Speed of Light Always The Same?
antd
I know this has been beaten to death in this forum and other places -> The problem is that I have not come across an explanation which I can understand!
I understand the most basic things of time dilation. And it makes sense to me.
However, I cannot grasp the concept of how light always travels at roughly the same speed in a vacuum.
If a spaceship traveling at 99% of the speed of light is racing after a photon of light, how is it that the photon is moving away from the spaceship at 100% of the speed of light...?
Shouldn't the spaceship be only a small distance from the photon which it is chasing?
It seems though that this is wrong. And that the photon should be moving away from the spaceship at c... meaning the photon would be extremely far away from the spaceship?!
I have read many explanations, but none do it for me >.<
Can someone explain this in a very simple manner?
excuse my stupidity on the matter..
Not "roughly" the same speed- exactly the same speed!
No, the photon moves away from the spaceship at 100% the speed of light. That would be true in clasical physics. In classical physics, a stationary person would say that the photon is moving, relative to him, at 199% the speed of light because he would use the "speed addition formula" u+ v. But according to relativity (and verified by experiment) for very high speeds the correct formula is
\frac{u+ v}{1+ \frac{uv}{c^2}}
In your example u= c. That formula gives
\frac{v+ c}{1+ \frac{vc}{c^2}}= \frac{v+c} {\frac{c+v}{c}}= c
That works out that way for any speed, not just .99c. That's why the speed of light, relative to anyone, no matter how fast, the spaceship that originates the light is moving relative to them, is c.
Hmm sorry, I don't understand the mathematics.
I accept what you told me is true :) But it doesn't help me explaining how it is true... >.<
For example, I don't know why the spaceship would see the photon far away from them
But someone not moving and watching would see the photon close to the spaceship?
Or the other way around? hmm... I don't understand. Surely the photon is either close or far away from the spaceship... but not both?
What if we froze time and the spectator walks up to the photon... where would it be then?! close to the spaceship or far away?
(if you have a problem with freezing time, let's say we have a simulation of the universe in a computer. And we froze that instead.) :p
Reposting some comments from another recent thread on this question:
Different observers measure the speed of anything using rulers and clocks which are at rest relative to themselves, and synchronized in their own frame using the Einstein clock synchronization convention. But the rulers of different observers don't measure distance the same way (each observer measures rulers that are moving relative to themselves to be shrunk by a factor of sqrt(1 - v^2/c^2) relative to their own ruler/clock system, the effect known as length contraction), the clocks of different observers don't measure time the same way (each observer measures clocks that are moving relative to themselves to have the time between ticks expanded by a factor of 1/sqrt(1 - v^2/c^2), the effect known as time dilation), and clocks that are synchronized in their own frame will be measured to be out-of-sync in other frames (clocks that are synchronized and have a distance x between them in their own rest frame will be out-of-sync by vx/c^2 in another frame where they are moving at speed v, due to what's called the relativity of simultaneity). So, it's because of all these differences that two observers can each think light is moving at c relative to themselves.
For a numerical example of how all these effects come together to ensure both observers measure a single light ray to move at c, see my post #6 on this thread.
you are confused for the same reason that all newbies get confused. 'relativity of simultaneity'. once you get the idea its not as hard as it sounds.
This wording is going to lead to cos-like discussion about what is "real" and "true". It's not just a case of each of the observers thinking that light is moving at c relative to themselves, light is moving at c relative to themselves.
The scenario raised here is almost precisely the one which got me interested in this area and I am not sure that someone who has approached from the OP's starting point will immediately appreciate the "relativity of simultaneity" approach.
The visualisation which I came up with to explain the phenomenon worked quite well for me, but months of effort have shown it is difficult to explain to others.
cheers,
neopolitan
the best advice I can give you is to learn to draw a spacetime diagram.
Well, it's only moving at c relative to themselves in a particular choice of coordinate system. Coordinate systems are human inventions, are they not? That's why I said "thinks", although I could equally well have said something like "measures using their own ruler/clock system constructed in the particular way defined by Einstein".
