Speeding up Project Euler problem 60 prime pair search
  • Topic: Python
  • Thread starter Thread starter Arman777
    Euler Project
97 replies · 14K views · last reply
Vanadium 50 said:
I was thinking the same thing. I think out of the whole set four primes are unpopular.
One thing I was pondering was the reverse. I already have found valid pairs. If there were a fast way to select the disjoint set of pairs, I could quickly make quadruplets.
That's going to be very slow, since you are doing a logarithm and an exponentiation. But more importantly, it shows you have missed the entire point of profiling your code. If you are spending less than 6 seconds concatenating numbers, what's the maximum gain you can have by speeding up that piece. For instance...
Switching from the concatenation to the product is an order of magnitude improvement. The code provably finds the correct solution in 11 seconds.
Hmm you are right.
Can 11 seconds be improved upon? It's pretty good for what is essentially brute force.
75% of the time is spent in unordered_map. Of that, 2/3 (i.e. 50% overall) is spent in Hash.
10% of the time is spent in power.
Most of the remaining time is spent in various aspects of iterators.
Arman777, based on this, do you think this approach could eventually reach one second? One tenth of a second? What is the limit? And what would need to be done to reach this limit?
Vanadium 50 said:
Let me be clear - it's 1 or 2 seconds to find the solution, and a few minutes to verify that it is indeed the smallest.
Code:
#include <iostream>
#include <cstdio>
#include <forward_list>
#include <unordered_map>
#include <string>
using namespace std;
/* This is all taken from Rosetta Code's deterministic Miller-Rabin test */
// calcul a^n%mod
unsigned long long power(unsigned long a, unsigned long n, unsigned long mod)
    unsigned long long power = a;
    unsigned long long result = 1;
    while (n)
        if (n & 1)
            result = (result * power) % mod;
        power = (power * power) % mod;
        n >>= 1;
    return result;
// n−1 = 2^s * d with d odd by factoring powers of 2 from n−1
bool witness(unsigned long long n, unsigned long long s, unsigned long long d, unsigned long long a)
    unsigned long long x = power(a, d, n);
    unsigned long long y;
    while (s) {
        y = (x * x) % n;
        if (y == 1 && x != 1 && x != n-1)
            return false;
        x = y;
        --s;
    if (y != 1)
        return false;
    return true;
 * if n < 1,373,653, it is enough to test a = 2 and 3;
 * if n < 9,080,191, it is enough to test a = 31 and 73;
 * if n < 4,759,123,141, it is enough to test a = 2, 7, and 61;
 * if n < 1,122,004,669,633, it is enough to test a = 2, 13, 23, and 1662803;
 * if n < 2,152,302,898,747, it is enough to test a = 2, 3, 5, 7, and 11;
 * if n < 3,474,749,660,383, it is enough to test a = 2, 3, 5, 7, 11, and 13;
 * if n < 341,550,071,728,321, it is enough to test a = 2, 3, 5, 7, 11, 13, and 17.
bool is_prime_mr(unsigned int n)
    if (((!(n & 1)) && n != 2 ) || (n < 2) || (n % 3 == 0 && n != 3))
        return false;
    if (n <= 3)
        return true;
    unsigned long d = n / 2;
    unsigned long s = 1;
    while (!(d & 1)) {
        d /= 2;
        ++s;
    if (n < 1373653)
        return witness(n, s, d, 2) && witness(n, s, d, 3);
    if (n < 9080191)
        return witness(n, s, d, 31) && witness(n, s, d, 73);
    if (n < 4759123141)
        return witness(n, s, d, 2) && witness(n, s, d, 7) && witness(n, s, d, 61);
    if (n < 1122004669633)
        return witness(n, s, d, 2) && witness(n, s, d, 13) && witness(n, s, d, 23) && witness(n, s, d, 1662803);
    if (n < 2152302898747)
        return witness(n, s, d, 2) && witness(n, s, d, 3) && witness(n, s, d, 5) && witness(n, s, d, 7) && witness(n, s, d, 11);
    if (n < 3474749660383)
        return witness(n, s, d, 2) && witness(n, s, d, 3) && witness(n, s, d, 5) && witness(n, s, d, 7) && witness(n, s, d, 11) && witness(n, s, d, 13);
