Solving x in DE: sin(x)=t+c, No arcsin
  • Context: MHB
  • Thread starter Thread starter simo1
The discussion revolves around solving the differential equation \( x' = \sec(x) \) with the initial condition \( x(0) = 2 \). Participants explore the implications of the solution \( \sin(x) = t + c \) and the constraints of not using the arcsin function to express \( x \). The conversation includes considerations of initial conditions and the behavior of the secant function.
  • Some participants note that the solution \( \sin(x) = t + c \) is correct and can be derived from the differential equation.
  • There is a concern about the secant function being undefined at certain points, which may complicate the interpretation of the solution.
  • One participant suggests that avoiding the arcsin function may not be possible, indicating that it might be the only way to express \( x \).
  • Another participant mentions that while the solution can be left in the form \( \sin(x) = t + c \), it can also be expressed as \( x = \arcsin(t + c) \), which raises the issue of the restriction against using arcsin.
  • A later reply introduces a function \( \phi \) defined as \( \phi(\theta) = \sin(\theta) - \sin(2) \) and discusses its properties, including its derivative and initial condition, seeking clarification on how this function relates to the original problem.
Participants express differing views on the necessity of using the arcsin function to solve for \( x \). While some believe it is unavoidable, others explore alternative representations and interpretations of the solution. The discussion remains unresolved regarding the best approach to avoid arcsin while still addressing the initial value problem.
Participants highlight the importance of the initial condition and the behavior of the secant function, which may introduce complexities in the solution process. The discussion also reflects uncertainty about how to express the solution without using arcsin.
simo1
I was given an DE equa x'=sec(x) : x(0)
I then solved it to
sin(x)= t + c(c0nstant)
but then I can't solve for x cause they say we shouldn't use arcsin. what can I do
Re: solving for x
I then solved it to
(i) What is the initial condition? x(0) = ??
(ii) There may be some trickery in this question. The sec function is undefined (or "infinite") at some points, so the equation needs to be interpreted cautiously at any such point.
Re: solving for x
it it x(0)=2
Re: solving for x
simo said:
it it x(0)=2
In that case I don't see any way of avoiding an inverse sin function.
Re: solving for x
are you saying the only way possible to solve this is by the arcsin
Re: solving for x
You solution $\sin x = t +c$ is correct. You can find the constant from the initial condition. Then you can either leave the solution in that form, or you can write it as $x = \arcsin(t+c)$. There is no way of writing the arcsin function in terms of other functions.
Re: solving for x
there is a part that says I need a function that is a slotion of the IVP
now I looked at t and it is uniquely defined for each x in this this
sinx = t + sin(2)
Now they saying a function say ϕ:ϕ(Ɵ)= sin(Ɵ) - sin(2)
which is a solution of the IVP such that
ϕ' (Ɵ) = cos(Ɵ) with ϕ(2) = 0
may I get an explanation how one gets to this equation