The relativity of simultaneity was only part of my answer, the more intuitive difference is that they measure length differently because of length contraction, and time differently because of time dilation (as well as because of the relativity of simultaneity if they are measuring the one-way speed of light, although you can dispense with simultaneity issues altogether if one of them is measuring the two-way speed of light and therefore needs only one clock), and each one defines "speed" in terms of their own distance/time measurements.
Hmm, but it seems as if the same photon is in two or more places at once... depending on how many observers there are?!
Not at two places at once... rather that for any fixed event (place and instant) the distances and times to other events will depend on the observer.
It's not that the photon is in two places at once, but that the single place-and-instant is at many different distances at once, depending on how you look at it.
I agree with these comments, but I would like to add that even though it's not as hard as it sounds (mathematically), it's even more counterintuitive than it sounds. (When you hear about it the first time, you aren't even aware of some of the more bizarre consequences of the invariance of the speed of light). That's why spacetime diagrams are so useful. The only way to develop some sort of intuition for these things is to starting thinking in terms of spacetime diagrams.
A photon is the worst example you can pick, because photons aren't really localized in space. (That's a very difficult quantum mechanical result that I don't fully understand myself). The detection of a photon is a better example, because that's an event. It's something that happens at a specific time at a specific place. The set of all events is called "spacetime". All observers agree about what events are a part of spacetime. They just disagree about what coordinates to assign to the events. Each observer uses his/her own coordinate system, which is just a function that assigns four numbers to each event.
Can you demonstrate a coordinate system in which c is not moving at c relative to an observer? (Stress is on the relative and note I write c, not the figure which is a consequence of the standard metre and the standard second, so c in terms of fathoms per fortnight or furlongs per full moon is still c.)
cheers,
neopolitan
The OP specifically had a photon based scenario.
cheers,
neopolitan
I don't know - to me it's far simpler than everyone else is trying to say.
The observer on Earth watches a photon leave the spaceship and travel 186,000 miles in one second. The spacehip in that time has moved 99% of that distance, and so has moved 184.2 thousand miles. (The photon is only 1.86 miles ahead of the spaceship)
The observer in the spaceship is time dilated by, say a factor of 10*. i.e. compared to his Earth counterpart, he's moving ten times as slow.
So, the photon is now 1.8 miles in front of his ship - but only 0.01 seconds has passed in his spaceship. He measures the photon's speed as 1.8miles per 0.01 seconds or 186,000mph.
(Alternately, he waits for his appropriate one second, then measures the photon to be 186,000 miles beyond his ship. However, on Earth, ten seconds has passed, so they see the photon 1,860,000 miles in front of the ship.)
*numbers in this example are picked for their clarity of explanation, not for their accuracy
I need help with this as well; I'm trying to get my head around it and its so much... fun and frustration at the same time, fun because its so interesting, frustrating because I don't understand it as much as I wish too.
Here is my similar problem:
A spacecraft is moving at 80% the speed of light (0.8c) from planet X, a radio station sends a light beam parallel to the spacecraft .
What would the observer on planet X and the spacecraft pilot see in regards to 'watching' this light beam move towards the spacecraft .
In both situations light would obviously move at 1c, but how does this work for the spacecraft and observer... damn Counter-Intuitive addition of velocities... where does Time dilation and the Length Contraction come into effect, and how.
Thanks for any help you can provide,
regards
(Alternately, he waits for his appropriate one second, then measures the photon to be 186,000 miles beyond his ship. However, on Earth, ten seconds has passed, so they see the photon 1,860,000 miles in front of the ship.)*numbers in this example are picked for their clarity of explanation, not for their accuracy
due to relativity of simultaneity he will measure distances differently too. not just time (the length of an object is the distance between the front and back at one simultaneous moment)
this is why learning to draw spacetime diagrams is so important
I guess I'm just nitpicking the word "photon". The OP's question is fine if we interpret "photon" as "massless classical particle", which is probably what he had in mind anyway. It's a convenient way to think about light in SR. (The word "photon" is actually defined by a quantum field theory which says that photons aren't localized).
