Specific heats for an incompressible substance
The discussion clarifies that specific heats at constant pressure and volume are identical for incompressible substances due to their inability to perform PV work. Unlike ideal gases, where heat energy is used for both increasing internal energy and doing work against external pressure, incompressible substances do not expand or compress significantly under pressure changes. Therefore, all heat energy contributes to temperature change without any energy loss to work, resulting in equal specific heats.
  • Understanding of thermodynamic principles
  • Knowledge of specific heat capacity concepts
  • Familiarity with the behavior of ideal gases
  • Basic principles of PV work in thermodynamics
  • Research the concept of specific heat capacity in different states of matter
  • Explore the thermodynamic properties of incompressible substances
  • Study the differences between ideal gases and real gases regarding specific heats
  • Learn about the implications of PV work in various thermodynamic processes
Students and professionals in physics and engineering, particularly those studying thermodynamics and material properties, will benefit from this discussion.
KOUSIK
why specific heats at constant pressure and volume are the same for an incompressible substance?
The reason that they are very different fo things like ideal gases is that with a gas at constant volume, there is no PV work possible. All of the heat going into the gas goes to increasing the energy of the gas molecules. At constant pressure, as you heat the gas, the gas will expand against that pressure -- doing PV work. Some of the heat energy that you added to the gas went out of the gas into the surroundings as work. More heat needs to be supplied to get the same change in temperature.
For incompressible materials, is this possible? Can the substance do any PV work?
thank u
  • · Replies 22 ·
