Speed of shaft connected to gear
  • Thread starter Thread starter vidhyarthi
    Gear Shaft Speed
The discussion centers on the relationship between the rotational speeds of two shafts connected by gears with a gear ratio of 1:2. When shaft S1, connected to a motor, rotates at 1000 RPM, shaft S2 does not rotate at the same speed due to the gear ratio. Instead, the RPM of S2 is inversely proportional to the gear ratio, resulting in S2 rotating at 500 RPM. The key principles highlighted include the tangential velocity being constant for both gears and the number of teeth being proportional to the diameter of the gears, which directly influences their rotational speeds.
  • Understanding of gear ratios and their implications on rotational speed
  • Knowledge of basic mechanical engineering principles related to gears
  • Familiarity with the formula for converting RPM to linear speed
  • Concept of tangential velocity in rotating systems
  • Study the principles of gear mechanics and their applications in engineering
  • Learn about the calculation of gear ratios and their effects on speed and torque
  • Explore the relationship between diameter, teeth count, and RPM in gear systems
  • Investigate the use of gear trains in various mechanical systems for speed adjustment
Mechanical engineering students, automotive engineers, and anyone interested in understanding the dynamics of gear systems and their impact on rotational speeds.
vidhyarthi
Hi all,
I'm an EE student and i have least knowledge about working of gears.
I just want to know that if there are two shafts S1 and S2 of same diameter having two gears G1 and G2 mounted on them respectively. The gear ratio is 1:2. And the shaft S1 is connected to a motor which rotates at 1000rpm. Then
Will the shafts S1 and S2 rotate at same rpm. If yes then why people say that gears are used to increase or decrease speeds. If no how their speeds are differed?
Keep these two things in mind about gears:
a) The tangential velocity is the same for both gears.
b) The number of teeth is proportional to the diameter of the gear.
As a consequence of a)
v = contant = R1 X angular speed 1 = R2 X angular speed 2
As a consequence of b)
gear ratio = ratio of teeth = ratio of diameters
So for a gear ratio of 2:1, the rpm ratio is also 2:1.
You need to be really careful how you write the gear ratios down, as what you've put doesn't match the drawing.
It's:
Input teeth:Output teeth
Gears can be visualised as two circles touching at a single point. With the respective diamaters being the ratio of the gears.
So you say the ratio is 2:1, but the picture shows a 1:2 ratio as the output gear is larger.
But actually rpm is inversely proportional to diameter of the rotating object then if gear ratio i.e. the ratio of diameters is 2:1 then i think the rpm is 1:2. Is it true?
It's:
Sorry i thought that gear ratio as the ratio of their speeds.
And what happens to the shaft rotation will they rotate at equal rpm?
That's true and you've just answered your next question.
The shafts rotate at the same speed as their respective gears.
Final question(i think i can understand fully with this)
Let the diameter of shaft S1=S2=19mm and S1 is a motor shaft rotating at 3000rpm.
from rpm=(kmphx1000)/(60xA) the speed of shaft is 10.744kmph
The gear G1 with diameter 150mm rotates at 380rpm and the gear G2 rotates at 190rpm(got from above formula)
then at what rpm the shaft S2 rotates 3000 or 190??
Why are you saying the gears are rotating at different speeds to the shafts? Also where on Earth did you find that formula?
I'm saying that because gear has more diameter than shaft and from your question can i understand that shaft just deliver power to any thing connected to it i.e same torque and same speed.
And coming to the formula i got it here http://wiki.answers.com/Q/What_is_the_formula_for_converting_rpm_to_kph