Do you mean a coordinate system in which light is not moving at c (or even at a constant speed) relative to the observer? If so you could pick something like Rindler coordinates which are commonly used for an observer experiencing constant proper acceleration (also discussed here). But really you have total freedom in defining non-inertial coordinate systems any way you like, for example if x,y,z,t represent the coordinates of an inertial coordinate system I could define a non-inertial coordinate system in terms of any transformation I can think of, a simple one would be:
x' = x - at^2
y' = y
z' = z
t' = t
But you could also do a crazy one like:
x' = x * sin(t/t0)
y' = y - t*c
z' = pi*z - 1008
t' = t + 3x/c + 7y/c + 0.5z/c
But by picking fake numbers you've actually given a misleading explanation here--in reality you can't explain the fact that both observers measure the photon to move at c using only time dilation as you suggest, you also need to take into account length contraction and the relativity of simultaneity.
regards
In the planet X rest frame:
Suppose as the spacecraft is leaving planet X, they synchronize clocks, so that the planet X clock reads t=0 and the spacecraft clock reads t'=0 at the moment it leaves planet X. Now suppose that planet X sends the signal 75 years later at t=75 on the planet X clock, and that at the same moment in this frame, the spacecraft is passing another planet, planet Y, which is at rest relative to planet X and 60 light years away in this frame (since the spacecraft was traveling at 0.8c in this frame, naturally 75 years after it left planet X it would be at a distance of 75*0.8=60 light-years from planet X). There is a clock at planet Y which is synchronized with the on at planet X in this frame, so it also reads t=75 when the spacecraft passes it. In this frame the spacecraft clock is slowed down by a factor of sqrt(1 - 0.8^2) = 0.6 due to time dilation, so it only reads t' = 75*0.6 = 45 when it passes planet Y.
The spacecraft starts out 60 light years away from planet X when the signal is sent at t=75, so after 300 years have passed in this frame the spacecraft will have traveled an additional 300*0.8c = 240 light years away, so 300 years later at t=375 years, it'll be 60 + 240 = 300 light-years away from planet X. And naturally if we assume the signal travels at c = 1 light year/year in this frame, the signal will also be 300 light-years away from planet X after 300 years have passed from the time it was sent, so t=375 years must be the time in the planet X frame that the signal reaches the craft. However, because of the time dilation factor, at t=375 the spacecraft clock only reads 375*0.6 = 225 years, so t'=225 years must be the time on the spacecraft 's clock when the signal reaches it.
In the spacecraft frame:
All frames agree on local events, so it must be true in this frame too that the planet Y clock reads t=75 at the moment the spacecraft is passing it, at which time the spacecraft clock reads t'=45, as we figured out before. However, in this frame the planet X clock does not read t=75 at this moment, due to the relativity of simultaneity. The way the relativity of simultaneity works is that if two clocks are synchronized and a distance L apart in their own rest frame, then in a frame where they are moving at speed v parallel to the axis between them, the clock in the rear will show a time that's ahead of the clock at the front by vL/c^2. So, in the spacecraft 's frame at the moment it's passing planet Y, the planet X clock must be behind by (0.8c)*(60 light-years)/c^2 = 48 years, so the planet X clock reads t=75-48=27 years at the moment the spacecraft is passing planet Y in the spacecraft frame. Since the planet X clock is slowed down by a factor of 0.6 in this frame, we know the planet X clock will take an additional 48/0.6 = 80 years to tick forward to t=75, i.e. the planet X clock will read 75 at t'=45+80=125 in the spacecraft frame. And again, all frames agree on local events, so it must be true in this frame as well that the signal was sent when the planet X clock read t=75, at t'=125 in the spacecraft frame.
Meanwhile, because of length contraction, if the distance between planet X and planet Y was 60 light years in their own rest frame, then in the spacecraft rest frame the distance is shrunk by a factor of sqrt(1 - 0.8^2) = 0.6, so the distance between planet X and planet Y is only 60*0.6 = 36 light-years in the spacecraft rest frame. So at t'=45 when the spacecraft was next to planet Y, planet X was 36 light-years away; and since planet X is moving at 0.8c away from the spacecarft in this frame, that means 80 years later at t'=125 when planet X was sending the signal in this frame, planet X must have been an additional 80*0.8=64 light-years away, for a total of 64+36=100 light-years away from the spacecraft at the moment the signal was sent at t'=125. So, under the assumption that light travels at c in this frame too, the signal will reach the spacecraft 100 years later at t'=225.
