Specific volume and density problem
2 replies · 9K views · last reply
Xyius
1. A pressure vessel of volume 100 liters is filled with 1 kg of liquid water and 80 liters of steam with a specific volume of 0.02 m3/kg. Determine
a. The density of the liquid water in SI fundamental units
b. The mass of the steam in grams
c. The density and the specific volume of the system (liquid water + steam)
[tex]Specific\ Volume = \nu = \frac{1}{\rho} = \frac{V}{m}[/tex]
Basically, I am unsure about the assumptions that should be made for part A only. The vessel is 100 L and is filled with 1 kg of liquid water and 80L of steam. Is it correct of me to assume that the entire vessel is filled? So therefore.. (Since 20L = 0.02 cubic meters)
[tex]\rho_{water} = \frac{m}{V} = \frac{1kg}{0.02m^3} = 50\frac{kg}{m^3}[/tex]
Does this sound right to you guys? Part B would be solved in a similar manner using the specific volume of steam that is given, and part C I am assuming you would do something like this..
[tex]\rho_{system} = \frac{m_{water + steam}}{V_{system}}[/tex]
Yep that would be correct.
part b would just be modifying your formula to get mass.
part c, that is correct as well (your method that is)
