Some tricky exponentioal equations
  • Thread starter Thread starter xortan
4 replies · 2K views
xortan
e^(4x-5)=9e^(x+5)
log rules
I have tried this one a few times using slightly different methods and getting 2 answers and neither of them seem to be working when i plug them back into the equation.
Here is my first method...
1. Divide out the e^(x+5) so i get e^(4x-5)/e^(x+5) = 9
2. Take the natural log of everything so i end up with
(4x-5)lne/(x+5)lne = ln 9
3. After doing the algebra i got the answer to be 8.87 (rounded to 3 sig figs), but it wasnt checking out when i plugged it back into the equation
Here is my second method...
1. I just started going crazy with the natural logs getting
(4x-5)lne - (x+5) ln 9e
The ln9e don't quite sit right with me tho, however after doing the algebra i get x=-10, this doesn't seem to check out either...please help!
(3^7x)(27^x)=9
logs
Alright well since i know that they are all powers of 3 i changed the bases so the equation became
(3^7x)((3^3)x)=3^2
Then i just looked at the exponents and ended up with
21x^2 = 2
Did the algebra and this one isn't working in the orignal equation either >.<
xortan said:
e^(4x-5)=9e^(x+5)
log rules
This part is incorrect. The natural log doesn't quite work like that. Before you take natural logs, you'll want to simplify:
[tex] \frac{e^{4x-5}}{e^{x+5}} = e^{(4x - 5) - (x + 5)} = e^{3x - 10}[/tex]
Then you have e^(3x-10) = 9, and you can take the ln of both sides there.
(3^7x)(27^x)=9
logs
(3^7x)((3^3)x)=3^2
21x^2 = 2
Seems a little fishy here. You changed everything to base 3 right, but then you should get:
[tex] 3^{7x} \cdot (3^3)^x = 3^{7x} \cdot 3^{3x} = 3^{7x + 3x} = 3^{10x}[/tex]
So then 3^(10x) = 3^2, which means x = ...
Thank you so much it just clicked..
I LOVE this site, got my finals right around the corner and this was only problem i was having with exponentioals, thank you i should be able to complete the rest of my assignment with ease :D
aye, no problem.. good luck!
Just be sure to remove that "o" from "exponentioal" if you want full marks :wink:
