Sound Intensity Level of Three Objects
14 replies · 5K views
songoku
Given that:
TI1 + TI2 = 70 dB
TI2 + TI3 = 80 dB
Find TI1 + TI2 + TI3
TI = 10 log (I/Io)
From that two equations, I got:
I1.I2 = 10-17
I2.I3 = 10-16
I1.I22.I3 = 10-33
Then stuck...
"1. Homework Statement
Given that:
TI1 + TI2 = 70 dB
TI2 + TI3 = 80 dB
Find TI1 + TI2 + TI3"
Don't you have three unknowns and only two equations, your stuck?
Given that:
TI1 + TI2 = 70 dB
TI2 + TI3 = 80 dB
Sorry I don't really get what you mean. But anyway, how to solve for three unknowns with only two equations?
songoku said:
bump
I think I'm mistaken above. See page 5 of the following link for examples of adding sounds. If you are still having trouble I will give it a second shot.
http://faculty.delhi.edu/hultendc/AECT350-Lecture%202-REV.pdf
Let us discuss the question in the your link first, page 5.
The answer for example 1 is 100.41 dB. I tried other working and got different result. Here it is:
L1 = sound intensity level = 100 dB and L2 = 90 dB
L = 10 log (I/Io), where Io = 10-12
L1 = 100
10 log (I1/Io) = 100
log (I1/10-12) = 10
I1/10-12 = 1010
I1 = 10-2 W/m2
With the same working, I2 = 10-3 W/m2
The question is asking about Ltotal = L1 + L2, so:
Ltotal = L1 + L2
= 10 log (I1/Io) + 10 log (I2/Io)
= 10 I1 - 10 log 10-12 + 10 log I2 - 10 log 10-12
= 10 log (I1.I2) + 240
= 10 log 10-5 + 240
= 190 dB
Where is my mistake?
L1 = 100
log (I1/10-12) = 10
I1/10-12 = 1010
I1 = 10-2 W/m2
The loudness is not additive. Add the powers, and calculate the resultant loudness from resultant power.
I=I1+I2= (0.01+0.001) W/m2
L=10 log(0.011/10-12))
ehild
ehild
Oh ok. But how to solve my question? I don't think we can find the sound intensity or power
songoku said:
Given that:
TI1 + TI2 = 70 dB
TI2 + TI3 = 80 dB
ehild said:
I do not understand the original problem. What are Tl1, Tl2, Tl3? Is the original question the same what you wrote?
ehild
Yes, that's all the problem given, verbatim.
TI there is sound intensity, exactly the same as L, expressed in dB and has formula:
TI = L = 10 log (I/Io), where Io = 1012
Sorry, I still do not understand what was meant on the '+'. The loudness of two sounds is not the sum of the loudnesses. Was it said that the resultant loudness of two sounds is 70 db or the sum of loudnesses is 70 db? Anyway, there are three unknowns and two equation, you can not get numerical solution. Ask your teacher what he/she meant.
ehild
ehild
Ok I will. Anyway, what is the difference between "the resultant loudness of two sounds is 70" and "the sum of loudnesses is 70 db"?
You saw it in the previous problem, when the resultant of the 100 db and 90 db sources was the question. You added the intensities (power/unit area) and calculated the loudness (dB) from it, instead of adding the decibel values.
I wonder if your teacher meant that the loudness of the resultant intensity of two sound sources is 70 dB or really the sum of two dB values is 70 as you wrote in the original post.
ehild
ehild
So can I say that "the sum of loudnesses is 70 db" does not exist and "the resultant loudness of two sounds is 70" is the correct term?
If the question asks about "the resultant loudness of the three sounds", can we solve it?
No, with two equation for three unknows.
ehild
ehild
OK thanks for the help :smile:
