Speed of a rocket using energy methods
11 replies · 2K views · last reply
BrainMan
A rocket is launched such that when the fuel is exhausted, the rocket is moving with a speed of Vo at an angle of 37° with the horizontal and at an altitude h. (a) Use energy methods to find the speed of the rocket when its altitude is h/2. (b) Find the x and y components of velocity when the rockets altitude is h/2. Use the fact that Vx=Vxo = constant (since ax-0) and the result from a.
The Kinetic and Potential energy equations
I did
1/2mv2+mgy= E
and then I solved for v and got
v= (2Egy)1/2
the correct answer is (a) v = (v02 + gh)1/2
(b) vx= .799vo, vy= - (- 0.362vo2 +gh)1/2
I wasn't really sure how to approach this type of problem
I did
1/2mv2+mgy= E
v= (2Egy)1/2
How did you manage to get that? It looks like you didn't do the algebra correctly.
in a you solved for v wrong. You're attempting to do what they did, you just made a mistake that I think you can find.
When they say the speed at h/2, do they mean on the way up or down?
I'm not sure and what could I do with that information?
BrainMan said:
1/2mv2+mgy= E
You have two instances where you can apply that equation: at the point where the fuel is exhausted, and again when it has descended to height h/2. Which term is the same at both points? What equation does that give you?
Is it that they both have the same amount of energy? So would you get something like 1/2mv2+mgy=1/2mv2+mgy?
Yes, plugging in the appropriate values for v and y each side.
OK I get it but I am having trouble finding the y component. I did sin 37 to find the y component but it looks like in the answer they gave they have that number squared - (0.362vo2 +gh)1/2. Why is sin theta squared in this equation?
What is ##\ (v_0)_y\ ?\ ## Isn't sin(θ0) a factor of this?
The initial speed in the y direction is Vo* sin(37). So shouldn't the equation be .601Vo instead of .362vo?
If a speed is 0.601v, what is the square of that speed?
