Solving y'=\frac{(1+y)^2} {x(y+1)-x^2}: An Alternative Approach
  • Thread starter Thread starter estro
    Approach
The discussion revolves around solving the differential equation y'=\frac{(1+y)^2} {x(y+1)-x^2}. Participants explore various approaches to find solutions and question the validity of certain transformations and assumptions regarding the behavior of the solution.
  • Participants discuss transforming the equation into a Bernoulli ODE and consider substitutions to simplify the problem. There are questions about the legitimacy of the proposed solutions and whether certain assumptions about the signs of derivatives can be made.
Several participants have offered alternative perspectives on the transformations used, and there is ongoing questioning about the correctness of the derived equations. The discussion is active, with attempts to clarify the implications of certain assumptions and the behavior of the solutions in different domains.
There are mentions of potential constraints regarding the positivity or negativity of y' in certain domains, as well as the implications of these assumptions on the solutions being explored.
estro
I want to solve:
What I tried:
I have no basis to think that y' is positive or negative in some domain, but if I do, I can write:
x'(y)=\frac {x(y+1)-x^2}{(1+y)^2}=\frac{x}{(1+y)} +\frac{x^2}{(1+y)^2}
and then I can substitute z=\frac{x}{(1+y)}
And I get the following ODE: (y+1)\frac{dz}{dy}+z=z-z^2.
So the solution is \frac{1}{z}=\frac{(y+1)}{x}=\ln|y+1|+C.
Then I can mark all this as "draft" and write: Let's notice that if F(x,y)=\frac{(y+1)}{x}-\ln|y+1|=C is a potential, so this is indeed the solution.
Is this solution legit?
How can I solve this problem alternatively?
Thanks!
You might want to check that. I get something a little simpler.
Sorry, I don't follow your logic there. Did you check that your solution satisfies the original equation?
Try substituting z = (y+1)/x straight off.
This is what I've got: attached pdf document.
Can you help me to spot what I did wrong?
Hmm I only looked at this for a moment, but it looks like a POSSIBLE candidate for the method of successive approximations.
estro said:
I want to solve:
What I tried:
This is a Bernoulli ODE with n = 2, with respect to x(y) and is transformed to a linear ODE with the substitution:
<br /> z = x^{1 - n} = x^{-1}<br />
The derivative is:
<br /> x&#039; = -x^{-2} \, x&#039;<br />
So, multiply the equation by (-x^{-2}), and see what you get.
The derivative is:
Thanks!
But, can I assume that y' is positive or negative in some domain?
How can I explain this?
x&#039; and y&#039; have the same sign.
I understand this. but how I can understand that any of one of the tho preserve sign in any domain?
Ok, so:
<br /> y&#039; = \frac{(1 + y)^2}{x (y + 1) - x^2} = \frac{(1 + y)^2}{x (y + 1 - x)}<br />
The sign of y&#039; is the same as the sign of x (y + 1 - x). You may draw the regions in the x-y plane where this is positive, negative, or zero. When it is zero, y&#039; diverges, but x&#039; = 0 (unless y = -1).
When you find the general solution, try and see if any particular solution crosses from one region to another.
Thank you very much!
