Saitama
- 4,244
- 93
Two identical loudspeakers are located at points A & B, 2m apart. The loudspeakers are driven by the same amplifier (coherent and are in the same phase). A small detector is moved out from point B along a line perpendicular to the line connecting A & B. Taking speed of sound in air as 332 m/s, find the frequency below which there will be no position along the line BC at which destructive interference occurs.
I am not sure how would I approach this problem. I started with calculating the path difference when the detector is at a distance x from its initial position,
[tex]\Delta x=\sqrt{4+x^2}-x[/tex]
For destructive interference,
[tex]\sqrt{4+x^2}-x=\left(n+\frac{1}{2} \right)\lambda[/tex]
where ##\lambda## is the wavelength of the wave.
I don't know how should I proceed from here.
Any help is appreciated. Thanks!