    return witness(n, s, d, 2) && witness(n, s, d, 3) && witness(n, s, d, 5) && witness(n, s, d, 7) && witness(n, s, d, 11) && witness(n, s, d, 13) && witness(n, s, d, 17);
}/* This was all taken from Rosetta Code's deterministic Miller-Rabin test */
bool is_prime(unsigned int n)
   if((n >  2) && !(n %  2)) return false;
   if((n >  3) && !(n %  3)) return false;
   if((n >  5) && !(n %  5)) return false;
   if((n >  7) && !(n %  7)) return false;
   if((n > 11) && !(n % 11)) return false;
   if((n > 13) && !(n % 13)) return false;
   if((n > 17) && !(n % 17)) return false;
   if((n > 19) && !(n % 19)) return false;
   if((n > 23) && !(n % 23)) return false;
   if((n > 29) && !(n % 29)) return false;
   if((n > 31) && !(n % 31)) return false;
   if((n > 37) && !(n % 37)) return false;
   if((n > 41) && !(n % 41)) return false;
   if((n > 43) && !(n % 43)) return false;
   if((n > 47) && !(n % 47)) return false;
   if((n > 53) && !(n % 53)) return false;
   if((n > 59) && !(n % 59)) return false;
   if((n > 61) && !(n % 61)) return false;
   if((n > 67) && !(n % 67)) return false;
   if((n > 71) && !(n % 71)) return false;
   if((n > 73) && !(n % 73)) return false;
   if((n > 79) && !(n % 79)) return false;
   return is_prime_mr(n);
bool is_valid_pair(unsigned int a, unsigned int b)
  if(a >= b) return false;
  if(a+b > 26021) return false;
  // Only prime numbers should be past this point, so no need to test a and b for primality
  if((a+b)%3 == 0) return false;
  if (is_prime(stol(to_string(a)+to_string(b)))==false) return false;
  if (is_prime(stol(to_string(b)+to_string(a)))==false) return false;
  return true;
main() {
double duration;
int nprimes;
forward_list<unsigned int> Primes;
unordered_map<unsigned int,bool> Pairs;
// Find the primes
for(unsigned int i=2;i<26000;i++) if(is_prime(i)) Primes.push_front(i);
Primes.reverse();// Find the prime pairs
for ( auto it = Primes.begin(); it != Primes.end(); ++it ) {
   for ( auto jt = next(it,1); jt != Primes.end(); ++jt ) {
      if(is_valid_pair(*it, *jt)) Pairs.emplace (stol(to_string(*it)+to_string(*jt)),true);
      else Pairs.emplace (stol(to_string(*it)+to_string(*jt)),false);
}// Now build the tuples
unsigned int smallest = 26034;
      if(Pairs[stol(to_string(*it)+to_string(*jt))]) {
         for ( auto kt = next(jt,1); kt != Primes.end(); ++kt ) {
             if(Pairs[stol(to_string(*it)+to_string(*kt))] &&
                Pairs[stol(to_string(*jt)+to_string(*kt))]) {
                  for(auto lt = next(kt,1); lt != Primes.end(); ++lt ) {
                    if(Pairs[stol(to_string(*it)+to_string(*lt))] &&
                       Pairs[stol(to_string(*jt)+to_string(*lt))] &&
                       Pairs[stol(to_string(*kt)+to_string(*lt))]) {
                         for(auto mt = next(lt,1); mt != Primes.end() && *it+*jt+*kt+*lt+*mt < smallest; ++mt ) {
                           if(Pairs[stol(to_string(*it)+to_string(*mt))] &&
                              Pairs[stol(to_string(*jt)+to_string(*mt))] &&
                              Pairs[stol(to_string(*kt)+to_string(*mt))] &&
                              Pairs[stol(to_string(*lt)+to_string(*mt))]) {
                                if(*it+*jt+*kt+*lt+*mt < smallest) {
                                   smallest = *it+*jt+*kt+*lt+*mt;
                                   count << *it << " " << *jt << " " << *kt <<" " << *lt << "  " << *mt << " = ";
                                   count << smallest << endl;
                                 } // smallest thus far
                            } // 5-plet
                         } // m-loop
                    } // 4-plet
                  } // l-loop
                } // 3-plet
          } // k-loop
      } // 2-plet
   } // j-loop
} //i-loop
return 0;
What's good? The fact that not only is the primality test accurate, it's faster.
What's bad? Keying the unordered_map on the concatenation of the two numbers. It would have been wiser to have used the product. It's also not clear to me that I wouldn't do as well or better using an array and my own hash function.
