Space-time travel in String Theory
String theory (ST) maintains a relationship with space-time geometry that aligns with Einstein's equations, suggesting similar conjectures to classical space-time regarding time travel. While time is perceived to travel in one direction, the relative speed of time can vary based on different paths through space-time, as illustrated by the twin paradox. The discussion indicates that the additional spatial dimensions in string theory do not significantly alter the fundamental paradoxes associated with past time travel. Overall, the consensus is that time travel to the past remains problematic within the framework of string theory, similar to traditional 4D space-time. The complexities of time travel in ST continue to invite exploration and debate.
alvarogz
Is it allowed to travel to the past in ST?. I've always thought about paradoxes in the regular framework (4D space-time).
What about ST framework?.
I need a little guidance here.
Thank you in advance,
AGZ
Relationship between string theory and space-time geometry.
http://www.superstringtheory.com/blackh/blackh4.html
... in general - space-time geometry that gets extracted from string theory is also describable via the Einstein equations on scales much larger than the string.
This means you'd have pretty much the same conjectures as with classical space-time.
Also see:
http://www.astronomycast.com/2007/0...-multiple-dimensions-and-before-the-big-bang/
not that I'm aware of no. Time travels in one direction, but the speed at which it travels is relative.
No, the AMOUNT by which it travels it relative. The speed by which it travels is always one second per second but different paths through spacetime can start and end at the same point but have different amounts of time. Google "twin paradox" for more details.
Likes samisbored
String theory also works in space-time with one time dimension and several space dimensions. The fact that string theory has more than 3 space dimensions does not make any real difference concerning the paradoxes of time travel to the past.
"Supernovae evidence for foundational change to cosmological models" https://arxiv.org/pdf/2412.15143 The paper claims: We compare the standard homogeneous cosmological model, i.e., spatially flat ΛCDM, and the timescape cosmology which invokes backreaction of inhomogeneities. Timescape, while statistically homogeneous and isotropic, departs from average Friedmann-Lemaître-Robertson-Walker evolution, and replaces dark energy by kinetic gravitational energy and its gradients, in explaining...
  • · Replies 33 ·
  • · Replies 0 ·
High School The M paradox
  • · Replies 47 ·
  • · Replies 30 ·
  • · Replies 21 ·
