Mentor
- 11,192
- 4,038
aletheia said:So, today I’d put the question like this: which physical operation establishes the transition from an initially joint nonfactorizable structure to physical disconnection or to exhaustively independent local wholes?
The answer depends on the interpretation; for example, in Bohmian Mechanics, particles are separate in the classical sense.
In the formalism of Quantum Field Theory, two entangled particles are a single 'excitatIon' of the quantum field. If you observe it with the particle number operator, you get two. However, if you observe a single-particle property, you instantly break the entanglement and get two separate excitations, each of a single particle. In other words, they are an entangled pair until an interaction (observation) breaks the entanglement.
If this is still in relation to Einstein's famous EPR paper, be aware that it is way out of date today, to the point that some say it is nonsense. This is hardly surprising since QM has developed enormously since then.
I think you may benefit from reading Bell's writings:
https://faculty.washington.edu/seattle/physics441/interpretations/Bell.pdf
Thanks
Bill