Oh, and I abandoned the hypothesis that numbers in multiple tuples are sparse. They aren't.
I would argue that for a solution to count, it should be the case that you know it will find the solution if it exists without knowing in advance what the solution might be. With this solution, you still have to assume that none of the primes are greater than 2600. Then again, I guess to make no assumptions you also would need to use big numbers.
C:
is equivalent to this right (for n > 0 )?
C:
if(!(n %  2)) return false;
if(!(n %  3)) return false;
if(!(n %  5)) return false;
if(!(n %  7)) return false;
if(!(n % 11)) return false;
if(!(n % 13)) return false;
if(!(n % 17)) return false;
if(!(n % 19)) return false;
if(!(n % 23)) return false;
if(!(n % 29)) return false;
if(!(n % 31)) return false;
if(!(n % 37)) return false;
if(!(n % 41)) return false;
if(!(n % 43)) return false;
if(!(n % 47)) return false;
if(!(n % 53)) return false;
if(!(n % 59)) return false;
if(!(n % 61)) return false;
if(!(n % 67)) return false;
if(!(n % 71)) return false;
if(!(n % 73)) return false;
if(!(n % 79)) return false;
Or this?
C:
if( ( (n %  2) |
   (  n %  3) |
   (  n %  5) |
   (  n %  7) |
   (  n % 11) |
   (  n % 13) |
   (  n % 17) |
   (  n % 19) |
   (  n % 23) |
   (  n % 29) |
   (  n % 31) |
   (  n % 37) |
   (  n % 41) |
   (  n % 43) |
   (  n % 47) |
   (  n % 53) |
   (  n % 59) |
   (  n % 61) |
   (  n % 67) |
   (  n % 71) |
   (  n % 73) |
   (  n % 79) ) ) return false;
I don't know actually.
You might be able to use tables instead of hash maps. I'm guessing that would improve the performance quite a bit.
My PHP code is optimized and debugged. It finds the solution in 11 seconds and proves to it to be the solution in 3 minutes. I thought it took about 1 minute but it wasn't searching correctly. It is different because I generate a list of primes and then use that as a primality test for higher numbers. The numbers used need primes up to about 70000. I'll show the prime test function:
Code:
function is_prime($n)
   global $theprimes;
   $limit = sqrt($n);
   foreach ($theprimes as $p) {
       if ($p > $limit) return true;
       if ($n % $t == 0) return false;
   return true;
This was quite enjoyable to do but I think I am out of ideas how to speed it up.
PS. Bah, it's not quite right because I changed it to a foreach from a for loop, so it can run out of primes now rather than error. But, I'll leave it.
I only use the answer to set the size of loops. In principle, I could make this a parameter and stick it in a loop, "Find all solutions with a maximum prime of 100, 1000..." or if I were very dastardly, 260, 26000, 2,600,000... I don't think this makes a difference.
It's not. Your code would claim 13 is not prime because it's divisible by 13.
You may need to build your own computer using pci-e add on memory cards. A guy I was doing work for needed 2 either 64gb or 128gb cards to speed up his nuclear program speed...maybe all you need is a lot of RAM and a i7 processor or 2.
we still couldn't solve under a minute. Which we know that's possible. I saw couple people that proves it under a min.
It probably would, but this is a case of "speed up the work" as opposed to "do less work". The problem says that 3, 7, 109 and 673 form a 4-plet. 673 is the 122nd prime, so you might expect 1 in 30 or so numbers participates in a 4-plet. That suggests the strategy of brute-force to find the 4-plets, which should take 10's of milliseconds, and then test for 5-plets based only on numbers in the 4-plets.
This is a variation on what I proposed in #27 and what verty calls "popular" numbers. I check for popularity not at the beginning, where every number is popular, but at the end. Another way to look at this is while asking for numbers that participate in at least five 2-plets doesn't remove many, asking for them to participate in at least five 4-plets probably is a substantial reduction. A good guess might be a factor of 30.
Suppose this is a factor of around 10. That would get you down to 2 seconds, half doing primaility testing. If it's instead 100, you get to 1 second, dominated by primality testing.
Can't believe I missed that.
Anyway, it seams like this is a working faster version of that block of code.
