Space travel and time dilation
  • Context: High School
  • Thread starter Thread starter Stas1234
The discussion revolves around the concept of time dilation in the context of space travel, specifically addressing how fast a spaceship must travel to ensure that a pilot ages only 10 years while traveling 1000 light years between two stars. Participants explore theoretical implications, calculations, and assumptions related to relativistic physics.
  • Some participants question the understanding of time dilation, noting that "time slows down as speed increases" is an oversimplification.
  • One participant suggests using a relativity calculator to determine the necessary speed for the spaceship to achieve the desired time dilation effect.
  • Another participant provides a detailed mathematical derivation of the speed required, indicating that the spaceship would need to travel at approximately 99.995% of the speed of light to achieve a time dilation factor of 100:1.
  • Some participants discuss the implications of acceleration on the aging of the pilot, noting that if the spaceship accelerates at 1g, the passengers would age less than 14 years for the journey.
  • One participant proposes using the spacetime interval to derive the speed needed for the journey, emphasizing a geometric interpretation of the problem.
  • Another participant mentions the ultrarelativistic approximation and its relation to rapidity, providing additional mathematical insights.
Participants express varying degrees of understanding regarding time dilation and the calculations involved. There is no consensus on the best approach to solving the problem, and multiple models and methods are presented without resolution.
The discussion includes assumptions about the nature of acceleration and the effects of relativistic speeds, which may not be fully resolved. Participants also note that the calculations provided do not account for the time spent during acceleration phases.
Stas1234
Hi everyone, help me figure this out please.
There are 2 stars (A and B) 1000 light years apart.
We know that time slows down as speed increases. (Or does it? I'm not a physicist)
There is a clock on the ship, we start it at the moment of takeoff from star A.
At what speed should the spaceship move (or how should it move at all) from star A to star B so that the clock on the ship shows 10 years at the moment of arrival at star B? The pilot on the ship must age by ten years.
Is this homework?
PeroK said:
Is this homework?
No, this is my argument with a friend, we are not physicists but we like to watch videos on YouTube about physics and astronomy. From the videos it is not clear at all how time dilation works
Thread closed for Moderation...
Thread is reopened provisionally in the non-schoolwork forums for now.
Depending on which videos, they are probably not the best resource to be using. Please read through this introductory article at Wikipedia, and ask specific questions about that article if you are having trouble understanding something. Thanks.
https://en.wikipedia.org/wiki/Time_dilation
Just point them here: https://www.1728.org/reltivty.htm
It's pretty simple - maybe a little too simple - but useful, once you grok it.
You want your pilot to make a trip of 1000 light years in 10 years subjective time.
That's a dilation factor of 100:1.
So input "100" and then hit "Factor of Change" and it will tell you the fraction of c you need to travel at (it is going to be a decimal point, followed by many nines).
(The scenario gets interesting when you ask yourself what the pilot sees out his window on that 1000 light year journey. hint: He sees a large flat pancake, much closer than expected.)
"Time slows down as speed increases" is a massive oversimplification and will lead you into contradictions if you use it as a basis for thinking about relativity. However, in this case it works well enough to do calculations with as long as we use the Earth's rest frame.
The time dilation factor is ##1/\sqrt{1-v^2/c^2}##. If you want that to be 100 then you need to be travelling at about 99.995% of the speed of light. That calculation ignores acceleration time, so you'd actually have to go faster - possibly much faster depending on how long is the acceleration phase.
This is a good (very good) approximation, though not quite exact.
If the trip is made at nearly light speed then it will take almost exactly 1000 years as reckoned in the shared rest frame of the two stars. We want 10 years of subjective time, so we need approximately a hundred to one time dilation ratio.
But that means that we were not really travelling at light speed. So it will really take just a bit more than 1000 years as reckoned in the rest frame of the stars. So we need a time dilation ratio just a bit more than one hundred to one.
