Spectrum of 6V 15W Tungsten Microscope Lamp
The forum discussion centers on measuring the spectrum of a 6V 15W tungsten microscope lamp using an older scanning monochromator. The user, Paul, expresses concerns about the lack of output in the 900nm range, questioning the functionality of the monochromator and the presence of potential infrared filters in the microscope setup. Other participants confirm that the spectrum appears attenuated, particularly above 790nm, and suggest testing the spectrometer with sunlight to verify its performance.
  • Understanding of tungsten lamp spectral output
  • Familiarity with scanning monochromators and diffraction gratings
  • Knowledge of infrared filtering in optical systems
  • Basic principles of color temperature and its impact on light emission
  • Investigate the spectral output of tungsten lamps at various color temperatures
  • Learn about the operation and calibration of scanning monochromators
  • Research the effects of infrared filters on optical measurements
  • Explore methods for testing spectrometers using known light sources
Optical engineers, laboratory technicians, and researchers involved in spectroscopy and light measurement will benefit from this discussion.
paul_harris77
Dear All
I am trying to measure the spectrum of an incandesant 6V 15W tungsten microscope lamp. I have a reasonably old scanning monochromator (diffraction grating based) coupled to a fibre optic cable and it has given me the spectrum below.http://dl.dropbox.com/u/15546679/silver_lamp_forum.png I think it maybe broken as I am having a hard time believing that it gives virtual no output at 900nm. Surely all standard tungsten bulbs give out significant radiation at 900nm-1000nm (NIR)? I know it depends on the temperature of the filament and hence the colour temperature, but from most graphs I have seen of tungsten bulbs (2000-3300K), they have spectrums that extend significantly into the 900nm+ NIR region. Unfortunately, I can not find the colour temperature of the bulb, but it is definitely a yellow light so probably in the region 2000-3000K.
Does anyone else think that the spectrum maybe incorrect and that the monochromator may be broken or be attenuating the spectrum significantly in the 700-900nm region?
Many thanks
Paul
It certainly looks attenuated - especially above the 790 nm mark. Have you tried pointing the spectrometer at the sun to see if those wavelengths show up? Unless it's broken, the only other thing I can think of is the possibility that your microscope has one of those infrared filters on it to keep the lamp from heating the sample as much as it otherwise would.
