Speed of particle before its KE is doubled
  • Thread starter Thread starter Miri
    Particle Speed
The discussion focuses on determining the speed a particle must reach for its kinetic energy to be double that predicted by the nonrelativistic formula KE=0.5mv². The correct approach involves equating the relativistic kinetic energy, expressed as (gamma - 1)mc², to twice the classical kinetic energy. The final result for the speed is v = c sqrt{[sqrt(5) - 1]/2}, where gamma is defined as 1/sqrt[1-(v/c)²]. This derivation confirms that the relativistic effects must be considered for accurate calculations at high velocities.
  • Understanding of classical kinetic energy (KE=0.5mv²)
  • Familiarity with relativistic kinetic energy concepts
  • Knowledge of the Lorentz factor (gamma)
  • Basic algebra for solving quadratic equations
  • Study the derivation of the Lorentz factor (gamma) in special relativity
  • Learn how to solve quadratic equations in physics contexts
  • Explore the implications of relativistic speeds on mass and energy
  • Investigate the differences between classical and relativistic mechanics
Students and educators in physics, particularly those focusing on mechanics and relativity, as well as anyone interested in the mathematical foundations of kinetic energy in high-speed scenarios.
Miri
What speed must a particle attain before its kinetic energy is double the value predicted by the nonrelativistic expression KE=0.5mv^2?
(there is no data given)
How should I solve this if I have no numbers to insert...? Should I set this equation equal to the relativist one (e.g. E=KE-rest energy)
In the end v/c=~0.786151
Corrct, but I think you meant to equate the relativistic kenetic energy to twice the classical kinetic energy:
Kinetic energy is (gamma - 1) m c^2, so we have:
(gamma - 1) m c^2 = m v^2 -------->
gamma - 1 = (v/c)^2
Thank you..But I don't get it how you have this 5 in the 2nd sqrt...v = c sqrt{[sqrt(5) - 1]/2} The result is correct.
You just put gamma = 1/sqrt[1-(v/c)^2], move gamma to one side of the equation, square both sides, and solve the quadratic equation.
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 53 ·