C:
    if( n > 79 &&
     ! ( ( (  n %  2 ) ) |
         ( (  n %  3 ) ) |
         ( (  n %  5 ) ) |
         ( (  n %  7 ) ) |
         ( (  n % 11 ) ) |
         ( (  n % 13 ) ) |
         ( (  n % 17 ) ) |
         ( (  n % 19 ) ) |
         ( (  n % 23 ) ) |
         ( (  n % 29 ) ) |
         ( (  n % 31 ) ) |
         ( (  n % 37 ) ) |
         ( (  n % 41 ) ) |
         ( (  n % 43 ) ) |
         ( (  n % 47 ) ) |
         ( (  n % 53 ) ) |
         ( (  n % 59 ) ) |
         ( (  n % 61 ) ) |
         ( (  n % 67 ) ) |
         ( (  n % 71 ) ) |
         ( (  n % 73 ) ) |
         ( (  n % 79 ) ) ) )
       return false;
True, but I was responding to this previous post.
I don't think so. 13 is not greater than 79, so that evaluates to false, so the whole expression evaluates to false, so therefore 13 is not prime. :wink:
More to the point, though, the code is not spending its time here. Only 10% of the time is spent on primality tests and the bulk of this is in the Miller-Rabin phase, not the small number checking phase. If you spend 0.1% of your time testing small primes, and you make it infinitely faster, how much do you gain?
Whats the fastest deterministic prime tester in python ?
My code is somthing like this
Python:
def prime(n):
    if n < 2:
        return False
    elif n == 2:
        return True
    else:
        if n % 2 == 0:
            return False
        for i in range(3,int(n**0.5)+1,2):
            if n%i == 0:
                return False
        return True
With non-deterministic Prime Test : Time = 230 sec (with 5 random number)
Python:
import time
start = time.perf_counter()
import random
_mrpt_num_trials = 5
def prime(n):
    if n == 0 or n == 1 or n ==5:
        return False
    if n % 2 == 0:
        return False
    s = 0
    d = n-1
    while True:
        quotient, remainder = divmod(d, 2)
        if remainder == 1:
            break
        s += 1
        d = quotient
    assert(2**s * d == n-1)
    def try_composite(a):
        if pow(a, d, n) == 1:
            return False
        for i in range(s):
            if pow(a, 2**i * d, n) == n-1:
                return False
        return True # n is definitely composite
    for i in range(_mrpt_num_trials):
        a = random.randrange(2, n)
        if try_composite(a):
            return False
    return True
P1 = [i for i in range(26040) if prime(i) == True and i%3 == 1]   # mod(3) == 1 elements
P2 = [i for i in range(26040) if prime(i) == True and i%3 == 2]
def con_test(j, n):  # j is the number, n is the element in the list as tuple
    if j == 0:
        w = int(str(n[0]) + str(n[1]))
        w1 = int(str(n[1]) + str(n[0]))
        if prime(w) == False or prime(w1) == False:
            return False
        return True
    else:
        for i in n:
            w = int(str(j) + str(i))
            w1 = int(str(i) + str(j))
                return False
        return True
def st(n):            #to get rid of the repeated elements
    H = [tuple(sorted(i)) for i in n]
    G = set(H)
    return G
for i in P1:
    if i < 26040//5:
        G1 = [ j for j in P1 if con_test(0,(i,j)) == True]
        G2 = [(j,k) for j in G1 for k in G1 if con_test(0,(k,j)) == True ]
        if G2 != []:
            G2r = st(G2)
            G3 = [(p,*q) for q in G2r for p in G1 if con_test(p,q) == True ]
            if G3 != []:
                G3r = st(G3)
                G4 = [(m,*q) for q in G3r for m in G1 if con_test(m,q) == True]
                if G4 != []:
                    G4r = st(G4)
                    for j in G4r:
                        f = sum(j)
                        print(G4r, "with", i, "and sum is", f+i)
for i in P2:
    if i < 26040//5:
        G1 = [ j for j in P2 if con_test(0,(i,j)) == True]
        if G2 != []:
            G2r = st(G2)
            if G3 != []:
                G3r = st(G3)
                if G4 != []:
                    G4r = st(G4)
                    for j in G4r:
                        f = sum(j)
end = time.perf_counter()
print("passsed time:", end-start)
With normal prime tester : Time = 40 sec (But range is 9000, if I increase the range to 26034 it would take probably 10 min or so)
Python:
import time
def prime(n):
    if n == 0 or n ==1 or  n==2 or n==5:
        return False
    if n % 2 == 0:
        return False
        if n%i == 0:
            return False
    return True
P1 = [i for i in range(9000) if prime(i) == True and i%3 == 1]   # mod(3) == 1 elements
P2 = [i for i in range(9000) if prime(i) == True and i%3 == 2]
    if j == 0:
            return False
        return True
    else:
        for i in n:
                return False
        return True
    G = set(H)
    return G
for i in P1:
    if i < 9000//5:
        if G2 != []:
            G2r = st(G2)
            if G3 != []:
                G3r = st(G3)
                if G4 != []:
                    G4r = st(G4)
                    for j in G4r:
                        f = sum(j)
for i in P2:
    if i < 9000//5:
        if G2 != []:
            G2r = st(G2)
            if G3 != []:
                G3r = st(G3)
                if G4 != []:
                    G4r = st(G4)
                    for j in G4r:
                        f = sum(j)
With non-deterministic prime tester : Time = 22 sec (Range is 9000 - with 5 random number test)
Conclusion: Without the prove I can solve the problem in half minute but I need faster prime checker so it would be possible to find the solution faster in 26000 range. However I can find the solution and prove it in 3 min with non-det prime tester.
I don't understand why its "bad" to use non- deterministic prime tester ? I think its useful and right for the situation
Vanadium 50 said:
Optimization 2: Checking to see if a number is definitely prime is slow. Checking to see if a number is probably prime, e.g. by checking small divisors or any of a number of more sophisticated tests will be faster, and I don't really care if a percent or two of composites gets mixed in.
So you are right about it.
Here is the all list that I find
Code:
{(1237, 2341, 12409, 18433)} with 7 and sum is 34427
{(5197, 5701, 6733, 8389)} with 13 and sum is 26033
{(7, 2341, 12409, 18433)} with 1237 and sum is 34427
{(7, 1237, 12409, 18433)} with 2341 and sum is 34427
{(13, 5701, 6733, 8389)} with 5197 and sum is 26033
{(941, 2099, 19793, 25253)} with 467 and sum is 48553
{(467, 2099, 19793, 25253)} with 941 and sum is 48553
{(467, 941, 19793, 25253)} with 2099 and sum is 48553
I think Vanadium means the prime checker isn't the main thing causing it to be slow. On my code, the Miller-Rabin checker is about 3 times quicker. It's not so much overall. Other areas of improvement are much more important. For example, I know how to solve it without caching. Then that unordered_map stuff goes and it is much quicker. I will tell you more about this tomorrow.
Well I trust the deterministic one because it is very simple. For example, the one Vanadium used is very complicated and hard to understand. So if I'm using PHP where it's hard to debug stuff, it's easier with trusted code. I was still getting spurious results though. I'm now using C# where I can debug and profile much more easily. And it isn't so maniacal like C++ is.
Its half true and half not. For smaller range it doesn't matter but for large numbers it starts to affect time.
(We can see that on the result of the code times) I also think that the language affects the speed so python can be bad at calculating these stuff respect to C++. And time also depends how can you use the language to do stuff more efficiently.
I actually didnt understand the unordered_map thing. I tried to look the code but I don't know C++
Yes i its simple. Its just takes still much time with proofing. (or we should use some tricks). I think its nice to use shortcuts.
Edit: I checked the non-det prime test and it gives me accurate numbers up to 10**7 (%100 accurate).
I also did some more tests. But interestingly with the normal prime checker I find the results faster.
In general my code is much better then non-det test but in this case (the problem) its not I don't know why.
For example I generated random 300000 numbers between 10**9 and 10**14 and my own code give me the result in 0.9 sec and the answer was 25997 and non det code gives me the answer as 25597 in 2 sec.
Because it gets the wrong answer - it is telling you that some composite numbers are prime and possibly that some prime numbers are composite. Yes, it's fast, and yes it's simple, but so is "if odd call it prime and if even call it composite", but we don't use that, do we?
http://www.google.com/search?q=unordered_map
In general its not wrong. Its accurate as normal prime checker but its slower ?? that's kind of odd. And in this problem its much more worse
Check this 2 codes and see where I am doing wrong cause its amazing
Python:
import time
import random
def prime(n):
    if n == 0 or n == 1:
        return False
    if n == 2:
        return True
    if n % 2 == 0:
        return False
    s = 0
    d = n-1
    while True:
        if remainder == 1:
            break
        s += 1
        d = quotient
            return False
        for i in range(s):
                return False
            return False
    return True
g =[]
for i in range(10**6):
    k = random.randint(10**9, 10**14)
    g.append(k)
L = [i for i in range(len(g)) if prime(i) == True]
print(len(L))
and
Python:
import time
import random
def prime(n):
    if n < 2:
        return False
    elif n == 2:
        return True
    else:
        if n % 2 == 0:
            return False
            if n%i == 0:
                return False
        return True
g =[]
    g.append(k)
print(len(L))
print(end-start)
Arman777 said:
Check this 2 codes and see where I am doing wrong cause its amazing.