By the way, another way to approach this problem would be to use the Lorentz transformation, which says that if an arbitrary event has coordinates x,t in one frame, then in a second frame moving at v along the first frame's x-axis (and with the two frames having a common origin, so x=0,t=0 in the first frame coincides with x'=0,t'=0 in the second), this same event will have coordinates:
x'=gamma*(x - vt)
t' =gamma*(t - vx/c^2)
with gamma = 1/sqrt(1 - v^2/c^2)
In this problem v=0.8c so gamma=1/0.6=1.666..., which means for example that if the event of the signal being sent had coordinates (x=0, t=75) in the planet X frame, in the spacecraft frame the event of the signal being sent has coordinates:
x'=1.666...*(0 - 0.8*75) = -100
t' =1.666...*(75 - 0.8*0) = 125
And if the event of the signal reaching the spacecraft happened at (x=300, t=375) in the planet X frame, in the spacecraft frame this event has coordinates:
x'=1.666...*(300 - 0.8*375) = 0
t'=1.666...*(375 - 0.8*300) = 225
So, you can see that this agrees with the previous calculations, and it's a little simpler to figure out although if you use the Lorentz transform you don't get to think about the different contributions of time dilation, length contraction and the relativity of simultaneity.
read einsten's "special theory of relativity",trust me ,all your doubts will vanish.
Thanks JesseM, this really helped in understanding it all, and the semi-complex nature of special relativity. Definitely printing that out for keeps in helping my understanding.
regards
x' = x - at^2
y' = y
z' = z
t' = t
x' = x * sin(t/t0)
y' = y - t*c
z' = pi*z - 1008
Yes, the first c should have been "it" from your quote and "it" was light.
As for your coordinate system, you just jumped out of SR and the question was posed in the context of SR (look at the OP's original question).
Let me rephrase, can you demonstrate a coordinate system in which light is not moving at c relative to an inertial observer?
It doesn't make sense to have a non-inertial coordinate system if the observer is inertial, but I think you will find that even if a non-inertial coordinate system is used then, in that non-inertial coodinate system, the speed of light relative to the observer will be c. So, the choice of inertial coordinate system is not the culprit in your example, but rather non-inertia.
And not being inertial is not a human invention.
cheers,
neopolitan
You're allowed to use non-inertial coordinate systems in SR (since 'SR' just means Lorentz-symmetric laws of physics in flat spacetime), you just can't assume that the equations for the laws of physics will work the same in such systems.
When you say "relative to an inertial observer", do you mean relative to an inertial coordinate system, or are you talking about the relative speed between an inertial observer and light in a non-inertial coordinate system?
Can you explain what it means to talk about the "speed of light relative to the observer" in a non-inertial coordinate system? Do you just mean the rate at which the distance between the inertial observer and the photon is changing in the non-inertial coordinate system? If so this needn't be c, and in fact even in an inertial coordinate system the rate at which the distance is changing between an inertial observer not at rest in this system and a light ray will be something other than c (for example, if an inertial observer is moving at 0.8c in the same direction as the light ray in whatever inertial frame you're using, then in this frame the distance between them is only increasing at 0.2c).
You are making this far too complex. There is no need for a non-inertial coordinate system for a non-inertial observer (the observer is the one using the coordinate system). You raised a non-inertial coordinate system unnecessarily, either because you misunderstood or as a diversion to cover the fact that you made an unsupportable claim:
To make it simpler for you, I will rephrase again:
Can you demonstrate an inertial coordinate system in which light is not moving at c relative to an inertial observer such as in the OP's scenario?
If you can't then your claim above is wrong. If you can, I thank you for your time.
Finally, your last bit about the distance between a photon and the observer increasing at 0.2c is not talking about the speed of light relative to the observer, is it? That's a scenario relative to someone else, a someone else relative to whom the observer is moving at 0.8c and relative to whom light is moving at c. That's a different scenario to the one raised by the OP.
