Enharmonics
- Messages
- 29
- Reaction score
- 2
I'm trying to write Strings to files in Java.
Basically, I'm supposed to read from a file containing text (assumed to be strings). For each line of text,
if the String has the format word1 word2 (that is, if it's two words), I have to write it to one file (a list of names), whereas if it doesn't have that format, I have to write it to another file, which is supposed to be called System.out (with the extension .txt)
I made a file and wrote some stuff on it to test my code with. Here's what it contains:
Prima Secunda
First Second
Un Deux
Uno Dos
Ein Zwei
This line is not valid
Neither \.! is this |||; one
Uno Due
This should not be written
I've got the list of names part working just fine. The names get written to the output file as they should:
P.Secunda
F.Second
U.Deux
U.Dos
E.Zwei
U.Due
but when writing to the System.out file, only this line gets written:
So the lines formatted like regular sentences ("This should not be written", etc) get skipped. I'm not sure why this is. Here's some excerpts from my code:
Does this maybe have something to do with my closing the output stream after using it in the try-catch block?
Prima Secunda
First Second
Un Deux
Uno Dos
Ein Zwei
Uno Due
P.Secunda
F.Second
U.Deux
U.Dos
E.Zwei
U.Due
Java:
public static void processData(BufferedReader inputFile, PrintWriter outputFile)
// A modified version of
// the algorithm shown
// on the class page.
String inputLine = null;
try
// Do/while loop that processes
// each line taken from the file.
// First it checks whether the
// line has the format word1 word2
while ((inputLine = inputFile.readLine()) != null)
// Splits the line into tokens,
// taking the delimiter to be
// anything that is not an
// upper or lowercase letter
// or the tab character (\t)
// in groups of at least one
// (using the regex [^a-zA-Z]+)
String[] tokens = inputLine.split("[^a-zA-Z\t]+");
// REMOVE LINES 215-216
System.out.println("inputLine is: " + inputLine);
System.out.println("The length of tokens is: " + tokens.length);
// If the line has the format
// word1 word2, the outputWriter
// method is invoked to process
// the words and write them to
// the output file
if (tokens.length == 2){
outputWriter(tokens, outputFile);
// Otherwise, the systemWriter
// method is invoked to write
// the line to the System.out file
// REMOVE LINE 234
else{
System.out.println("ENTERED SYSTEMWRITER TREE AT: " + inputLine);
systemWriter(tokens);
// Catch block that prints
// the name of the exception
// and the line it occurred on
// to the console
catch (IOException ex)
System.out.println(ex + " on line: "
+ inputLine);
// Auxiliary method that writes
// lines that do not conform
// to the format specified
// by the instructions to the
// System.out file
public static void systemWriter(String[] tokens)
// REMOVE LINES 297-303
System.out.println("Tokens contains: ");
for (String currentToken : tokens)
System.out.println(currentToken + " ");
File systemOutput = new File("System.out.txt");
// Here we create a PrintWriter
// to write to the System.out
// file. Note that this does NOT
// create the file itself, only
// an object that manipulates it
// Therefore there is no problem
// in repeatedly creating the
// systemFile instance each time this
try
PrintWriter systemFile = new PrintWriter(new FileWriter(systemOutput));
// As requested by instructions,
// this message let's the user
// know that the line in question
// does not have the format word1
// word2
systemFile.println("The following line does not have the"
+ " format word1 word2:");
for (String currentWord : tokens)
systemFile.print(currentWord + " ");
// Close the System.out file after modifying it
systemFile.close();
System.out.println("Failed to create System.out file!");