You are using 5 trials but I think it is 3x quicker with 1 trial. So 5 trials is slower.
Yes that's what I thought.. So I am doing nothing wrong and as you can see its accurate right.
For example I made another test checking prime numbers up to 10**7 and non-det gives me the result of 664579 in 85 sec but normal one gives the same answer in 64 sec.
sorry nothing is wrong ... But in any case we can see that non-det is accurate as normal prime checker but not faster
That's the same as "Sometimes its right."
If sometimes is up to 10**12 then, its safe to use in this problem.
I made couple runs and its pretty safe to use it up to 10**7. I am sure that it can go up to 10**14 maybe even more. As an example of post 79.
In any case I think normal one is better then non-det. Its just faster in my code or it seems that way Idk I ll look in more detail tomorrow. Also the unordered map thing.
My new code runs in 20s in C# and 45s in PHP. The main difference is I avoid the need for caching. To put it simply, a lot can be learned from the pairs collection. In particular, if (i, j) is a pair and (j, k) is a pair, we need to know if (i, k) is a pair.
Vanadium 50 said:
Its like dictionary in pyhton ?
Yes you are right. Thats what I did in my last code. If (i,j) is pair and (i,k) is pair then if (j,k) is pair (i,j,k) must be pair
My c# executable is taking 18 seconds and when I compile it with ngen, it takes 14. That's pretty close to the 11 of the c++. Some of the things I do are: sieving primes to get a list of them, storing the index of the first pair corresponding to a prime and the number of pairs containing that prime, using a binary search within that range to find the pair, and caching the random number that Miller-Rabin uses (I only run one trial anyway).
This is all small potatoes time-wise because the big time hog is generating the pairs (96% of total) and Miller-Rabin is taking 60% of the total. I think I can perhaps save another 2 seconds but that'll be the limit of what is possible, I reckon.
While in general I agree, if you index on the number you're testing - very fast -you will need a huge array: 676 MB if you do it naively. (The unordered map is probably 8-9 MB in comparison) When you think about physical computers, as opposed to language abstraction, you will realize that most or all of the unordered_map is in cache, but very little of an array would be.
One thing to try would be to take advantage of the sparseness of the array - for example, we don't need to test even numbers, we don't need to test pairs whose sum is congruent to 3 mod 3, and we can pack 8 bools into a byte. That gets us to just a hair over 10 MB.
Another idea I have been toying with is to take advantage of the fact the keys aren't random - they are prime numbers, and approximate functions exist for the n-th prime. One can use this fact to speed up navigation over, say, binary search trees.
Finally, one could take the profiling literally and see what can be done about the hash function. It's MurmurHash2, which is quite fast, but we're probably not doing it any favors by presenting it only odd numbers. A faster but slightly worse hash could be an improvement.
My code now runs in 5s. I made two modifications from what I wrote before.
1. When generating prime pairs, if two large primes are used the sum may be too high.
2. Concatenating the numbers was slow. I now use the following procedure:
Code:
private static long custom_concat(int p1, int p2)
    if (p2 < 10) return p2 + (long)p1 * 10;
    else if (p2 < 100) return p2 + (long)p1 * 100;
    else if (p2 < 1000) return p2 + (long)p1 * 1000;
    else if (p2 < 10000) return p2 + (long)p1 * 10000;
    else if (p2 < 100000) return p2 + (long)p1 * 100000;
    else throw new AssertionException("custom_concat, too large");
Code:
Would something like this be faster?
C:
long cat( long a, long b )
   long s = log2( b ) + 1;
   long p = a << s;
   long t = floor( log10( ( 2 << s ) ) );
   return a*pow( 10, t ) + b;
C:
   long p = a << s;
Those math functions call out to a DLL which is expensive for some reason.. I was going to see how quick it was but it won't compare for that reason. Also there is no ##log_2## function.