I'll repost the OP's scenario to aid you:
cheers,
neopolitan
But you were just talking about non-inertial coordinate systems yourself when you said: "but I think you will find that even if a non-inertial coordinate system is used then, in that non-inertial coodinate system, the speed of light relative to the observer will be c." Much of my previous post was just asking what you meant by that, if you wish to take back the statement then fine, but don't go accusing me of intentionally creating a "diversion" to "cover" something, which seems like unnecessarily antagonistic language on your part.
That statement was in response to your taking issue with a previous statement I had made:
I think it's misleading to say light "is" moving at c relative to themselves in any objective physical sense that's independent of human conventions. There may be no need to use non-inertial coordinate systems, but that doesn't mean that inertial coordinate systems reflect what the speed of light really "is" relative to themselves whereas non-inertial ones don't.
I think you misunderstand my claim, it had nothing to do with the idea that the speed of light is anything other than c in inertial frames. I was just saying that I think your statement "It's not just a case of each of the observers thinking that light is moving at c relative to themselves, light is moving at c relative to themselves" is misleading, because without specifying a choice of coordinate system or method of measurement, all statements about how fast one thing is moving relative to another are ill-defined, speed being an inherently coordinate-dependent notion. If you just meant that light "is" moving at c relative to themselves if they choose to define 'speed relative to themselves' in terms of speed in their own inertial rest frame then of course I agree, but hopefully you agree that it's purely a matter of convention for inertial observers to define "their own" perspective in terms of how things work in the inertial frame where they happen to be at rest. Also, if this is what you meant, then I don't see how that's different from my original statement that each observer "thinks" the light is moving at c because they measure it using rulers and clocks at rest relative to themselves.
If you look back at the context I think it was pretty clear that bit wasn't in response to any statement in the OP, it was in response to your statement "but I think you will find that even if a non-inertial coordinate system is used then, in that non-inertial coodinate system, the speed of light relative to the observer will be c." Here you seemed to be trying to define the speed of light "relative to the observer" (an inertial observer, if I was understanding the context right) in a non-inertial coordinate system, so I was asking what you meant by that. I offered the hypothesis that maybe you meant the rate the distance between the inertial observer and the light was changing in the non-inertial coordinate system, and so I pointed out that if this is what you meant then there'd be a problem with this, because even in an inertial coordinate system the rate the distance between an inertial observer and a light ray changes can be other than c if that inertial observer is not at rest in this system. If that wasn't what you meant by "the speed of light relative to the observer" when "a non-inertial coordinate system is used", then this particular comment of mine can be ignored since it was based on an incorrect hypothesis about what you may have meant by that, although in that case I am still curious what you did mean by that statement.
I assume you agree that if an observer is inertial, while the observer chosing an inertial frame in which that observer is at rest is sensible (even if arbitrary), the observer would not be sensible to chose a non-inertial frame to describe how things work? I assume you also agree that it is in fact possible to do so.
In the context of my comments above, I am assuming that you agree that an inertial observer may chose to utilise a non-inertial coordinate system. We can convert from that non-inertial coordinate system to an inertial coordinate system, can we not?
Do you agree that if we start using a non-inertial coordinate system to describe the delta between the path of an inertial observer and the path of a photon relative to that observer (the speed of the photon relative to the observer who is at rest relative to himself), and then convert that delta to an inertial coordinate system, at the very least, the delta described in an inertial coordinate system (the speed of the photon relative to the observer who is at rest relative to himself) will be c?
I am certain that an inertial observer, even if forced to adopt a non-inertial coordinate system, will calculate that the speed of a photon relative to him is c.
Try to imagine that you are inertial, but told you are spinning and must use a coordinate system which reflects that. This means that a photon you observe (thought experiment magic again), although apparently maintaining a straight path to your location must be spiralling in towards you. Now you can either use your senses to say "no, the photon is not spiralling in, and I am not spinning" or you can calculate the relative path of photon in towards you using your bizarre coordinate system. Once you do the latter, you will have your own behaviour (spinning) and the behaviour of the photon (spiralling in) and the relative motion of the photon towards you can be calculated. Do that calculation and you will find that the speed of the photon relative to you is c - a constant c, in one direction.
