Homework Helper
- 8,948
- 687
Links to prior threads
https://www.physicsforums.com/threads/sorting-revisited-again.728448
https://www.physicsforums.com/threads/sorting-revisited.218369
https://www.physicsforums.com/threads/efficient-sorting.181589
https://www.physicsforums.com/threads/merge-sort-using-linked-indexes.786487
Bottom up merge sort for linked list, using a small (26 to 32 ) array of pointers to nodes, where array[ i ] points to a list of size 2 to the power i (or null).
C:
typedef struct NODE_{
struct NODE_ * next;
int data;
}NODE;
/* prototype */
NODE * MergeLists(NODE *pSrc1, NODE *pSrc2);
/* sort list using array of pointers to first nodes of list */
/* aList[i] = NULL or ptr to list with 2 to the power i nodes */
#define NUMLISTS 32 /* size of array */
NODE * SortList(NODE *pList)
NODE * aList[NUMLISTS]; /* array of lists */
NODE * pNode;
NODE * pNext;
int i;
if(pList == NULL) /* check for empty list */
return NULL;
for(i = 0; i < NUMLISTS; i++) /* zero array */
aList[i] = NULL;
pNode = pList; /* merge nodes into array */
while(pNode != NULL){
pNext = pNode->next;
pNode->next = NULL;
for(i = 0; (i < NUMLISTS) && (aList[i] != NULL); i++){
pNode = MergeLists(aList[i], pNode);
aList[i] = NULL;
if(i == NUMLISTS) /* don't go past end of array */
i--;
aList[i] = pNode;
pNode = pNext;
pNode = NULL; /* merge array into one list */
return pNode;
/* mergelists - compare uses src2 < src1 */
/* instead of src1 <= src2 to be similar to C++ STL */
NODE *pDst = NULL; /* destination head ptr */
NODE **ppDst = &pDst; /* ptr to head or prev->next */
if(pSrc1 == NULL)
return pSrc2;
if(pSrc2 == NULL)
return pSrc1;
while(1){
if(pSrc2->data < pSrc1->data){ /* if src2 < src1 */
*ppDst = pSrc2;
pSrc2 = *(ppDst = &(pSrc2->next));
if(pSrc2 == NULL){
*ppDst = pSrc1;
break;
} else { /* src1 <= src2 */
*ppDst = pSrc1;
pSrc1 = *(ppDst = &(pSrc1->next));
if(pSrc1 == NULL){
*ppDst = pSrc2;
break;
return pDst;
