Other than that I have no idea where to begin.
thanks,
Good. So we know C=11.49i-9.647j
so let's put A=ai+bj. It says A points in the negative x direction, so what should A really be ? (i.e. should the 'a' be +a or -a and what should 'b' equal to?)
So B acts at an angle of 30 degrees to the x-axis. If the magnitude of B is |B| then B=|B|(ci+dj)
so find A+B+C, grouping together the i and j terms.
like this ?
C = 11.49i - 9.647j
A = ai - bj
B = |B| (ci + dj)
_____________________ +
= (11.49 + a + |B|c)i - (9.647 - b + |C|d)j
Is that right? :confused:
nokitman said:
like this ?
C = 11.49i - 9.647j
A = ai - bj
B = |B| (ci + dj)
Sorry I made a mistake, let's take out the |B| and just have B=ci+dj
You should get A+B+C = (11.49+a+c)i + (-9.647-b+d)j
once again now, if A=ai+bj is in the negative x direction, what is b equal to? And what sign should the a really have ?
the "a" should be negative so A=-ai+bj, should the b also be negative?
right the 'a' should really be '-a'. So if the j component is the vertical component, and you know A is purely horizontal, what value should 'b' equal to?
b should be 0 in the A vector
C = 11.49i - 9.647j
A = -ai
B = ci + dj
_________________ +
= (11.49 -a + c)i + (-9.647 + d)j = 0
Is that correct? what's the next step?
Thank you
C = 11.49i - 9.647j
A = -ai
B = ci + dj
_________________ +
Thank you
yes this correct. So if it is equal to zero, that means both the i and j components are zero, so what is d?
d= oi + oj
how does it get me to find the magnitude of A and B vectors?
nokitman said:
d= oi + oj
no no
we have A+B+C = = (11.49 -a + c)i + (-9.647 + d)j = 0 =0i+0j.
so when you equate components, what is d equal to?
nokitman said:
d is zero?
no if (-9.647 + d) =0 what is d? Do you know why (-9.647 + d) equal 0?
nokitman said:
sorry d is 9.647
ok good. Now we know for a vector say R of magnitude |R|, acting at an angle θ to the x-axis can be represented as R= |R|cosθi+|R|sinθj
Can you now make a similar comparison to the vector B with magnitude |B|? Are you able to see how 'd' relates to |B| at the given angle?
vector B = |B|cos30i + |B|sin30j ?
is 9.647 the y component of vector B?
yes, so now if d=|B|sin30 -> 9.647=|B|sinn30 what is |B| equal to?
When you get |B|, can you find what 'c' is equal to ?
