Space-time continuity as an assumption in quantum theory
The discussion revolves around the relationship between spacetime continuity and the conflict between relativity and quantum theory. Participants explore the implications of assuming spacetime is continuous within quantum theory and question whether this assumption leads to redundancy in the theory, especially in light of relativity's treatment of spacetime. The conversation touches on theoretical implications, potential models like Loop Quantum Gravity, and the nature of mass and energy in relation to spacetime structure.
  • Some participants argue that quantum theory is redundant because it assumes spacetime is continuous, which is derived from relativity, leading to a perceived conflict.
  • Others question the validity of this conflict, suggesting that there is no obvious incompatibility between relativity and quantum mechanics, and that the understanding of quantizing general relativity is incomplete rather than conflicting.
  • A participant proposes the idea that if spacetime is not continuous, then mass and energy cannot be discrete, prompting further inquiry into the relationship between spacetime continuity and the discreteness of mass.
  • Some participants express interest in Loop Quantum Gravity as a potential framework to explore these issues, seeking resources for further learning.
  • There is a suggestion that both theories may be partially correct and could be replaced by a broader theory that encompasses their limitations.
Participants express multiple competing views regarding the relationship between relativity and quantum theory, with no consensus on whether there is a fundamental conflict or if both theories can coexist without redundancy. The discussion remains unresolved with differing opinions on the implications of spacetime continuity.
Limitations include the dependence on definitions of continuity and discreteness, as well as the unresolved nature of how to properly quantize general relativity. The discussion also highlights the need for a more complete theory beyond the current understanding of quantum gravity.
Readers interested in the foundations of quantum theory, the implications of spacetime structure, and the interplay between relativity and quantum mechanics may find this discussion relevant.
vivekfw66
There is an apparent conflict between relativity and quantum theory, in which case quantum theory must be redundant isn't it as it explicitly makes the assumption that spacetime is continuous whereas relativity in-fact derives the notion that spacetime is continuous from an experimentally observed aspect of constancy of speed of light. When a theory borrows the result of another theory as its foundation and then comes into conflict with the very theory from which it borrowed the idea,then doesn't logic tell that the lending theory is not complete or it's only partially correct and the borrowing theory is redundant. Its purely logical isn't it?
What if spacetime isn't continuous?
i like the term.
partially correct.
That's a good question. If spacetime is not continuous then mass and energy cannot be discreet.
Are we talking Loop Quantum Gravity? This is next on my list of important things to learn about before I die. Does anyone know of any decent sources?
Maybe start here: http://math.ucr.edu/home/baez/acm/ ?
Why? What does spacetime being continuous have to do with the apparent fact that mass is discretized?
1st. There is no obvious conflict between relativity and quantum mechanics. There is an incomplete understanding of how to properly quantize general relativity, but that's not the same thing as saying there is conflict between them. For instance, Quantum Field Theory is both relativistic and quantized without any obvious conflicts.
2nd. Even if there is a conflict between them, your logic doesn't seem to hold water. Quantum mechanics tenets go far beyond the assumption of continuous space time. The core of QM is the replacement of the dynamical variables with operators in some linear space (which space exactly depends on the details of the theory). You can't milk that out of relativity. there is no meaningful way in which relativity makes QM redundant
There is no conflict:
http://arxiv.org/pdf/1209.3511v1.pdf
'Effective ï¬eld theory shows that general relativity and quantum mechanics work together perfectly normally over a range of scales and curvatures, including those relevant for the world that we see around us. However, effective ï¬eld theories are only valid over some range of scales. General relativity certainly does have problematic issues at extreme scales. There are important problems which the effective ï¬eld theory does not solve because they are beyond its range of validity. However, this means that the issue of quantum gravity is not what we thought it to be. Rather than a fundamental incompatibility of quantum mechanics and gravity, we are in the more familiar situation of needing a more complete theory beyond the range of their combined applicability. The usual marriage of general relativity and quantum mechanics is ï¬ne at ordinary energies, but we now seek to uncover the modiï¬cations that must be present in more extreme conditions. This is the modern view of the problem of quantum gravity, and it represents progress over the outdated view of the past.'
Also be aware that all our theories, not just gravity, are thought to break down at the Plank scale - renormalizable or not.
Thanks
Bill
What if spacetime were in different structures connected through matter?
imo both theories are partial correct
maybe both replaced by a broader theory.
  • · Replies 31 ·
  • · Replies 36 ·
  • · Replies 28 ·
  • · Replies 75 ·
10K
