Speed of catching a falling ruler
  • Thread starter Thread starter bobbajobb
    Falling Speed
The discussion focuses on calculating the reaction time for catching a falling ruler, weighing 0.025 kg and dropped from a height of 1.04 m. The gravitational potential energy is calculated as 0.26 Joules, while the kinetic energy upon falling 12 cm is determined to be 0.03 Joules. The governing equation for the time taken to fall is derived from s = (1/2)gt², leading to a calculated reaction time of approximately 0.154 seconds. Participants clarify the importance of using the correct equations and understanding the relationship between potential and kinetic energy.
  • Understanding of gravitational potential energy calculations
  • Familiarity with kinetic energy concepts
  • Knowledge of basic physics equations of motion
  • Ability to perform unit conversions (e.g., cm to m)
  • Study the equations of motion in detail, particularly s = ut + (1/2)at²
  • Learn about the conservation of energy principles in physics
  • Explore the effects of air resistance on falling objects
  • Practice calculating reaction times using different heights and weights
Students studying physics at the GCSE level, educators teaching basic mechanics, and anyone interested in understanding the principles of motion and energy conservation.
bobbajobb
Okay, I've been set a piece of coursework to compare the reaction times of catching a ruler, with, or without a certain variable. (I've chosen either eye.)
I'm having trouble working out the exact amount of time it takes the person to catch the ruler. (Yeah, I have attempted it. :) )
(Explained in section 3.)
The ruler weighs 0.025kg.
I hold the ruler at 1.04m. (An average of 10 times holding the ruler at a neutral position)
To calculate the gravitational potential energy I do:
0.025 x 1.04 x 10
This gives me = 0.26 (Joules)
The ruler falls 12 cm, (the person caught it at 18cm)
So 0.025 x 0.12 x 10 = the kinetic energy = 0.03
The formula for speed is :
Speed squared = kinetic energy/(0.5 times the weight)
0.03 divided by 0.0125 = 2.4
The square root of 2.4 = 1.549193338
To two decimal places = 1.55m/s
And if the ruler traveled 12 cm at 1.55m/s
0.12/1.55 = 0.0774 seconds……
I must have gone wrong somewhere...because I swear its 'physically' (pun intended) impossible for them to catch it that quickly?
If the ruler falls 12cm you find the time taken using
S=ut + ½gt²
s=12cm, that is 0.12m
g=9.8m/s²
and u=0 if it started from rest.
The reaction time will be between 1 and 2 tenths of a second, which seems about right.
Sorry, would you mind using words to write it out? This is only GCSE so I'm not too good with all the proper letters and stuff :(
so, you are using work- kinetic energy theorem. I'm trying to understand your problem, if anywhere I go wrong then let me know by posting here.
so m = 0.025 kg
so h = 1.04 m
0.025 x 1.04 x 10
Correct!
I'm unable to understand this sentence and your solution from here. And most probably you are wrong from here. Also remember that potential energy is calculated from the bottom. I mean height is calculated from the ground level. so if the body falls 12 cm then potential energy will be mg (h -12). Secondly, loss in potential energy is equal to gain in kinetic energy.
Ahhh sorry. The way the test works is that I hold the '30cm' mark directly above their fingers, so its almost touching. So the person's fingers are on '18cm' on the ruler.
And as you might have seen. I don't actually use the potential energy at all, I'm just showing that I know how to, to gain extra marks.
Have you done the equations of uniform motion at GCSE yet? See below.
If you are trying to use kinetic and potential energy considerations you will not get the time directly.
There is a set of 4 equations you can use to solve problems of objects accelerating when you know some of these:
s=distance travelled
t=time taken
u=initial velocity
v=final velocity
a=acceleration
I mentioned one of them in my post. This was the one to use in this case. g is acceleration due to gravity, =9.8m/s/s
okay, then potential energy at the point where you stop the scale is
= 0.025 * 10 * 0.92
= 0.23 Joule
Now loss in energy = 0.26 - 0.23
=0.03 Joule
This much energy is converted into kinetic energy
0.03 = (1/2) 0.025. v^2
v = sqrt of (2 * 0.03)/0.023
Now try to calculate. But remember don't trust blindly on me cause I'm noob like you in physics.
on second line 0.92 is because the height of the scale from the ground is (1.04 - 0.12) m
The weight or mass and energy don't enter into this problem at all. Basically all you're doing is measuring how far the ruler falls before the other person catches it. From this distance you can calculate the person's reaction time. The governing equation is s = (1/2)gt2, with g ~ 9.8 m/sec2.
Guys I'm seriously confused now :(
So is what I'm doing in my original post...correct? Or at least somewhat? I don't need to go into detail about drag or anything for GCSE do i...?
What I'm trying to say is...have I just gone about it in a different way? Could someone use the g ~ 9.8m/sec^2 thing for my example in my first post and see if it gets the same outcome?
so I should continue with my last post.
after calculation, I've got v = 1.61 m/s
Now v = u + a.t
1.6 = 0 + 10 t
t = 1.6/10
t = 0.16 second.
Or you can also get this result by using equation
v^2 = u^2 + 2.a.s
v^2 = 2*10*0.12
then apply,
v = u + a.t
Or simply you can use as told by most of here,
s = u*t + (1/2) a* t^2
=> s = (1/2)a * t^2
=> 0.12 = (1/2) 10 * t^2
=> t = 0.154 second
  • · Replies 20 ·
9K
