Speed bump question - Newton's laws
5 replies · 4K views · last reply
feveroffate
You're driving down the road at 8 m/s and go over a speed bump. When you go over the bump, you feel lifted from your seat. Explain why.
I assumed it was because of inertia, but I'm not sure.
You weigh 700 N. If it is approximated that the speed bump is shaped like an arc of a circle, with radius of 10 m, find the magnitude of force the seats exerts on you as you go over the speed bump.
If F = mv^2/r, then would you just plug everything in directly?
The seat normally pushes upward on you with 700 N (because you push down on it with 700 N weight). While in circular motion, though, you experience a centrifugal force upward that reduces the 700 N.
So while in circular motion, you aren't pushing down on the seat with 700 N so you are lifted up?
It is unlikely you will float up off the seat - that would take a terrific speed - but the force pressing you against the springs of the seat will be reduced so the spring compression will be less and you will go up a little bit.
But would the seat still exert 700 N upward? I mean, would I just plug in the numbers into the equation for the second part?
