Speed, force, velocity, (falling object)
In summary, the conversation discusses a homework problem involving an egg being dropped from a balcony and the speed and force involved in the fall. The first question is solved using the kinematics equation v2 = v1 + a*t, with a time of 0.1 seconds and a gravitational acceleration of 9.81 m/s^2. The second question is answered by assuming the normal force and gravitational force are equal, resulting in a force of 2280N. However, it is noted that this answer may not be completely accurate without considering momentum.
Shane-O
(A) An egg (57g) is dropped from a balcony 4m high,calculate the speed with which the egg, when dropped from the first floor balcony will hit the ground. ( use Newtons laws). ( note the time taken for the egg to hit the ground is 0.1s)
(B) What force from the ground will be applied to the egg causing it to crack. The speed before the egg hits the ground will become the initial velocity before the egg stops.
i know that i am definantly wrong but the only formula i think that i know and can truly use is V=S/T and maybe F=MA.(try make the answer simpler for me)
(A)
V=?
S=4m
T=0.1s
V=S/t
V=4/0.1
V=40m/s?
( i know i didnt use Newtons laws but this is the only thing i know)
(B)
F=?
M=57grams
A=40m/s/s? F=MA
F=40X57
F=2280N?
(im not sure if its right)
The answer to question A is correct. The average speed the egg took to hit the ground is 40 m/s. The average speed is the change in distance traveled (4m) over the time taken (0.1s).
The answer to question B is also correct depending on what your teacher is expecting. The egg has a gravitational vector pulling the egg down towards the earth. As soon as the egg hits the earth, a normal force is applied to the egg to prevent the egg from going through the ground. I believe you need to know momentum to accurately solve the problem, but if you assume the normal force and the gravitational force are equal, then yes, your answer is correct.
I would wait for a mentor if I were you.
Actually, I have a question for the mentor that comes to solve your problem, if you assume the gravity vector and normal force vector are equal, then doesn't that only prevent further acceleration? How does that cause the object to stop?
Thank you but I believe I needed to use Newtons laws for the first question and I'm not sure that I did.
I don't seem to see how you could use Newton's laws to solve the question. Maybe I misunderstood the question? Is it asking for the velocity of the egg when it hit the ground? If so, you can use the kinematics equation:
v2 = v1 +a*t
= 0 + 9.81*0.1
= 0.981 m/s
(A)
V=?
S=4m
T=0.1s
V=S/t
V=4/0.1
V=40m/s?
(B)
F=?
M=57grams
A=40m/s/s?
F=MA
F=40X57
F=2280N?
When an object is dropped, it usually means it starts with zero velocity. If the balcony was 4m high and the egg was dropped, it will take more than 0.1 seconds to reach the ground
I think the 0.1 seconds refers to the time taken for the egg to STOP having hit the ground.
Use the usual formulas to calculate the speed just before hitting the ground.
If you have done enough vertical motion / falling object questions you would know that if an object falls 4.9 m , it takes 1 second, and reaches 9.8 m/s.
Since this egg falls 4 m it will take a little less than a second, and reach a slightly slower speed.
thanks for the tips but i haven't learned anything about that so far on kinematics equations ect.
Well its a hypothetical question and the egg does take 0.1s to complete the fall but you make a good point
I strongly disagree.
Clap you hands twice as quickly as you can.
The time between claps will be approx 0.1 seconds.
You can't even throw an egg fast enough to get to the ground in 0.1 seconds.
For simplicity: let's adjust this to a 4.9m balcony.
The egg will reach a speed of 9.8 m/s, having accelerated for a whole second under the influence of gravity - the force is the weight of the egg. (0.057 x 9.8) N
When the egg hits the ground it stops in just 0.1 seconds. That requires 10 times the acceleration, so 10 times the force*, so the force that cracks the egg is 10 x (0.057 x 9.8) N
* 10 times the force to stop it in 1/10 th the time.
Your balcony was only 4 m high, so the speed is a little less, and the "crcking Force" will also be a little less.
The equations you need to use are listed here
http://en.wikipedia.org/wiki/Equations_of_motion
They are also explained there.
From the "Classic Form" of the equations, you use No 5 for Part A, then No 1 for Part B.
Everyone knows that an egg would not really take 0.1 seconds to fall four meters. This question has been just simply used to test my knowledge about Newtons laws, force, velocity.(which isn't very much).
If you will finally get your head around the idea that the egg fell from 4m and then stopped in 0.1 seconds when it struck the ground, you may be able to increase your knowledge.
Here i will state the question directly:
Assume the egg is not encased in an egg holder:(Note the time taken by the egg to hit the ground is 0.1s and the hight of the balcony is 4m.)
a). calculate the speed with which the egg, when dropped from the first floor balcony will hit the ground.(Use Newtons laws.)
This is exactly what the question asks and i do agree with you when you say it would take around 1.3 seconds or so to reach ground and would take 0.1 seconds for the egg to stop moving. so yes you are right even though we were discussing about kind of different things
Related to Speed, force, velocity, (falling object)
What is the difference between speed and velocity?
Speed refers to how fast an object is moving, while velocity takes into account both speed and direction of motion.
What factors affect the force of a falling object?
The force of a falling object is affected by the mass of the object and the acceleration due to gravity.
How does air resistance impact the speed and velocity of a falling object?
Air resistance, also known as drag, can decrease the speed and velocity of a falling object by pushing against it in the opposite direction of motion.
What is the equation for calculating the force of a falling object?
The equation for force is F = m x a, where F is force, m is mass, and a is acceleration due to gravity.
How does the surface area of an object affect its speed and velocity when falling?
The larger the surface area of an object, the greater the air resistance it will experience, which can slow down its speed and velocity while falling.