Which means that we pretty much have to write down an equation. Let us use ##T_\text{subjective}## to denote the time in years experienced by the pilot and ##T_\text{rest}## to denote the time in years as reckoned in the stars' rest frame. ##v## will be the speed of the craft as a fraction of the speed of light and ##d## is the distance to be covered in light years.$$10 = T_\text{subjective} = \frac{T_\text{rest}}{\gamma} = T_\text{rest} \times \sqrt{1-v^2} = \frac{d}{v} \times \sqrt{1-v^2} = \frac{1000}{v} \times \sqrt{1-v^2}$$ or $$1 = \frac{100}{v} \sqrt{1-v^2}$$We need to solve that for ##v##. It looks rather nasty. But let us try. We can square both sides:$$1 = \frac{10000}{v^2}(1-v^2)$$ and multiply by ##v^2##$$v^2 = 10000 - 10000v^2$$ $$10001 v^2 = 10000$$ $$v^2 = \frac{10000}{10001}$$ $$v = \sqrt{\frac{10000}{10001}} \approx 0.99995000375$$
This is negligibly different from the naive estimate given by both @DaveC426913 and @Ibix
In general, we have:
$$\gamma = \frac{1}{\sqrt{1 - v^2/c^2}}$$Which can be rewritten as:
$$\frac{v}{c} = \sqrt{1 - \frac {1}{\gamma^2}}$$If ##\gamma## is large, we can use the binomial expansion to get:$$\frac v c \approx 1 - \frac 1 {2\gamma^2}$$In this case, ##\gamma = 100##, so:
$$\frac v c \approx 1 - 0.5 \times 10^{-4} = 0.99995$$
This "ultrarelativistic" approximation can even be done without a binomial expansion (in case OP or other lurkers aren't familiar with that technique). Using ##\beta = v/c##:
\begin{align*}
\gamma^{-2} &= 1 - \beta^2 \\
& = 1 - \left( 1 - \left( 1 - \beta \right) \right)^{2} \\
& = 1 - \left(1 - 2 \left( 1 - \beta \right) + \left( 1 - \beta \right)^2 \right) \\
&= 2 \left( 1 - \beta \right) - \left( 1 - \beta \right)^2.
\end{align*}
Now since ##(1 - \beta)## is very small, we can neglect its square:
\gamma^{-2} \approx 2 \left( 1 - \beta \right),
and:
\beta \approx 1 - \dfrac{1}{2 \gamma^2}.
If the thing is very fast, your calculator might just round this to ##1##. In that case, write it like ##1 - \beta \approx 1/(2 \gamma^2)## so you have leading zeros.
And the ultrarelativistic approximation in terms of rapidity:
$$1 - \beta \approx \dfrac{1}{2} \textrm{sech}^2 \, \theta$$
or just as good:
$$1 - \beta \approx \textrm{sech} \, (2 \theta)$$
I’m always surprised at the time difference, (and I know this isn’t exactly the same scenario that OP described), but if the spaceship is providing just 1g of acceleration in the direction of travel for the first half of the journey and in the opposite direction for the second half (starting and ending at rest wrt Earth), then the passengers on board will age less than 14 years for a 1000 LY trip. In this scenario, the passengers have to spend 3.8-ish more years aboard the ship than they would in the OP’s scenario, but they’ll be able to board and de-board the spaceship without dying (necessarily).
In the scenario of inertial motion, there’s a straightforward formula for the required speed ##\beta##:
$$\beta=\frac{d}{\sqrt{\Delta \tau^2+d^2}}$$
This follows directly from the invariant interval. The proper time ##\Delta \tau## is related to the coordinate time and spatial distance by:
$$\Delta \tau=\sqrt{\Delta t^2-d^2}
\Rightarrow
\Delta t=\sqrt{\Delta \tau^2+d^2}$$
Substituting into ##\beta=\frac{d}{\Delta t}## gives the result.
The nice thing about this approach is that it allows for a geometric interpretation/solution. The speed is the ratio between ##AB## and ##AC##. This diagram also nicely shows the relation between ##d##, ##t## and ##\tau##.
My approach would also be with the spacetime interval. ##c^2 \Delta \tau^2=c^2 \Delta t^2-\Delta x^2##.
For this problem we set ##\tau=10##, ##x=1000##, ##c=1##, and ##t=1000/v##. Then solve for ##v##.
  • · Replies 26 ·
  • · Replies 22 ·
  • · Replies 115 ·
9K
  • · Replies 25 ·
  • · Replies 43 ·
  • · Replies 22 ·
