What happens to the speed and time of a satellite orbiting closer to Earth?
  • Thread starter Thread starter Kajan thana
    Satellite Speed
19 replies · 2K views
Kajan thana
A satellite orbiting the Earth moves to an orbit which is closer to the earth.
What happens to the speed and the time it takes for the one orbit of the Earth.
It is circular motion so I will use [/B]
a=ω^2(r) a=(2π/T)^2/r
If the r is decreasing, then the value of a is also decreasing this means that period will increase as it is inversely proportional.
Can someone help me out?
In the first equation, r is in the numerator on the right-hand side. But in the second equation you have moved r into the denominator. Did you mean to do that?
If the r is decreasing, then the value of a is also decreasing... .
Can you justify this statement?
a is proportional to r by the omega constant. If I increase a then r will also increase.
Is it correct to assume that ω is constant when you switch orbits?
yes, the omega will change also but I am still clueless.
It will help to consider where the acceleration is coming from. When the satellite is in a circular orbit, what force acts on the satellite?
Yes, the force acting on the satellite is the force of gravity. If the satellite is moved closer to the earth, does the force of gravity on the satellite increase or decrease?
Kajan thana said:
Increases, is ma is proportional to 1/r^2
Yes. Good.
how will I still find out if the period is increasing or decreasing?
Look at your equation a = ω r. [EDIT: Meant to write a = ω2 r] If you switch to an orbit closer to the earth, what happens to r? What happens to a? What happens to ω?
yes but like what you said the r is not a constant.
Using the formula a = ω2 r, you should be able to figure out if ω increases or decreases when the satellite is moved into an orbit closer to the earth.
Does the left side of the equation get larger or smaller?
Left hand side get larger, I thought in order to look at proportionality something need to remain constant, isn't that the case?
And also I want make sure if we are allowed to relate MA with gravity because my teacher told me MA can be only used when it is contact with something else.
In the equation a = ω2 r, all three quantities a, ω, and r change when moving to an orbit closer to the earth. Nevertheless, you can still use the equation to deduce what happens to ω.
Gravity is an "action-at-a-distance" force. It can act on an object even when the object is not in contact with any other object. The satellite is a good example. When it is in orbit, it is not in contact with any other object. Yet, there is the force of gravity acting on the satellite.
F = ma will apply to this situation.
If it helps then try thinking about the extremes
Try thinking about or solving the velocity required to orbit the Earth a meter above the surface and the velocity required to orbit the Earth far out like 1000 km away
Compare the two results and see what relationship they hold
