Some of my Winter Break physics problems
The discussion revolves around problems related to electric potential and electric fields, specifically involving point charges and a uniformly charged metal sphere. The original poster presents two physics problems assigned over winter break, seeking assistance with calculations involving electric potential and work done by electric fields.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the potential difference between points A and B, and how to calculate work done using the potential difference and charge. There are attempts to clarify the integration process for calculating work and the use of Gauss's law to find electric fields. Questions arise regarding the setup of distances and the application of equations.
Some participants provide guidance on using equations for electric potential and work, while others express confusion about the integration process and the application of Gauss's law. There is a mix of attempts to clarify concepts and calculations, with no clear consensus on the second problem yet.
The original poster indicates a lack of understanding regarding the integration needed for the second problem and expresses uncertainty about applying the relevant equations. There are references to specific distances and potential values that are under discussion.
totalmajor
[SOLVED] Some of my Winter Break physics problems
Hey guys, I'm new to this site, and as the way things are going with my physics class, this won't be my last request for help lol.
Well anyway, our teacher assigned us a few problems to do over break, and since I have a week left I decided to start doing them now..
The first problem looks like this:
Two point charges q1 = +2.20 nC and q2 = -6.50 nC are 0.100 m apart. Point A is midway between them and point B is 0.080 m from q1 and 0.060 m from q2 (Fig. 23.29). Take the electric potential to be zero at infinity.
(a) Find the potential at point A. **right**
(b) Find the potential at point B. **right**
(c) Find the work done by the electric field on a charge of 2.50 nC that travels from point B to point A.
I got A and B right, but C I've got no clue how to do.. I was going over my notes and saw some sort of integration stuff, but I can't figure out how to do any of that!
A total electric charge of 2.10 nC is distributed uniformly over the surface of a metal sphere with a radius of 36.0 cm. If the potential is zero at a point at infinity, find the value of the potential at the following distances from the center of the sphere.
(a) 48.0 cm
(b) 36.0 cm
(c) 12.0 cm
This one, I've got NO CLUE how to do at all...
I know the basic equations v=U/q but what do you plug in where!?
I guess I'll just leave it at these two for now until I get these right...
Thanks a lot!
Peter
What is the potential difference between B and A? What does the product of the potential difference and the charge give you?
For first part use equation for points (A and B) V = Kq/r for Work = qV = U, so it will be q(Vb-Va)
For part two use Intergral of E dot dr should be equation in book
I don't know, do I do it the same way as i did for A and B?
How do you figure out the distance though?
Here's basically what I have on paper..
http://irollerblade.org/physics/phys.jpg
Well if you have the potential at A,[itex]V_A[/itex], and the potential at B,[itex]V_B[/itex]. What is the potential difference? when you get that all you need to do is multiply by the charge that you moving from B to A
Okay thanks a lot!
First problem is completely finished
But the second one I don't get..
I looked up the equation you were talking about
W(ab) = Integral of E(dot) dr
There's an example with something to do with infinity and r/2, for the first one it's zero, and the second one is r/2 so do i divide the radius by 2 and then multiply it by the what?
I'm sorry..
Use gauss law to find E, the "r/2 and infinity" are just different limits of integration.
Yeah I'm sorry but I don't get it..
E would be Q/4*pi*E(naught)
right?
But what do you multiply that by??
Your E is wrong missing R squared.
"But what do you multiply that by??" how do you simplify a dot product? (hint: you can choose any path for dr, and you know how the vector field E looks like)
oh woops yeah I did forget R squared
so for vector path dr I'd put .48m because that's what they're looking for?
So .48Q/4piEnaughtRsquared?
Sorry, I'm just terrible at gaussian surfaces.. I never really understood how to do them
For this case dr it is just the integration operator. And since you want from V(0m) - V(.48m) = integral of E dot dr, your limits would be 0 -> .48m (you might have to split it into two integrals, since you cannot have 1/0)
i got it!
thanks a lot!
9K
  • · Replies 20 ·