Which means to me that the fact that a photon travels at c is not a coordinate system based thing.
(Equally, if you are spinning, and your coordinate system uses that, then the inertial speed of a photon traveling towards the location where you are spinning will still be c. As for acceleration, you can do element analysis rather than talking about instantaneous relative speed (which is what I would do) and say that over an infinitesimally short period of time, you will be effectively inertial even while accelerating smoothly over a longer period and during that infinitesimally short period of time, the relative speed of a photon traveling towards the location where you are undergoing acceleration will still be c. What will change is how far away it is in your non-inertial coordinate system.
cheers,
neopolitan
Yes, but as soon as you convert, you're no longer using the non-inertial coordinate system. When physicists talk about what's true when you are "using" a given coordinate system, they mean to restrict your attention only to statements involving that system's coordinates. Anything else would just be a totally confusing and convoluted use of language.
If you convert to the one inertial coordinate system where that inertial observer is at rest (as opposed to some other inertial coordinate system where he isn't), then sure, in this coordinate system the light's velocity relative to the observer will be c.
This doesn't make sense in terms of how physicists talk--if he's "forced to adopt a non-inertial coordinate system", that means he's calculating things from the perspective of that coordinate system, not converting into the inertial coordinate system where he's at rest (since that automatically means he isn't using only the non-inertial coordinate system).
Ideally I'd prefer not to deal with thought experiments where observers are explicitly given false information--whenever you bring up such thought-experiments they never seem to make much sense to me. And this certainly isn't what I meant when I talked about an inertial observer using a non-inertial coordinate system. I meant that they would be correctly calculating the coordinates of events using a non-inertial coordinate system, not calculating the coordinates of events in an inertial coordinate system but falsely believing it to be non-inertial.
I don't understand what "relative motion of the photon towards you" would mean in this context. Presumably if the observer isn't really spinning, then they are really just using an ordinary inertial frame and the coordinate speed of light in this frame will be c. But if they falsely believe that this is a spinning frame, they will conclude that if they were to transform from their own "non-inertial" frame to an inertial frame, the light would be moving in a spiral in this hypothetical inertial frame, yes? Are you somehow arguing that even with these false assumptions, if they calculated the speed the light was moving in the hypothetical inertial frame, they would still find it to be c? Or are you defining "relative motion" in terms of the putatively spinning frame, which we know is really inertial so by definition the speed of the photon must be c in this frame?
Of course it is. Leaving aside confusing thought-experiments about observers who have been lied to, if we calculate the speed of the photon in an actual valid non-inertial coordinate system, it is not necessarily going to be c. Do you disagree?
If you calculate the "inertial speed" of a photon, then by definition you are calculating its speed in an inertial coordinate system, not a rotating coordinate system! When you calculate the speed of something "in" a given coordinate system, you calculate it using that coordinate system's distance and time intervals, period.
  • #31
Let's try again, keeping it simple.
Do you agree that when we are talking about an inertial observer, it does not make sense to use anything other than an inertial coordinate system?
Do you agree that by default we talk about inertial coordinate systems (for example in the second postulate, this is assumed)?
Can you give me an example where we would not use an inertial coordinate system (either by choice or as the result of coercion) in a scenario where we are discussing only inertial participants (participants in the scenario)?
cheers
neopolitan
  • #32
It would be kind of pointless to use a non-inertial coordinate system in this situation, although there'd be nothing technically wrong with using one if you just wanted to see how things worked out in it.
Well, it's not just assumed, it's specifically stated that the two postulates are meant to apply to inertial coordinate systems. But yes, I agree this is the default in SR.
There isn't any specific reason why you'd normally make that choice, but it is your choice, if for whatever idiosyncratic reason you wanted to analyze this situation using a non-inertial system then again there'd be nothing physically incorrect about it.
  • #33
In light of that, can you explain why it was sensible of you to say that the speed of light being c is a consequence of your (human invented) coordinate system?
cheers,
neopolitan
