What Is the Correct Source Voltage Amplitude for Desired Power in an AC Circuit?
The discussion focuses on calculating the correct source voltage amplitude for an AC circuit with a resistor and capacitor, aiming for an average power of 529 watts. The user initially calculated the reactance and impedance but confused apparent power with active power. The correct approach involves using the power factor and the relationship between average power, voltage, and impedance. It was clarified that the amplitude of the voltage is needed, not the RMS value, leading to the final answer of approximately 1166 volts. The conversation emphasizes the distinction between active and reactive power in AC circuits.
superslow991
An ac series circuit consists of a voltage source of frequency f = 60 Hz and voltage amplitude V, a resistor of resistance R = 163 ohms and a capacitor of capacitance C = 6.2x10^-6 F. What must the source voltage amplitude V be for the average electrical power consumed in the resistor to be 529 watts? There is no inductance in the circuit.
XC = 1 / (2 × π × f × C)
Z = √(R2 + X2)
P=V^2/R
So first i calculated the reactance and got 1/(2*π*60*6.2*10^-6)= 428.05
next impedance-√(163^2 + 428.05^2)= 458.0
last i used the power equation - 529=v^2/458.0 and solved for v and got 492.2 V
My only question is I've checked different answers online and saw some as V = 1165 or 1166
just wondering if i did the math right on this question. Any help is appreciated.
You are asked to find the active power in the circuit, which is dissipated in the resistor only.
You have calculated the apparent power, which is the sum of active and reactive powers.
What is the power factor of this circuit? How will you find the active power with the help of power factor?
Hmm isn't the power factor R/Z? Also after reading the question more wouldn't I used the average power equation?
Yes.
So what is the expression for active power now that you know the apparent power and the power factor?
cnh1995 said:
Yes.
Have no clue
P=Z*R? That wouldn't make sense I think
superslow991 said:
Only the reactive **apparent** power Q **S**=IV.
superslow991 said:
Also are you saying when I solved for the impedance that was solving for the apparent power?
Yes.
superslow991 said:
I'm not seeing anything related to the active power
There is a formula in that article which you can directly use to solve this problem. Read 'instantaneous power in ac circuits' again.
That formula describes the relation among active power P, voltage V, impedance Z and power factor cosθ.
cnh1995 said:
Yes.
P=V^2/Z x cos(theta)?
Right.
cnh1995 said:
Right.
So I tried 529=v^2/458 * 163/458 but I don't think that's right am I missing something?
Why?
cnh1995 said:
Why?
Idk maybe cause some of the answers I saw online but I'll just work with the answer you provided em. Thanks a lot
The power is average power, calculated with the rms value of the AC voltage. P=Vrms2R/Z2. Vrms=amplitude/√2. You got the rms voltage of the source, while the problem asked the amplitude of the generator voltage.
Likes superslow991
They are asking for the amplitude of the voltage. You are calculating the rms voltage. As ehild said, multiply it by 1.4142 and verify your answer with the online one.
Likes superslow991
Yea got the answer that i saw online, 1166.
Thanks for the help
So to recap first i calculated for the reactance. Then i calculated for the impedence or the apparent power. Then i calculated for the rms of the voltage or the power dissipated through the impedance? Then i solved for the amplitude of the voltage using the equation v(rms)=amplitude/√2 and solved for amplitude
Voltage does not dissipate. Active power dissipates in the resistance only and not in the reactance.
hmm ok so what exactly could you call the equation P=V^2/Z x cos(theta)? Apparent power dissipated through resistance? but what about the impedance?
No.
Apparent power has two components: Active power and reactive power. Active power is dissipated in the resistive elements only.
Reactive power is associated with the reactive elements (inductance and capacitance). It oscillates between the source and the load.
Likes superslow991
Power is dissipated (transforms to heat) on the resistors only. The equivalent complex impedance seen by the source has a real and an imaginary part:: Z=R+iX. The magnitude of the impedance is ##Z=\sqrt{R^2+X^2}##. R=Zcos(theta), X=Zsin(theta), and the magnitude of the current is I=U/Z, where U is the voltage of the source. When calculating power, we use the rms value of both the voltage and current.
The power dissipated in the circuit is that dissipated on its equivalent resistance: the square of the rms current, multiplied by R:
##P=I^2 R=\left(\frac{U}{Z}\right)^2 R##. As R/Z=cos(θ), you can write ##P=\frac{U^2}{Z}\cos(\theta)##.
Likes superslow991
