Specific Gravity: Mass 30kg & SG 3.6 in Fluid SG 1.2: True?
  • Thread starter Thread starter tsecalvink
    Gravity Specific
The discussion revolves around an object with a mass of 30kg and a specific gravity of 3.6 placed in a fluid with a specific gravity of 1.2. Participants are exploring the implications of these values on the object's acceleration and apparent weight, while neglecting viscosity.
  • Participants are attempting to calculate the apparent weight and acceleration of the object using specific gravity and buoyancy concepts. Questions arise regarding the calculations and the reasoning behind the expected answer.
Some participants have provided calculations and reasoning, while others are seeking clarification on the relationships between mass, specific gravity, and buoyant force. There is an ongoing exploration of how to express the apparent weight in terms of specific gravities and mass.
Participants are working under the assumption that the volume of the object remains constant and that gravity can be approximated. There is a noted confusion regarding the apparent weight calculations and the effective gravitational acceleration.
tsecalvink
An object with mass 30kg and specific gravity 3.6 is placed in a fluid whose specific gravity is 1.2. Neglecting viscosity, which of the following is true?
A. The acceleration of the object is (1/3)g and its apparent weight is 100N.
B. The acceleration of the object is (2/3)g and its apparent weight is 100N.
C. The acceleration of the object is (1/3)g and its apparent weight is 200N.
D. The acceleration of the object is (2/3)g and its apparent weight is 200N.
Equations I used:
g can be rounded to 10
[tex]\rho[/tex]=m/v
F=mg=[tex]\rho[/tex]Vg
I know the volume does not change. I know the answer is D but I don't know why.. When I attempted to solve it I attempted to do a proportion and I keep getting an apparent weight of 100N. Please explain why it is D.
Perhaps you could show a bit of the calculations you attempted and your reasoning behind them?
Volume remains the same so I attempted to do this:
p = m/V, so V = m/p
m1/p1 = m2/p2
30kg/3.6 = m2/1.2
m2=10kg applying w=mg I get an apparent weight of 100N
And I assume gravity is 1/3
The mass m2 that you calculated is the mass of the displaced fluid. The buoyant force will equal the weight of the displaced fluid, and this force will decrease the apparent weight of the object. So the object will have apparent weight (30kg - 10kg)*g.
You should be able to express this as a formula involving the specific gravities and mass of the object. Taking the density of water to be 1.0g/cm3, then the specific gravities will be equivalent to densities. Let ρ1 be the specific gravity of the object, ρ2 the specific gravity of the fluid. You've already found that the volume will be given by V = m1/ρ1. So the apparent weight will be:
w = V*(ρ1 - ρ2)*g
You can substitute your expression for V into this, and rearrange to find what the "effective" g is.
12K
  • · Replies 20 ·
  • · Replies 16 ·
